I have a 2012 Tundra CrewMax, 5.7 that I need your help with!
Long story short, I brought my truck to the dealership for an oil change. I drove away and after the truck began stuttering, struggling to move, I immediately returned to the dealer.
When I checked the oil, there was nothing on the dipstick. I checked it again, and nothing came out on the dipstick. The oil guage in the truck was all the way to the left.
My question is: What is the maximum amount of oil that could have been present with NO OIL showing on the dipstick?
I called Toyota direct, and they said that they'd have to leave that to the dealer to decide...not much help.
Thank you in advance!
The Following User Says Thank You to 211lostlake For This Useful Post:
Wow thats bad news. Thankfully you didnt get very far. Still dont let them try to weasel out of it. Try to get lifetime maint/extended warr or something like that out of it.
The Following User Says Thank You to Tundra Hunden For This Useful Post:
It has been my experience that the two hash marks on the dipstick account for about a quart of oil. If the dipstick is totally dry, then I would estimate that you are at least 1.5 quarts low. Of course, you could be at zero too.
The only way to know is to either top if off and back calculate, or drain whatever oil there is.
I'd plant myself on the shoulder of the tech and take copious notes. They may have just bought you a new truck.
2010 5.7L SR5 TRD 4x4 DC ==
The Following 3 Users Say Thank You to The Onceler For This Useful Post:
The dealership added oil without me seeing how much was added. They have my truck now and are inspecting it. I have no reason to doubt them, but am just skeptical that, as they claim, there was plenty of oil when I brought it back. Why would it have made awful noises if "nothing happened "? Why would it have stammered? Everything was fine when I brought it in.
No reason to doubt them??
Lets assume that they returned your truck to you with insufficient oil, resulting in damage. Where is the upside for them in revealing that information to you?
And, as you noted, they are telling you that there was plenty of oil, despite the fact that you found a bone dry dipstick, and despite the sudden onset of obviously bad symptoms.
They are telling you that all of this is merely in your head, and you say you have no reason to doubt them?
Make sure you keep that documentation.
1- Oil change documentation from that day.
2- Oil shortage documentation from that same day, 30 minutes after they finished your oil change.
MAKE DAMN SURE they write up a work order that specifies that you returned with an oil shortage, and they added more oil in. They should put how many qts were added. At any rate, DO NOT let them just top you off and send you on your way. IF/when your motor blows, and there is nothing documented that THEY shorted you oil, then THEY added more oil, you're screwed.
The Following 3 Users Say Thank You to Bad Dad's Tundra For This Useful Post:
I guess what I'm trying to say is that they are very convincing when they say nothing is wrong. I'm not big on confrontation and am looking for advice on how to handle.
OK. Got you. I am much the same. I apologize for letting my sarcasm get the better of me when making my point.
I'd gird my loins for potential conflict and follow Bad Dad's advice.
Good luck.
The Following User Says Thank You to The Onceler For This Useful Post:
It sounds bad. You stated that the oil gauge was all the way to the left meaning no oil pressure. It has to be really low for that to happen. Someone should be able to tell you the low pressure reading on the idiot gauge. My previous Chevy actually had the PSI listed on the oil gauge. The middle point was about 50 PSI (normal) and the low point (needle on left peg) was below 20 PSI.
__________________ 2012 Toyota Tundra Rock Warrior Dbl Cab 4WD 5.7L
Color: Magnetic Gray
LineX XTra, Undercover SE Tonneau, Underseat Cargo, WeatherTech Floor Liners, Revtek 2.5/1.5 Leveling Kit
The Following User Says Thank You to TundraRockWarrior For This Useful Post:
With it struggling to move, there is ABSOLUTELY engine damage. If they just added oil and sent you on your way, That's CRAP. The best thing would have been to start it back up when you realized the dipstick was showing nothing and run it till it seized.
- I'm Ken and I approve this message -
2012 Black SR5 DC 5.7 - TRD SS Steps - 20" Ultra Mammoth Wheels - Nitto Terra Grapplers 285/55-20 - CST Spindles - +2 Shackles - Rear 5100s -
Tint - Ventvisors - Sport Shifter - Line X Premium - Access Loredo Tonneau - White Dash LEDs - BHLM - Oracle Halos - Dirty Deeds BAMuffler SS Exhaust....
Details in "My Garage"
Frequent Yamaha AR230 Jetboat Attachment!
The Following User Says Thank You to Big Shasta For This Useful Post:
I'd be talking to the dealership GM NOW! I'd demand a new truck, as the wear that was a result of their carelessness won't present itself right away.
I appreciate you don't want to be confrontational, but you may need to be, as well as professional, to make this right.
What's to say they forgot to put oil in it?
They obviously didn't check the level when they were finished with your oil change did they? Otherwise they would have known it wasnt full.
Very well could have pooched the internals (pistons, rings, bearings etc.)
I would be very leary about accepting them at their word.
A new engine is in the $20,000 range.
Do you want to be on the hook for that?
I know I wouldn't.
I wouldn't have let them take the vehicle out of my sight either.
I would want to know for sure exactly how much oil it was low.
The Following User Says Thank You to TundraOnTheTundra For This Useful Post:
