The official Drive Shaft Problem thread - Page 4 - TundraTalk.net - Toyota Tundra Discussion Forum
Register Home Forums Active Topics Photo Gallery Gameroom Auto Loans Garage Search Today's Posts Mark Forums Read Auto Escrow
Old 03-19-2009, 01:00 PM   #46 (permalink)
Banned
Originally Posted by AXLES ETC View Post
I'm a 3 man operation here. Kind of a small guy I guess you can say. But Making shafts for the tacomas I can do, and have done quite a few shafts for them but the new Tundra's I have not had any action on other than the 1 one I did that was in a wreck.Its a unique shaft. I'm gonna have to start looking in to what types of tubing sizes I would need and see whats available to fabricate these. This might take me a little time but I will keep you all up to date on what I come up with.
Thanks AXLES. I can't wait. I see light at the end of the tunnel and its you holding a flashlight.
MacTruck is offline   Reply With Quote
The Following User Says Thank You to MacTruck For This Useful Post:
Mr. Creosote (02-24-2012)
Old 03-19-2009, 01:31 PM   #47 (permalink)
Banned
Update:
New drive shaft installed. Does the clunk WORSE. Dealer still has it, just called to tell me that. They are going to drive every tundra on lot, find one that doesn't do it and take the drive shaft off that one and give it to me. Thats freakin service!
Old 03-19-2009, 01:39 PM   #48 (permalink)
"Stugots"
AXLES ETC's Avatar
Man and there sure it's in the driveshaft huh? Thats a strange deal bro , I hope it all works out for ya. Wouldnt that be a bitch if it wound up being the pig yoke or pinion bearing rather. I got my fingers crossed for ya.
AXLES ETC is offline   Reply With Quote
The Following User Says Thank You to AXLES ETC For This Useful Post:
Old 03-19-2009, 01:40 PM   #49 (permalink)
"Stugots"
AXLES ETC's Avatar
At least you have a good Dealership thats working for ya !
Old 03-19-2009, 02:25 PM   #50 (permalink)
Banned
The drive shaft slides back and forth. Let me ask you axles, does a drive shaft NEED to do this? If not then why does toyota do it that way and what would happen if we installed a solid shaft?
Old 03-19-2009, 03:55 PM   #51 (permalink)
"Stugots"
AXLES ETC's Avatar
They use a stub and slip shaft to lenghten and shorten so it flex's with the vehicle when you go over bumps, train tracks,off roading etc,etc. All 2 pc shafts have a slip shaft, Ford,Dodge,and chevy long beds have the same setup. With a one pc shaft they have a slip yoke that slides onto your tail shaft of your transmission.That will slide a few inches to help out with the vehicle flewing. Thats what Iam trying to figure out on how to make a 1 pc shaft for our trucks, they do not have a slip shaft , its more like a flange that goes to the tranny. So If I make a 1 pc shaft for these trucks I have to figure out how to make it move or slide if you will. They do make a part for off roading guys that has a tube that slides into the other tube, and that will kenghten and shorten a couple feet, most guys that do rock climbing use this design shaft but it's very expensive to make. I could do it but it would cost over $ 1000,00 to make. If I can find a way to make it have some movement I could build these for around 5 or $600.00 .
Old 03-21-2009, 05:21 PM   #52 (permalink)
Banned
Dealer tried 3 drive shafts. ALL did the bump. Oh well, guess I have to live with it. One thing to note though. I drove the crap out of it when I got home. Flooring it to death. I noted 2 things.
1. The bump kind of went away a bit.
2. The flex fuel trucks are slower than the non- flex fuel trucks. Hmmmm.
Old 03-23-2009, 01:29 PM   #53 (permalink)
"Stugots"
AXLES ETC's Avatar
2. The flex fuel trucks are slower than the non- flex fuel trucks. Hmmmm.[/QUOTE]
Really ? I wonder why thati s.
Old 03-27-2009, 04:33 PM   #54 (permalink)
My truck has been having this clunking and bump from behind feeling for about a year and today I finally decided to bring it to the dealer. The service tech confirmed that the driveshaft was bad and ordered up a new one. It will be replaced next Thursday.
cyberjeff is offline   Reply With Quote
The Following User Says Thank You to cyberjeff For This Useful Post:
Old 03-29-2009, 03:32 PM   #55 (permalink)
At my dealership we have see this often and not just in tundras.We have had good results by useing emory cloth on the slip yoke,cleaning real well,adding a antiseized lube on the yoke,install shaft dont tighten the center support bearing put truck on ground then tight center support.Mactruck I think that when you be the P!$$ out of the truck that slip shaft was worked back and fourth so much that when it got HOT the reciever part expanded and did not bind as much.AXLES ETC I would like to hear your though on this.Also you will feel a bump at time when coming to a hard stop because of two things,one the shaft bottoms out on the yoke and binds,the other for what ever reason the trans dont down shift till the brake is released.I talked with the Toyota feld engineer about that a he said yea we dont know why ether?Great answer RIGHT!
2003 TUNDRA
3" FRONT AND 1.5" REAR LIFT
K&N FILTER
S&S STANLESS HEADERS
TRD EXHAUST
285X75/16 BF GOODRICH AT/KO
ALPINE RECIEVER W/XM
650 WATT HEATER TO PUMP UP THE SOUND!
LEAR CAP
GREGK is offline   Reply With Quote
The Following User Says Thank You to GREGK For This Useful Post:
Old 03-29-2009, 06:38 PM   #56 (permalink)
JCv2.0's Avatar
Gameroom cash: $2237922
Originally Posted by GREGK View Post
At my dealership we have see this often and not just in tundras.We have had good results by useing emory cloth on the slip yoke,cleaning real well,adding a antiseized lube on the yoke,install shaft dont tighten the center support bearing put truck on ground then tight center support.Mactruck I think that when you be the P!$$ out of the truck that slip shaft was worked back and fourth so much that when it got HOT the reciever part expanded and did not bind as much.AXLES ETC I would like to hear your though on this.Also you will fell a bump at time when coming to a hard stop because of two things,one the shaft bottoms out on the yoke and binds,the other for what ever reason the trans dont down shift till the brake is released.I talked with the Toyota feld engineer about that a he said yea we dont know why ether?Great answer RIGHT!
So I assume you are a Toyota Tech right?
I hate being bipolar ....... It's awesome!
The Following User Says Thank You to JCv2.0 For This Useful Post:
Old 03-30-2009, 07:48 AM   #57 (permalink)
No not a tech an advisor 19 yrs w/toyota,ASE certified in all but paint and body repair.
2003 TUNDRA
K&N FILTER
TRD EXHAUST
LEAR CAP
Old 03-30-2009, 09:53 AM   #58 (permalink)
Bought my '07 DC 4 wheel drive Tundra in late July '07(built '07/'07 in SA,TX){must have just got off the transport}.I haven't experienced the "bump" on stopping, but do occasionally get it when slowing, as in a reduced speed area, where I maintain a slight throttle pressure. It seems worse if I'm on an up-hill grade when doing this. The downshift from 6th to 5th(at about 45mph) is fine, but the downshift from 5th to 4th(about 35 mph) is when it boots ya; this is with the tranny selector in "D". I've been reluctant to bring it in, but think I will now, if only to possibly prevent "other" driveline problems
'07 DC SR5 Tundra 4x4
Pyrite Mica
Under seat storage box
Tow package
Cold package
Tekonsha Brake control
Brushed stainless sidesteps
TRD alloy wheels/Goodrich POS tires
Steel wheels/Cooper Discoverer S/T studded snows(4)
Toyota box liner-soon to be Line-xed
X-Tang tonneau cover
Bone stock and staying that way
oldtimer is offline   Reply With Quote
The Following User Says Thank You to oldtimer For This Useful Post:
Old 03-30-2009, 10:12 AM   #59 (permalink)
gregk --- I think you have hit the nail dead on.. There is more than one
thing that causes the bump... I think that the transmission down shift bump is being blamed on the driveshaft. I notice this more with the AC on. you come to a stop and the AC compressor kicks out, the engine RPM's drop wehich lets some pressure off the trans. The the trans down shifts letting the preasure off and "bump"... your looking in the rear view to see who hit you.
joefish is offline   Reply With Quote
The Following User Says Thank You to joefish For This Useful Post:
Old 03-30-2009, 09:02 PM   #60 (permalink)
well, i have an 07... and i have that clunk, but its not all the time, should i check it out? Wold they just replace the driveshaft? i like my truck how it is, and have done a couple mods...
navyhawg is offline   Reply With Quote
The Following User Says Thank You to navyhawg For This Useful Post:
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Copyright 2006-2009, TundraTalk.net. All Rights Reserved.
