07 tundra, 5.7 MOTOR with rear diff leak between bolts.
Stained diff fluid between bolts at both sides of diff. Not on ground. Other individuals noted it at other site so I looked and have same. Anyone here have same or know If normal? |
Mighty Putty will seal that right up!! Oh sorry....take it to the dealer and have them check it out. My 01 Dodge seeped from the fill hole. It was just a rubber plug. Don't even know what my yota has so I guess I should look.
08 Double Cab SR5 5.7 4x4 TRD Pyrite Mica IBTO Mods: Tinted Windows Hurst Shifter Kobalt Narrow Over Rail Tool Box Under Seat Storage Box Toyota Bed Mat Trailer Brake Conroller
Exactly 4 months and bottom bolt of rear differential seal seapage again after seals replaced.
Not same areas as before, just one at bottom of bolt, obvious yes, leaking to ground, no. Should I just leave this alone before they (dealership) really screw up the truck by trying to do it again? 13,000 miles on a 12.5 month old truck. |
