#17 (permalink) | |
Not quite,HEHEH,my GReddy type S on my 98 TC HRC Neon sounded like you done run over a 400 pound house cats tail when you got off the fast pedal at 25 psi.Couldn,t even hear the K&N intake over the noise of the turbo spool and the 5" SS Modern Automotive exhaust. That whistle sound you hear maybe swirl, as my Jeep made that noise when I got on the gas,but then again it had a air flow swirl built into the TBS??????? |
#20 (permalink) |
I have the K&N 77. mine whistles only on a slight acceleration, like when you are trying to stay at a constant speed. no sound when I am coasting. Growls when I get on it. Not a major problem, but annoying when you have the cruise set.
#22 (permalink) |
I installed a K&N 77 CAI this morning, and just got back from a short (about 20 mile) test drive.
NO WHISTLES, at any throttle settings. I had one of these on my last truck, and it never whistled then either. Power feels incredible. I did a back to back test(not immediately back to back due to install time--anybody else find the K&N instructions a pain in the butt? Some of the brackets COULD NOT be installed in the order they instructed, but were easy to install in a different order!) The K&N would get the tires spinning if I punched it from speeds up to 40 mph, where stock it would only spin the tires from stopped to about 15 mph!!! |
#23 (permalink) |
just installed mine this afternoon too. no whistling on mine either...just some typical breathing sounds when I get on it. I totally dig it so far. I actually thought they did a pretty good job with the instructions too...although, I can't recall if I went step by step or not. I usually only use those things for a guide anyway
![]() oh! I also got K&N's dry charger cover for their filter to protect it from any moisture that may make it's way to the filter. i dig it so far too! |
