Arizona: 4.88 4X4 + LSD = $2300 INSTALLED!! - TundraTalk.net - Toyota Tundra Discussion Forum
Old 01-14-2013, 12:15 PM   #1 (permalink)
So ive been shopping around, ALOT!!!
Found CM Performance wasnt the cheapest.
I found a local Arizona Nitro Dealer, that also performs installations.
480-797-0469 – Andrew / Untitled Document
Fr Master Kit
Rr Master Kit
4.88 Front/Rear Nitro Gears
Detroit TrueTrac LSD
Roughly to be around $1600.00 + $600 installation
PARTS ON ORDER!
eightyhd is offline   Reply With Quote
The Following 2 Users Say Thank You to eightyhd For This Useful Post:
EBTundra (01-18-2013), Ogtoyfan (01-21-2013)
Old 01-14-2013, 12:27 PM   #2 (permalink)
Report back on how the install goes.
Total chaos long travel, Fox shox, Deaver leafs
XD Addict 18" w/35" Toyo open country 4.88 gear Auburn LSD,Nfab RSP front bumper w/ 480 watts of LED Custom rear bumper, Fiberwerx fenders, McNeil trophy truck bedsides
AVIC z130bt head unit,Polk Audio 5ch amp
Polk Audio 6" components, Polk Audio 6" coaxial
Polk Audio 10" sub, Two layers dynamat throughout
Katzkin
Custom headliner
BHLM PD'd grille Matte White wrap, Coachbuilder1 Roof rack w/4 10" LED's
White knuckle off road sliders
VOTE NOW!
April TOTM Contest - From Dusk Till Dawn!
Sponsored by:
SaltRiverLED.com
Winner will receive a 20" Light Bar from SaltRiverLED.com!
wingnut537 is offline   Reply With Quote
The Following User Says Thank You to wingnut537 For This Useful Post:
Old 01-14-2013, 12:34 PM   #3 (permalink)
absolutely will!
Going to pay today and possibly install it by Friday
07 Crewmax 4X4
35" Toyo Open Country MT
The Following User Says Thank You to eightyhd For This Useful Post:
Old 01-14-2013, 12:37 PM   #4 (permalink)
JCv2.0's Avatar
Gameroom cash: $2213428
Pricey
The Following User Says Thank You to JCv2.0 For This Useful Post:
Old 01-18-2013, 08:19 AM   #5 (permalink)
cheap i got 1950 in parts.....not including the install that the flat rate book shows 13 hrs
Shenegar is offline   Reply With Quote
The Following User Says Thank You to Shenegar For This Useful Post:
Old 01-21-2013, 07:44 PM   #6 (permalink)
aanolo's Avatar
what is the purpose of the auburn lsd and the 4.88 gears? would i need them if i put 24s on my truck?
2010 Platinum CrewMax Black
5.7L V8 4x4 FlexFuel
AMP Power Running Boards
3/1 Daystar Leveling Kit
KMC Skitch 22s
Yokohama Parada Spec X tires
Corsa Sport Exhaust
Rhino Spray on Liner
LazerLite Tonneau Cover
Remote Start
All windows 5% Tint, Windshield 35%
aanolo is offline   Reply With Quote
The Following User Says Thank You to aanolo For This Useful Post:
Old 01-21-2013, 08:07 PM   #7 (permalink)
Are you lifted? really don't need that much traction in az...
tundrakountry is offline   Reply With Quote
Old 01-21-2013, 09:39 PM   #8 (permalink)
aanolo's Avatar
[QUOTE=tundrakountry;986179]Are you lifted? really don't need that much traction in az...[/QUOTE
im living in utah right now and i have a 3/1 leveling kit.. the auburn and 4.88s have been on my mind but i dont know what the purpose they serve or if they are worth me putting on my truck.
KMC Skitch 22s
Corsa Sport Exhaust
Remote Start
Old 01-21-2013, 10:15 PM   #9 (permalink)
You really won't benefit from the 4:88s unless you are running 35"-37" tires as they are to lower gear ratio to compensate for the larger diameter tires...that's is unless you are looking for more bottom end for something like drag racing then you may want them but as a daily driver your mileage will suffer withbthe smaller tires and low gears....the auburn posi is for just that reason...a mechanical posi traction unit to make your truck hook up better and put power to ground...unlike our electronic controlled stuff that is good but not great... Hope this helps but don't waste your money unless you have the lift and big tires....only reason I did it is I want taller tires and even though this truck is a beast...I know I will not be happy with the power or mileage when I go bigger on tires.....just as an example I had a chevy HD 2500 6.0 and no matter how I drove or what I towed, highway or city, I got 13.5 mpg.....lifted and 325/60-20s and put in 4.88s, stock were 4.10s, and truck felt like it pulled and ran better and actually went up to 14.5mpg....not a huge mileage improvement but keeping all my power to tow car trailers etc was worth it....but I will say it was less than 1000$ installed on the chevy.....gotta pay the tundra tax I guess lol...
Old 01-22-2013, 01:32 AM   #10 (permalink)
The Tundra tax makes it a tough sell. I regeared my old Wrangler with Yukon gears for around $800 with Timken master install kits. I keep wanting to regear my truck but even if I were to gain 2 mpg and driving 30k/ year it would take forever to break even on $2k. I guess in fairness that would be adding Auburn too though because I couldn't resist if I were doing it.
Shenegar are you installing your own gears? You have a shop in Bluefield right?
2012 CM TRD 5.7 Pyrite Mica
Zone 5" + Shims, Coach Builder's 3" Shackles, Ballistic Wizard 18x9 +14mm, 295/70r18 Trail Grappler
K&N CAI, Magnaflow Performance Exhaust P/N 16485, LED Interior Lights
Stubby Antenna, Nfabs, Floor Liners, Towing Mirrors, Python 574 Remote Start, TPMS Bypass Mod
Build Log
bigbair2002 is offline   Reply With Quote
Old 01-22-2013, 01:34 AM   #11 (permalink)
aanolo's Avatar
Shenegar thnks for taking time to explain!
KMC Skitch 22s
Corsa Sport Exhaust
Remote Start
Old 01-22-2013, 07:35 AM   #12 (permalink)
They will install at shop here in bluefield.....not my shop but I manage it for them lol
Old 01-27-2013, 12:30 PM   #13 (permalink)
let us know how it goes! Just finished up my LT and am working on my front and rear bumpers right now...this is next on my install list along with a SC.
'08 Limited CM 4x4 - Camburg Long Travel w/ Fox Coilovers, Deaver 11-Leaf Pack w/ Fox Piggyback Shocks, 17x9 KMC Enduro w/ BFG A/T 315/70, McNeil Fiberglass Front Fenders.
In progress - custom built (by me) front and rear bumpers
de oppresso liber
ries is offline   Reply With Quote
