TundraTalk.net is the premier Toyota Tundra Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 01-17-2009, 01:59 PM   #1 (permalink)
surfer's Avatar
MAF sensor cleaning
I've been getting check engine alarms with error code P0101 appearing from time to time (sometimes once every 2 weeks and sometimes in appears back again after fews hours).
Once i got error code P0171. When reading the description of both errors and possible cause, MAF sensor cleaning is suggested.
Now, they say that i have to clean it using an electronics cleaner. Can anyone guide towards what an electronics cleaner is and where can i buy it ( on the internet, of course).
surfer is offline   Reply With Quote
Old 01-17-2009, 03:27 PM   #2 (permalink)
Brandon Johnson's Avatar
walmart... they have a computer board cleaner. thats the only thing i can think of..
Brandon Johnson is offline   Reply With Quote
Old 01-17-2009, 10:09 PM   #3 (permalink)
surfer's Avatar
Is it a chemical spray or is it a can that just blows air ?
Old 01-17-2009, 10:13 PM   #4 (permalink)
bolivia310's Avatar
a chemical spray that is non-conductive. I have used this product a few times and like how it works.
Private Label - Contact Cleaner
08 Tundra DC, SR5, 5.7, TRD Off-road, Slate Metallic w/graphite interior.
bolivia310 is offline   Reply With Quote
Old 01-17-2009, 10:45 PM   #5 (permalink)
surfer's Avatar
Thanks for the info, I already have one of those, I will use it today and see how it goes.
Old 01-18-2009, 02:21 PM   #6 (permalink)
Despized's Avatar
They make a Map sensor cleaner. you can buy it at Checker or Autozone or any other autoparts store. I use it everytime I change my oil. If you read on the side of the can it recommends it. But pick up a can the s**t work really well. I had to use it on my GT2 alot and when I used to work for Lambo we used it on alot of applications. Ive seen a 4hp difference on the dyno with a Subaru WRX. Try it out! Its kina pricey!
Despized is offline   Reply With Quote
Old 01-18-2009, 05:36 PM   #7 (permalink)
Brake cleaner is what most of the dealer ships use.
2007 DC 4X4 Limited
TRD,Tow,NAV
Afe CAI, Xcelerator Exhaust
275/65/18 BFG AT/KO
Desert Sand
Skyhammer is offline   Reply With Quote
Old 01-18-2009, 06:23 PM   #8 (permalink)
ramoine's Avatar
Thought this might help :How To Clean A Mass Air Flow Sensor | Adventure Road Trip
They recommend Contact cleaner from radio shack .
sig pic by http://screenfx.ipbfree.com
Old 01-18-2009, 06:39 PM   #9 (permalink)
Despized's Avatar
Tried Brake Cleaner. BAD BAD BAD. It cost me a sensor a few years back work at a dealer, the chemicals inside brake clean removes coating on electrical componets cuasing short to ground. It may work a few times but! CRC is the company that makes the MASS AirFlow Cleaner.
Sponsors
