#16 (permalink) |
IMO, higher octane gasoline will improve performance because the Tundra's computer will advance the ignition timing with it. The reason these trucks won't experience pinging with 87-octane is because of the knock sensor/computer. Not saying that 87 will create ping but just because you get none on 87 doesn't mean performance will not increase with higher octane gasoline. Also STP fuel treatment in a tank of 87 octane gasoline does not equal 91/93 octane fuel. Premium gas will also increase fuel economy, whether it be the fact that it burns slower or not, it does work.
#17 (permalink) |
This is the first vehicle i've ever put premium in on purpose. I did it once in my old SUV on accident.
#18 (permalink) |
I'm going to try premium to see if there is any performance diff. Just because you don't hear pinging or knock doesn't mean anything because the knock sensors hear it first and retard the timing, therefore reducing power.
'07 RCSB 4x4, 5.7. Much Faster than my modded Hemi was. Insulated intake & box. Drop in K&N. Removed top filter. Bypassed TB coolant hose to keep intake cold. Valve cover hoses to breather, not intake. 305-50-20 Yoko's on 20 x 9 chrome MB 5 spokes, Debadged, More to come... WANT TUNER! |
#19 (permalink) |
Toyotas are sensitive to Octane rating. I've tested it on the past five Toyotas I've had and I've already tested it on this truck. Mileage and overall driveability improve with Premium gas on my Toyota vehicles. YMMV.
2008 Tundra Crewmax 4X4
#20 (permalink) |
Has anyone of legitimate credibility verified that the toyota ECU actually alters the tune to suit the gasoline (octane rating)?
If so, it'd be the first I've ever heard of doing so. That'd be a pretty advanced ECU. The only way the engine could do so would be to advance the timing up to and just to the edge of engine knock. Running higher octane fuel would in theory result in more power if like stated before, the ECU could run more advanced timing and/or lean out the fuel a little more to make more power. I highly doubt that the ECU has this capability. Again, without a wideband input, the only way it COULD do so is to advance the timing such that it was just at the point of activating the knock sensor.....and I highly doubt that Toyota would do such a thing as it would be only a matter of time before you had a bad fuel/air/spark exchange and had damage to internals. In some engines, namely high compression, high performance types, running higher octane fuel actually yields more power because the engine runs smoother. (with no change to the tune). But for the most part, running higher octane fuel is nothing more than added insurance against engine knock...especially in hot Summer months where towing uphill in 100*F heat would DEFINITELY benefit from running 93+ octane. I can tell you that the amount of any increase in fuel mileage you experience will NOT be equal to the cost increase of the premium fuel.
2008 Black Double Cab SR5 |
#21 (permalink) | |
87 octane- $3.00 93 octane- $3.20 to $3.30 (comes out to $4 more a tank (20 gallons) at $3.20 a gallon) If I use 20 gallons and I get 300 miles out of those 20 gallons, with 87 octane it costs me $0.20 a gallon. Now if I get 1 mpg better with premium (which I get 1-2 better) that would mean I would get 20 more miles out of 20 gallons of gas or 320 miles. So it would cost me $0.20 a gallon or the same as using 87 octane. So it costs roughly the same as using the cheap gas and the truck runs better so use what you want, I use premium. I know that is not real world but it was the simplest way to explain it. Oh and I hope my math is right, it's late. ![]()
#22 (permalink) | |
#23 (permalink) |
Has anyone been to or seen where they distribute the gas to these tanker trucks? Reason being I watched for awhile not thinking much about it at the time to my amazement at a Hess distributor seeing Pilot J, Raceway, Shell, Chevron, Flash Foods (Exxon), BP trucks all there getting the same fuel. Who is the superior brand?
#24 (permalink) |
Mickey,
From what I have been told is all the tankers get their gas from the same distrbution center. But the trucks already have the additives in the tanks when they get the fuel load or they have to add it before getting to the gas gas staions. Since the load is so large I beleive that the additives are in before hand. We have a distrbution center down near the water and all the trucks get their load there.
For those who serve our nation. Our Prayers are with you. |
#25 (permalink) | |
#27 (permalink) |
Wallygator I will try it. Wednesday I'll make another 400 mile trip and we will see. I did 80mph and had 17.3mpg using the cheap stuff. I made 400 miles on a tank so we will try this tomorrow with a full tank of premium.
#28 (permalink) |
Yeah I'm interested to know if you feel a difference. I feel a difference but it could all be in my head.
Even if my mileage didn't improve, four dollars is worth it to me because I think the truck runs better. YMMV.
#29 (permalink) | |
#30 (permalink) |
My job in the military is Fuels. In my job we have to sample and Lab test different grades of fuel from Jet fuel to diesel to mogas (or unleaded fuel) to make sure they pass certain standards. The truth is that the different grades of unleaded gasoline have different "Flash points". This is the difference that your engine sees. When your engine flashes at different temperatures it directly effects the timing of the engine. Although this is so minute by scale, over time your engines ECU learns through sensors, the time at which you cylinder flashes, in turn adjusting the other components accordingly. Higher octane gas burns hotter and faster, which creates more power and a cleaner burn.
Bottom line is there are differences in Octane and the higher the octane (within limits to your ECU tune) the easier and better your engine will run The good things about todays cars/trucks are the ECU's are better tuned for todays crappy gas. You will see suddle differences between grades, but they are there. Hope that helps a little. Just be glad you dont have to use Bio-diesel. That crap sucks!!! |
