Engine & Trans temps before and after supercharged - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 13 (permalink) Old 04-18-2017, 07:11 PM Thread Starter
Quoted: 34 Post(s)
Cool Engine & Trans temps before and after supercharged
All temps are from bullydog gt.
Lightly loaded or empty
Before sc:
engine temp: 185
Trans temp: 185
Imissbdc
With sc:
Engine temp: 195
Trans temp:195
Normal driving.
Driving 80-90mph regardless of weather or temp both engine and Trans goes to 204-206.
Does anyone supercharged with bullydog see the same temp increase?
Running no tune.
Only reading bullydog gauges.
Yuckfou is offline
The Following User Says Thank You to Yuckfou For This Useful Post:
Mr. Creosote (04-18-2017)
post #2 of 13 (permalink) Old 04-19-2017, 12:30 AM
Quoted: 423 Post(s)
all i can think of is the front s/c low temp radiator could be the cause of that.
restosud is offline
post #3 of 13 (permalink) Old 04-19-2017, 07:12 AM
RIjon's Avatar
Quoted: 230 Post(s)
That's good news. 206 is nothing for a transmission.
08 RCSB B00STED
10 T4R
RIjon is offline
post #4 of 13 (permalink) Old 04-19-2017, 07:15 AM
Quoted: 223 Post(s)
I have the edge cts2 which monitors both the torque converter and pan temp. It floats around 185-209 peak is usually once I'm stoping and starting more frequently.
Corsa sport catback / FFV TRD supercharged / Bilstein 5100's / airlift loadlifter 5k / Mini D2s Retrofit / TRD rear sway bar / XSP LED DRL's
Rockwarrior club member #45
j_fuggin_t is offline
post #5 of 13 (permalink) Old 04-19-2017, 05:30 PM Thread Starter
Quoted: 34 Post(s)
Towing 12' enclosed trailer with 4 Ktms. Prolly 2300 lbs.
80-85 mph light head wind.
Max engine temp: 206
Max Trans temp: 206-208 highest I've seen.
Does anyone know where the Transmission temp sensor is located?
Yuckfou is offline
post #6 of 13 (permalink) Old 04-19-2017, 05:37 PM Thread Starter
Quoted: 34 Post(s)
I agree.
Heat soaking the intercooler speeds up the process.
Also the blocked airflow.
Yuckfou is offline
post #7 of 13 (permalink) Old 04-20-2017, 06:54 AM
Quoted: 78 Post(s)
I'm guessing your truck is 2010+? The original ATF cooler was off to the side for this reason.
Brian
bjowett is offline
The Following User Says Thank You to bjowett For This Useful Post:
RIjon (04-20-2017)
post #8 of 13 (permalink) Old 04-20-2017, 12:16 PM
Quoted: 423 Post(s)
but it did not benefit from the fan air at lower speeds and at high speeds the high pressure air in engine compartment prevented good air flow as well.
restosud is offline
post #9 of 13 (permalink) Old 04-20-2017, 04:29 PM Thread Starter
Quoted: 34 Post(s)
i'm guessing your truck is 2010+? The original atf cooler was off to the side for this reason.
2008
Yuckfou is offline
post #10 of 13 (permalink) Old 04-22-2017, 03:14 PM
ViktorG's Avatar
Quoted: 150 Post(s)
I have removed the blower, but still have the low temp rad in front of the condenser installed.
I am seeing engine and trans temps of 190 - 195 F under steady cruise at 70 mph.
I have an intercooler fluid temp sensor installed on my truck, and while I was running the blower I would rarely ever see fluid temps over 100 F - only after a run under heavy load.
I am in Canada though, so temps are cooler here overall.
Agreed, on my 2008 the transmission sometimes overheats while off-roading and climbing very steep hills at slow speed.
I think the new design with the trans cooler built into the condenser is better overall.
2010 RCSB 4x4 (497whp/466wtq) - TRD SC, 1.25 Gal IC tank, IKH-24 plugs, 325 LPH AM FP, weight reduction
2008 DCLB AWD (329whp/338wtq) - TripleR cams, IPT VB, 325 LPH AM FP, 2x12" E-fans, Sequoia AWD t-case and Optitron cluster, IS250 paddle shifters, 12" BP lift with Toytec 3" shackles + 1" blocks, 17" MotoMetals with 37x12.5 Cooper ST Maxxs, 3" spacers, ARB frt bumper, 8500# Superwinch, KC 8" lights, HID headlights and fog lights, Autometer boost, AFR and IC fluid temp gauges, TRD shifter, flares, LEER canopy
Me: Shop foreman at Lexus of Calgary, Toyota Master Tech
ViktorG is offline
The Following 2 Users Say Thank You to ViktorG For This Useful Post:
restosud (04-22-2017), RIjon (04-22-2017)
post #11 of 13 (permalink) Old 04-22-2017, 05:09 PM Thread Starter
Quoted: 34 Post(s)
I just loaded bd 93 SC tune.
I don't expect to see any temp change
I tried it before and couldn't really feel much difference other than firmer shifting.
Running 91 but I can't imagine it matters.
Time will tell.
Yuckfou is offline
post #12 of 13 (permalink) Old 04-24-2017, 02:58 AM
Quoted: 36 Post(s)
Airflow, especially with such a small differential before and after.
freudie1 is offline
post #13 of 13 (permalink) Old 04-24-2017, 06:48 AM
Quoted: 78 Post(s)
The early system has the potential to be superior as it won't be adding heat to the air that also needs to cool the radiator behind it. The Land Cruiser still uses the side mount, but has an additional oil to coolant in the lower radiator Tank. A dedicated fan for the side mount will take care of slow speed work.
Brian
bjowett is offline
