Bad gas mileage - TundraTalk.net - Toyota Tundra Discussion Forum
#1 (permalink) Old 06-20-2011, 05:05 PM
Bad gas mileage
2011 toyota tundra 4x4 crewmax t-force. getting around 8 and 9 miles to the gallon. Its got 3000 miles. Any similarities or suggestions. thanks
barberman is offline
#2 (permalink) Old 06-20-2011, 06:06 PM
rytekproject's Avatar
Thats pretty bad even for the tundras. You probably need to drive slower. How are you calculating it?
07 Crewmax Limited 4x4:
3/1, 20x9 BMF S.O.T.A zero offset, 305/55/20 Pro Comp EX AT,
AEM intake, Edlebrock Dual exhaust
Lazer Lite tonneau cover, OEM fender flares
FX-R HID projector retrofit into headlights
Mini H1 HID projector retrofit into fogs
rytekproject is offline
#3 (permalink) Old 06-20-2011, 06:43 PM
wildbill23c's Avatar
Quoted: 7 Post(s)
First of all, is your truck lifted, are you running aggressive tires, where are you purchasing fuel from? If your truck is lifted and your running aggressive tires there's where most of your fuel economy loss is going to. If your running really cheap fuel that's an issue too.
wildbill23c is offline
#4 (permalink) Old 06-20-2011, 06:48 PM
I believe the Tforces come with 20s and all terrains, but there are guys running 37s that get more than 8-9 mpg.
I'm with wildbill on maybe the fuel or possibly alignment, tire pressure?
#5 (permalink) Old 06-20-2011, 07:04 PM
Quoted: 7 Post(s)
Low profile tires are going to cause huge faults in the ride quality because there isn't enough sidewall to absorb the bumps that's what I was trying to refer too LOL. However running the stock size wheels with larger tires tends to help with absorbing bumps.
Tire pressure I don't think he would want to mess with too much having that type of tire as they tend to come unseated from the bead to easily with too little air pressure.
Bad fuel will definitely cause issues. I know some gas stations have horrible fuel and in turn will give horrible fuel economy. Ethanol fuel doesn't help any but I've only lost a couple MPG's 8-9MPG is down right horrible. I'd take the truck into the dealer and have it looked at something isn't right.
#6 (permalink) Old 06-20-2011, 07:44 PM
tonyspin's Avatar
tonyspin is offline
#7 (permalink) Old 06-20-2011, 08:39 PM
ger
ger's Avatar
i was having that type of milage with mine , and my front diff was locked up causing the front end to drag all the time .
Also switched to non ethanal fuel , still not great , averaging almost 14 mpg city/hwy and city is a shitttty 10mpg
09 double cab, 20x9 monsters(+35)
black grill, mirrors and door handles.
Trifold tonneau cover
ger is offline
#8 (permalink) Old 06-20-2011, 09:52 PM
ortegaowns's Avatar
Originally Posted by tonyspin View Post
Whats a t-force?
its the texas edition
ortegaowns is offline
#9 (permalink) Old 06-20-2011, 10:04 PM
starbuc21's Avatar
here's the answer.... you bought a Tundra. I absolutly love my truck and would most likely buy another tundra, but I can't figure for the life of me with all the technology today, companies going green and all the eco power out there, Toyota did nothing with fuel mileage when building the new tundra. Toyota can get a scion to pump out awsome HP with some TRD add-ons while maintaining good fuel mileage but the tundra just keeps on sucking. With mine being a 4x4, level kit, larger tires I average about 10 in the city on a good day if I don't get on it. Pulling our TT we're lucky to get around 7-8 on the highway. Instead of selling this truck, I'm going to buy some fuel sipping hyundi or something to comute to work. For 4 years I have been driving this beast over 100 miles a day and with the price of gas, I'm dumping almost $180 per week. Let me know if anyone can improve the mileage
2008 Tundra double cab 4x4 X-SP black w/ red rock
starbuc21 is offline
#10 (permalink) Old 06-20-2011, 10:11 PM
Trekken's Avatar
Run 91 octane and you will be alot happier. 8-9 mpg is great for an e85 rig though! I was getting 12.9 mpg with 87w10%eth. I switched to 91 and get 15-16mpg city and 18.5 - 19.5 hwy average speed 60 or so, and about 17.5 freeway cruise at or just under 70 and 15-16mpg and going down as speeds exceed 70. If you can find non ethanol fuel 91 octane 20 plus mpg should be a day in the park to achieve. Driving style affects mileage alot, a light right foot can help.
2011 DC 5.7 TRD SR5 4x4, black interior w/bucket power seats, Pyrite Mica, 3M paint protection, Running boards, backup camera and blue tooth, bug shield, Rugged Liner w/rail kit, window visors, power rear window, Pace Edwards Full Metal Jackrabbit roll top w/utility racks, tailgate step, Yakima kayak racks and weather tech floor mats.
Trekken is offline
#11 (permalink) Old 06-20-2011, 10:21 PM
Trekken's Avatar
If your towing a trailer don't exceed 65 mph, it's happier at 60. Either way I get 16 plus mpg towing a little 5,000# trailer.
Trekken is offline
The Following User Says Thank You to Trekken For This Useful Post:
Ed Zeppeli (08-13-2013)
#12 (permalink) Old 06-20-2011, 11:09 PM
Powertechn2's Avatar
Quoted: 23 Post(s)
there is only E-85... when you talk about 87 and 89 and 91, its all 10% ethanol, e-85 is 85% ethanol... huge difference.
i managed to get 14.2ish or so last time i calculated, i towed a lil, i do about 80 on the highway, and i have a heavy right foot and tunder gets sideways often...
so at 8-9, something is odd, unless your running e85.
I put the Laughter in Slaughter
2010 CM RW, blacked out, Led's,Hid's bhlm, 315/60r18 Grabber's, XD wheels, Aero turbine exhaust, more than meets the eye.
I like weapons.
and you can call me Power.
Powertechn2 is offline
#13 (permalink) Old 06-20-2011, 11:16 PM
Trekken's Avatar
Good point, either way it is crap gas. If you can locate non - eth gas you will get much better mileage. Point is Toyota tested the trucks with 91 octane non eth and the truck runs much better with it. for the added 2 -3 dollars at the pump run premium.
Trekken is offline
#14 (permalink) Old 06-21-2011, 12:06 AM
Quoted: 23 Post(s)
yea, any of the ethanol fuels pretty much bringeth the sucketh.
bio-butanol is on the way... it will be a lil better, maybe. lol
I like weapons.
argyle64 (08-24-2013)
#15 (permalink) Old 06-21-2011, 12:19 AM
Boudin's Avatar
Quoted: 21 Post(s)
Www.puregas.org
Sent from my ADR6300 using AutoGuide App
2007 5.7L TRD OFF ROAD
Bronze Level8 MK6,275/70/18 LTX AT2 ,Bilstein 5100s
Camo Wet Okoles, UC Swing Cases, Westin Steps
DIY Bedliner, Gibson 7101 Exhaust , Satoshi Grille
BHLM, Spyder LED Tails, Dip'd bumpers, Yellow Laminx Fogs
TRD Rear Swaybar, LS460 HID Retrofit ( Pazorell )
Boudin is online now
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Problems & Dealer Service/Maintenance
