Old 10-07-2007, 04:20 PM   #1 (permalink)
Ck engine code 0441
I have an 2002 Tundra, Ck engine code 0441 EVAP system incorrect purge flow detected came on today,
What does it mean? Thanks
Peanutmantx is offline   Reply With Quote
Old 10-07-2007, 04:37 PM   #2 (permalink)
JackMS's Avatar
If you just filled fuel recently, check that your gas cap is tight. Service manual lists 5 things.
1. Purge valve
2. Purge valve circuit (between purge valve and ECM)
3. Leakage from EVAP line(between purge valve and intake manifold)
4. EVAP line (between purge valve and canister)
5. ECM
I had this code on my 05, but I think I had another code with it. I replaced my charcoal canister/vacuum pump assembly. I suspected that because the truck had flooded up to the floorboard. Fixed the problem and was only $150, + or -, for the whole assembly new from Toyota. The assembly is under the truck near the gas tank. You can check the wires and hoses on that assembly pretty easy just to see if anything looks wrong.
2007 Tundra D/C Ltd 4wd
2005 Tundra D/C SR5 2wd
2004 Sequoia SR5 2wd
JackMS is offline   Reply With Quote
Old 10-07-2007, 04:46 PM   #3 (permalink)
Evap
What is EVAP? Thanks
Old 10-07-2007, 06:34 PM   #4 (permalink)
JackMS's Avatar
It is the Evaporative Emission system. About 5 hours ( I think) after shutting off your truck, a vacuum pump turns on to pull a vacuum on the system to check it for leaks. There is a rubber hose, about 3/4" or 1", that goes from your fuel fill pipe to a charcoal canister under the truck. All the vapors coming off the fuel in the tank go through the charcoal and are filtered out instead of just going into the atmosphere. I think when the truck is running, the engine provides the vacuum. Been a while since I worked on it so a few of the details could be wrong, but that is basically it as I understand it.
Old 10-08-2007, 08:06 AM   #5 (permalink)
RunItHard's Avatar
Thumbs up Gas Cap
I got the same error message and it turned out to be the new locking gas cap I installed... Just didn't screw the thing down tight enough. The dealer told me the Tundras are very sensitive to all their sensors. I guess he was right.
The other thing he told me is unfortunately once the light comes on, you need to go to the dealer to have them shut it off. That is unless you have an error code reader with a reset on it, which I fortunately have.
Old 10-08-2007, 11:01 AM   #6 (permalink)
jpnca's Avatar
On the Tacoma I can diconect the battery to reset the computer. It may work on the tundra
