AEM Tuned S/C Tundra - TundraTalk.net - Toyota Tundra Discussion Forum
Old 12-27-2012, 07:19 PM   #1 (permalink)
TRD_Tundra's Avatar
Talking AEM Tuned S/C Tundra
AEM Piggyback finally arrived and had an appointment today with SSA Racing Technologies (Secret Services)
Wired the piggyback while I waited there and it had no maps pre-loaded so it took like 20 dyno pulls to get it right, It's not running lean no more but it's not running at it's full potential. Based on the A/F graphs there's no way to control the fuel after a long WOT pull(according to my tuner at 4900+RPM), the Factory ECU kept taking over but it didn't lean it out it goes rich in to 10.1-10.3 .... But it's better than the previous 13.6!
I got a couple of videos of the Dyno pulls.
On a Mustang Dyno the final power was
461rwhp
470tq
Also got it weighted and it's full weight with no passengers was 5721lbs, let's see if it can move now.
http://www.youtube.com/watch?feature...&v=zLzw9uTK5DM
Yes it's a mess, I'll try to make it look pretty later on.
2011 FFV Tundra Limited: SuperCharged (TRD Forged 22"s, Lucchese, ASP pulley, Valve Body, DT Long Tubes, TRD Swaybar, Deleted all cats, AEM F/IC-8 Tuned, Dual e-cutouts)
2006 Silverado 5.3 (76mm Turbo,Cam 216/220, AEM TruBoost, AEM Wideband, Built 4l80e, Dual springs, Bosch 60# injectors, Aeromotive 340, AEM Meth injection... Boost is at 12psi on meth) Tuned by TELLEZ
TRD_Tundra is offline   Reply With Quote
The Following 12 Users Say Thank You to TRD_Tundra For This Useful Post:
BRX (12-27-2012), dirtydeeds (01-04-2013), jbroas (12-27-2012), Mfour (12-27-2012), Mr. Creosote (12-27-2012), Powertechn2 (12-27-2012), RedBullistic (01-06-2013), Rut (12-27-2012), shotgun (12-28-2012), Supercharged (12-27-2012), texas boy (12-27-2012), wacked (12-28-2012)
Old 12-27-2012, 07:32 PM   #2 (permalink)
Mfour's Avatar
the AEM is one cool system, I had it on my drag car before I upgraded to the Big Stuff 3. The AEM has a lot of very cool features for boost. It also has a 2 step for drag racing that is easy to use. I would log a run and look for any knock it should read .1-.5v through out the prm range. Where you see a little just add some fuel to that square area.
2011 DC SR5 5.7
Mfour is offline   Reply With Quote
The Following 3 Users Say Thank You to Mfour For This Useful Post:
BRX (12-27-2012), Mr. Creosote (12-27-2012), wacked (12-28-2012)
Old 12-27-2012, 07:52 PM   #3 (permalink)
Supercharged's Avatar
Wow. Looks like you tuner knows what's he is doing. Good to see that Chris's piggy back system works as advertised. Puts all the companies that tried to shame.
Great pic of the Tundra shooting flames!!
First 11 Second Tundra
Best 1/4 mile time: 11.940 @ 113.19 mph
1.66 second 60' time.
http://www.youtube.com/watch?v=Bb9MNYFwUFA
12.034 @ 113mph
http://www.jdmtube.com/video/657/Toy...PH-PBIR-Moroso
12.1 @ 112mph. Tundra vs 600hp Challenger
http://www.youtube.com/watch?v=Fa8JI...e_gdata_player
Supercharged is online now   Reply With Quote
The Following 6 Users Say Thank You to Supercharged For This Useful Post:
BRX (12-27-2012), dirtydeeds (01-04-2013), Mr. Creosote (12-27-2012), RedBullistic (01-06-2013), sanchez (01-05-2013), wacked (12-28-2012)
Old 12-27-2012, 08:04 PM   #4 (permalink)
HELL YEEAAHH!
texasranger96 is offline   Reply With Quote
The Following 4 Users Say Thank You to texasranger96 For This Useful Post:
BRX (12-27-2012), dirtydeeds (01-04-2013), Mr. Creosote (12-27-2012), wacked (12-28-2012)
Old 12-27-2012, 08:19 PM   #5 (permalink)
TRD_Tundra's Avatar
Video is almost done uploading, 2.6GB of Full HD. I'll update the 1st post with the link whenever it's done. I'm impressed with the numbers, if it was on a Dynojet that's and easy 515rwhp+/-
*Ended up uploading a compressed video(other one was taking for ever)*
The Following 5 Users Say Thank You to TRD_Tundra For This Useful Post:
BRX (12-27-2012), Mr. Creosote (12-27-2012), Powertechn2 (12-27-2012), RedBullistic (01-06-2013), wacked (12-28-2012)
Old 12-27-2012, 09:06 PM   #6 (permalink)
BRX
BRX's Avatar
Your progress in the last couple of months is simply amazing! From an N/A flex fuel Tundra to a fire breathing Supercharged Tundra in no time!
Now I can't wait for my truck to be dyno tuned with more boost. Which reminds me, why not install the other ASP pulleys now that you can adjust the A/F ratio? This beast is gonna haul some real ass
Couple of questions, you removed the unichip didn't you? if so, is gear shifting smooth like stock or does it act weird when shifting sometimes? Because I think the TRD flash reprograms everything from A/F ratio to gear shifting unlike the unichip or the AEM for that matter. In case you have that problem, just get a new or used ECU, change the vin #, flash the TRD tune on it and plug it in so that it won't shift as bad.
'07 2WD RCSB 5.7L Tundra
TRD SC, ASP SC Pulley, Spoolin Shift Kit, AIRAID Intake, Hayden Transmission Cooler 1679, Ranger Fan Kit
Doug Thorley Long Tube Headers, True-Dual BAMufflers, Deleted Rear Cats
TRD Sway Bar, Tundra Racing Lowering Kit, Caltracs Drag Profile Traction Bars
TRD Forged 22" Wheels, Toyo Proxes ST II
Key-colored Door Handles & Mirror Caps
Alpine INA-W910 W/ Back-up Camera
White Gauges & A/C Control LEDs
11.866 @ 116.61 MPH Video
Youtube Channel
BRX is online now   Reply With Quote
The Following 4 Users Say Thank You to BRX For This Useful Post:
Mr. Creosote (12-27-2012), RedBullistic (01-06-2013), TRD_Tundra (01-03-2013), wacked (12-28-2012)
Old 12-27-2012, 09:13 PM   #7 (permalink)
TRD_Tundra's Avatar
Thanks, It shifts better than the unichip since it doesn't bounce off the rev limiter but it still has a little lag. But much better tho. I'm also thinking of adding the waterpump and crank pulley
My tuner had crazy Ideas because he's had previous Tundra's with unichip and they'll just go back to normal after 2-3 runs. He was thinking a full standalone with twin 68mm's with the S/C and re-doing everything even on the tranny with a Pro 128 ECU, very tempting!
The Following 3 Users Say Thank You to TRD_Tundra For This Useful Post:
Mr. Creosote (12-27-2012), RedBullistic (01-06-2013), wacked (12-28-2012)
Old 12-27-2012, 09:41 PM   #8 (permalink)
BRX
BRX's Avatar
Easy now, you just got that AEM tuned for $800
Maybe just an ECU for the transmission like that 1st gen 5.7l turbo tundra. It should cost less than a whole new standalone for both the engine and trans...
Youtube Channel
The Following 2 Users Say Thank You to BRX For This Useful Post:
Old 12-27-2012, 09:44 PM   #9 (permalink)
TRD_Tundra's Avatar
Any more info on that tranny setup?
The Following 2 Users Say Thank You to TRD_Tundra For This Useful Post:
Old 12-27-2012, 09:48 PM   #10 (permalink)
Make sure to get as much weight off your truck when you go hit the track. 5700 lbs is a lot.
You make me want to dyno my truck so bad, I wanna breathe fire too!!
12.034 @ 113mph
The Following 3 Users Say Thank You to Supercharged For This Useful Post:
Old 12-27-2012, 09:52 PM   #11 (permalink)
TRD_Tundra's Avatar
Take it, I'm sure you'll break 500 easy
Prolly just the rear seats if I feel like taking the off
They did like 20 dyno pulls mine but only recorded like six.
I also got the 18" stocks and just bought M/T ET Street Radials 305/45/R18
I need some Caltracs ASAP! Truck hops insane from a dig
Old 12-27-2012, 10:16 PM   #12 (permalink)
^pm sent...btw, impressive numbers. I'm sure 500rwhp is inevitable at this point!
2007 5.7L DC SR5 2WD TRD OFFROAD blue streak
*Volant CAI*OBX LT headers, DT mid-pipe, rear cat delete*Flowmaster 50 Series muffler w/H-pipe​*Nfabs*Pioneer Avic Z-140*Stubby antenna*Color matched door handles, mirror covers, tailgate handle*20% tint*Line-X*5k HID kit*20" Limited rims*Platinum grill*Cooper Zeons LTZ 275/60/20*Tinted taillights & 3rd brake light*TRD swaybar*Tundra Racing 3.25" rear drop kit*Custom devil horns*Caltrak traction bars*
texas boy is offline   Reply With Quote
The Following 3 Users Say Thank You to texas boy For This Useful Post:
Old 12-27-2012, 10:40 PM   #13 (permalink)
You should re dyno the truck now that the tune is done. 20 pulls had to create lots of heat soak which probably resulted in less HP. Either way great results.
12.034 @ 113mph
Mr. Creosote (12-28-2012), RedBullistic (01-06-2013), wacked (12-28-2012)
Old 12-27-2012, 10:56 PM   #14 (permalink)
TRD_Tundra's Avatar
Its a Mustang dyno they usually read 12% less than any other dyno... I think
Old 12-27-2012, 11:01 PM   #15 (permalink)
TRD_Tundra's Avatar
* Updated 1st post with the video *
Mr. Creosote (12-28-2012), wacked (12-28-2012)
