Supporting Vendor
RMJ - K&N Intake install
Hey guys, well I got the K&N Intake for our Tundra. Comes with everything you need including hardware and bolts and nuts. The kit is pretty straight forward, install took about 35 minutes, mainly cause it got dark and I did it outside of our shop (we were tuning the new race car in the garage) and I got stubborn and did not want to grab a lamp, lol.
Tools I used were: 10mm wrench (mine is ratcheting but normal will work) ¼” Ratchet 8mm socket 10mm socket 12mm socket Flat head and Phillips Head Screw driver Razor blade Most complicated part, which was not hard just time consuming, was running the seal around the heat shield, after that its smooth sailing. Unplug the negative battery terminal (12mm bolt). Removing the air box is simple, loosen the clamps at the throttle body and air box, all are 10mm sockets or a screwdriver. Carefully unplug the MAF and disconnect the vacuum hose and the crankcase vent hose. Unclip the upper airbox and carefully remove the upper air box and intake tube. The lower air box is held together with two 10mm Bolts, looking at the front of the Truck, one is in the lower right front outside corner of the air box and the second is in the upper left outside corner. Remove the lower box and it is all clear. ![]() ![]() Next you prep your heat shield (carefully use the razor to splice the seal to make it around the 90 degree corners), loosely attach the two inner L-brackets (do not tighten any of the nuts and bolts till the end, this will help line-up everything.). Attach the L-bracket to the side of the passenger fender-well and also attach the Funny looking L-bracket to the side of the passenger-side engine valve cover. (basically follow the detailed K&N instructions.) Line everything up, start all the bolts and once it is all lined up, tighten away, make sure not to over tighten the nuts and bolt, as they are only 10mm and do not need to be tightened much, 6-8 lb feet at the most. ![]() ![]() Attach the intake pipe to the throttle body, loosely tighten the clamps (I used the 8mm socket), attach the filter, tighten everything down. ![]() Don’t forget to attach the funny L-bracket from the valve cover to the bottom of the Intake pipe. Lastly place the engine cover back on, nice thing is you do not have to trim it to fit. Re-connect the negative battery cable. Double check to make sure the MAF is in the correct position. And start her up. ![]() ![]() ![]() ![]() On my truck the Maintenance Required Light blink a few times, but went away. The CHECK ENGINE light did not come on. Drive for about 100 mile for the computer to relearn itself and to re-program your radio presets. This intake really impressed me, throttle response improved dramatically, engine comes to life when you mash it. The sound is beautiful, at cruising it is calm and tame, but when you floor it sounds awesome. Definitely recommend it. Can't wait to add the exhaust. Let me know if you have any questions. Miguel - RMJ
2007 Toyota Tundra 5.7 Slate, Double Cab 1990 Nissan 240sx - Daily Driver 1989 Nissan 240sx Pro Drift Spec (the HATCH) - FOR SALE - 1991 Nissan 240sx Pro Drift Spec (the COUPE) www.RMJMOTORSPORTS.com ![]() Performance Parts - Technical Consulting/Support - Track Proven |
Where did you get the k & N kit from? How much? What happens to the crankcase and vacuum hoses? What kind of exhaust are you going to put on?
2007 Black Tundra Crew Max 5.7L TRD 4X4...Line X bedliner, custom seat covers, K & N CAI, westin signature series black step bars
Supporting Vendor
Jar, we sell the K&N Kit, it's $300 for members of the forum, plus shipping. The Vacuum and Crankcase hoses, reattach to the K&N Intake Pipe, You reuse the vacuum and extend the Crankcase hose with an extansion and hose that is provided in the kit.
AS for the exhaust, I'm keeping that hush for now, in the works. Let me know if you are interested in the Intake kit.
Thanks for the info...I will let you know!! Want to do intake and exhaust as well. Stuck on what exhaust to get...waiting on more reports on the forum...thanks again.
My install looks a little different than yours. It looks like the heat shield is bent in the pics on your truck? Mine seals up really tight up against the washer tank. I think you have the front bracket installed wrong? Not to be a pain just trying to let you know the install looks a lot cleaner on my truck and the heatshield actually seals out some of the heat.
2007 Tundra dc sr5 4x4 5.7 trd blue streak metalic K&N 77 series intake, trd shifter , trd pedals, trd oil cap, xsp style steps,underseat storage, timbren system 14.9@ 92mph (15.2 on streetfire tundra vs. vette) both completely stock 2004 mercedes c230 sport coupe 1992 eagle talon tsi awd modded |
Supporting Vendor
Top, god point did not notice that, I will take a look at the mounting hold on the body for that bracket, I might have used a whole that was a bit further back, lol duh to me. I did install it at night while tuning and finishing our race car, but there is no excuse for being a goober.
#7 (permalink) |
Supporting Vendor
TopSecret was right, I will put up a pic tomorrow, I had the l-bracket reversed. Good call Top
#8 (permalink) |
I dug around but didnt find an answer so I thought I'd just ask....do you happen to know if this affects the warranty? Or if they are likely to give you a hard time about that (bad experiences with dodge dealers - maybe not fair to assume toyota would do the same).
#9 (permalink) |
Supporting Vendor
I can Imagine that if you need to take the truck in for a warrenty issue they would give you a hard time. I kept all my stock box equiptment so I can slap it back on if necessary
