Originally Posted by ***nutjob
Ya gotta be careful with using hoses in an intake as they may collaps. You need to use something ridgid like PVC, and at least 3" to make it worth the effort. 3 or 4" PVC 90's and 45's take up too much room and would be next to impossible to use. Although using the fog light cavity has been talked about there still isn't any room to rout anything big enough up to the air box. My added 3" fender intake works awesome! If anyone comes up with a ram air post it for sure!
The hoses I referred to will not collapse the are metal reinforced , I've used them to pump grout , portland cement and to fill up water trucks with a 6" pump.
I'll look at my truck this weekend and see if it's at all possible to run this set-up to the intake box .
I'll post some pics as well , and hopefully provide some info that will be useable.
