All cats delete - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 11 (permalink) Old 02-08-2013, 12:00 PM Thread Starter
Quoted: 292 Post(s)
All cats delete
Well, don't want to hollow it all out since we need them for inspection. But if we replace the four cats with two straight pipes (possible adding a couple of small mufflers there to keep noise level down), with stock header, will this help leaning out the super rich stock map & gains any ponies at all? Will need a URD o2 sim to keep the light off too.
Also, any muffler in place of the cats that will keep the noise level the same? I really want some more flow/lean out the maps but don't need anymore noise. This will be on SC/stock header/ <straight pipe with mufflers?> / Corsa touring catback w/ extra 3" resonator after muffler.
randomwalk101 is offline
The Following 3 Users Say Thank You to randomwalk101 For This Useful Post:
Mr. Creosote (02-08-2013), shotgun (02-12-2013), Wacked (02-08-2013)
post #2 of 11 (permalink) Old 02-08-2013, 12:03 PM
stroked383z's Avatar
Quoted: 1053 Post(s)
I wouldn't mess with them.
11 Tundra CM 4x4 TRD Offroad, Spruce Mica, Zone 3/1, 20x9 XD Black Hoss, 35x12.5x20 Nitto Trail Grappler, TRD Skidplate, Sunroof, Cold Weather Package, Clarion NX501 NAV/DVD, 2 DC Audio 10's, custom ported box, CT Sounds 1400.1D, XenonVision HID's, Plasmaglow Fire and Ice Light Bar, Rhino Liner Hardline, Tri-Fold Bedcover
stroked383z is offline
The Following 2 Users Say Thank You to stroked383z For This Useful Post:
Mr. Creosote (02-08-2013), Wacked (02-08-2013)
post #3 of 11 (permalink) Old 02-08-2013, 12:47 PM
scotman623's Avatar
It can be done but not advised to do so, Would be better just adding some headers and aftermarket Muffler, Just my thoughts.
2012 Rock Warrior D/C 7" BDS lift, XD Cranks Matte blk. 20x9 0 offset, Toyo Open country M/T 35x12.50
tinted windows, Recon smoke led tails and 3rd brake, Bull bar plasti dipped black, Carbon delete,KN filter.
Bushwacker sport fender flares,Black window deflects.
Husky floor liners,Info button install,hypertech speedo
Extang tri-folding tonneu cover, BAMUFFLER 6 INCH.Custom punisher grill emblem.
scotman623 is offline
The Following 2 Users Say Thank You to scotman623 For This Useful Post:
post #4 of 11 (permalink) Old 02-08-2013, 09:31 PM
TRD_Tundra's Avatar
I cut all my 4 cats, got rid of those 2" hidden exhaust pipes in the Y pipe with a new 2.5"
Dough Thorley Long tube headers and thru the factory muffler and 3" outlet w/ URD O2 simulator. It's quiet but with the Cutouts open it sounds like a monster!
2011 FFV Tundra Limited: SuperCharged (TRD Forged 22"s, Lucchese, ASP pulley, Valve Body, DT Long Tubes, TRD Swaybar, Deleted all cats, AEM F/IC-8 Tuned, Dual e-cutouts)
2006 Silverado 5.3 (76mm Turbo,Cam 216/220, AEM TruBoost, AEM Wideband, Built 4l80e, Dual springs, Bosch 60# injectors, Aeromotive 340, AEM Meth injection... Boost is at 12psi on meth) Tuned by TELLEZ
TRD_Tundra is offline
The Following 2 Users Say Thank You to TRD_Tundra For This Useful Post:
post #5 of 11 (permalink) Old 02-08-2013, 09:41 PM
BLOWN's Avatar
I got rid of mine doing the dt headers with the dt cat deleate pipes and urd sims. Still running factory tail section but am a huge fan of being able to return back to stock if need be. Noticed a little low end loss but alot of top end gain, with the sc low end loss is not really an issue. Shoots flames now ha. Only down side is that the exhaust smells horible and it takes way longer for the truck to warm up.
BLOWN is offline
The Following 3 Users Say Thank You to BLOWN For This Useful Post:
post #6 of 11 (permalink) Old 02-08-2013, 10:47 PM
Chief of Grammar Police
Wacked's Avatar
Quoted: 1513 Post(s)
Have you talked to DirtyDeeds? I am sure he would be able to fab something up and give you some advice on a direction to go.
Born in TEXAS built by TEXANS
aFe Stage II Pro-S Dry Si
Wacked is online now
The Following 2 Users Say Thank You to Wacked For This Useful Post:
Mr. Creosote (02-08-2013), RedBullistic (02-08-2013)
post #7 of 11 (permalink) Old 02-08-2013, 10:49 PM Thread Starter
Quoted: 292 Post(s)
Well I'm concerning about the excess noise without the cats.
Mr. Creosote (02-08-2013), RedBullistic (02-08-2013), Wacked (02-08-2013)
post #8 of 11 (permalink) Old 02-12-2013, 08:02 AM Thread Starter
Quoted: 292 Post(s)
Found this guy in Tucson who made one. He doesn't have the resonator or muffler on the test pipe so it's super loud as I expected. I wonder of a couple of small mufflers or resonators solve his issue. I want something like this for better flow without going LT and not too much noise (adding mufflers/resonators).
07-13 Toyota Tundra cat bypass pipes (test pipes) w/o2 simulator (22nd/wilmot)
I had these custom made for my 08 Tundra with the 5.7 engine because i have the supercharger and blew out a cat! These replace both catalytic converters on both sides and the o2 simulator plugs into the rear o2 sensors to send a signal to the computer so you don't throw a code! I had them on for a week but the problem is the truck is too loud now (says my significant other) so i need to sell them now! They open up the exhaust flow considerably!!! The nice thing about this set up is it's designed to bolt right up to the stock exhaust manifold! noone sells any to do that, just to bolt up to long tube headers which i didn't want! so if you (and your wife if you have one) don't mind the increase in exhaust sound this is a nice horsepower add. just trying to recoop my money but all my hardwork is free!..... only asking $350 for everything! that includes the o2 simulator from URD!.....any question please call or text 991-1407
The Following 2 Users Say Thank You to randomwalk101 For This Useful Post:
Mr. Creosote (02-12-2013), Wacked (02-12-2013)
post #9 of 11 (permalink) Old 02-12-2013, 10:12 AM
"The Antagonizer"
JOSH 5.7's Avatar
Quoted: 4 Post(s)
You won't lose power but you will lose gas mileage. It makes a good difference in the sound. Opens up a sound not heard often from these trucks which sounds damn good.
"Now two flags fly above my land that really sum up how I feel One is the colors that fly high and proud The red, the white, the blue The other ones got a rattlesnake with a simple statement made "Don't tread on me" is what it says and I'll take that to my grave"
BTCM46
TWACCM113
JOSH 5.7 is offline
The Following 2 Users Say Thank You to JOSH 5.7 For This Useful Post:
post #10 of 11 (permalink) Old 02-12-2013, 11:26 AM
i got a 4.6 and i got some flowmaster 40/40s on there (dude at the shop said it was the best for the truck) he dumped the exhaust right before the axle....its super quiet i want it to sound MEAN!! how can i go about this? gutting the cat i always thought it will fuk with smog so i never mess with it
bodio is offline
The Following 2 Users Say Thank You to bodio For This Useful Post:
post #11 of 11 (permalink) Old 02-12-2013, 06:17 PM
Quoted: 13 Post(s)
I went with a single VX (knockoff flowmaster 10 series) after reading about how quiet our trucks are. So glad I didn't do the 40 series, the 10 sounds great and isn't too loud. I get at least 1 compliment on my exhaust every week on my job sites since putting it on. My motor is all stock right now except the HC filter has been removed. All exhaust plumbing is stock.
2012 DC 5.7 4x2 pyrite mica, rescued on 9-5-12
Current Mods: Too many to list!
toyot@tundr@ is offline
The Following 2 Users Say Thank You to toyot@tundr@ For This Useful Post:
