Free HP mod, stock Air box lid charcoal filter delete!
Note: I am making this thread because I spent an hour searching for info on this with no luck. Special thanks to Dez and sxd for telling me to rip it out
![]() Remember, if you install any CAI or after market intake, you will be with out this charcoal filter. So why keep it! Time: 30 sec 1. Pry off the charcoal filter with a flat head screw driver. Start with a corner, then just it just pops off with little force Example of how it pops off: Note: No need to cut the filter. 2. Test drive. The charcoal filter is very restrictive. Using a can of compressed air, blowing through the charcoal filter cuts the air down to only a trickle. Just look how thick this 7 layer beast is: Wow, what a diffrence! Loud, deap throaty sound up front! Increased throttle response! Next steps: Im guessing, find and install a drop in filter. Then dyno this vs a common CAI.
![]() 07 5.7L Sky Silver Double Cab -EGR Vents/Bug guard -TRD Sway bar -Corsa Touring Exhaust -Charcoal filter delete Gallery Last edited by Cyprex : 06-25-2008 at 12:37 PM. Reason: Added Easy Way Instructions. |
Thanks. I'm gonna do that tonight!
www.IBTOHQ.com |
You know with a little smoothing out of the lid, im sure there will be more of a gain, all those ridges do is slow the air flow to make it quieter, I will take a dremel or grinder to mine soon and update everyone.
![]() White Tundra Club Member #1 |
What's that filter for anyway?
www.IBTOHQ.com Last edited by SRT8TUNDRA : 06-08-2008 at 07:05 PM. |
www.IBTOHQ.com |
#7 (permalink) |
.......don't see how it can be restrictive as these trucks run lean....ULEV II. According to K&N, airflow is only 1-2 mph across the filter element at 70 mph. Again, if the factory intake was restrictive, it would be causing a rich operating condition.
Can Oil Come Off Our Filters? High Airflow Testing & Engine Air Filter Dynamics
#8 (permalink) |
I thought they run rich!
www.IBTOHQ.com Last edited by SRT8TUNDRA : 06-08-2008 at 07:04 PM. Reason: grammar |
#10 (permalink) |
Thanks, TB.
www.IBTOHQ.com |
#11 (permalink) |
Very inventive mod . Thanks for sharing !
#12 (permalink) |
Removing it will make the intake a little louder. I popped mine out after about a month of owning the truck. Supposedly the charcoal is there to clean any backflow gases when you turn the truck off.
#13 (permalink) |
Yeah I just did it! Intake is a little louder and seems to be just a little peppier. May be my imagination though. Very easy mod. Took me about 10 minutes.
www.IBTOHQ.com |
#15 (permalink) |
Yeah, the butt dyno told me I picked up .99 hp and 1.7 ft lbs of torque!
www.IBTOHQ.com |
