Tundra cooling fan possibilities! - Page 17 - TundraTalk.net - Toyota Tundra Discussion Forum
Old 11-06-2012, 03:36 PM   #241 (permalink)
Originally Posted by texasranger96 View Post
Yeah when I look for it all I find is the clear version, I know what you are talking about I have a glock 17. I think I found something that is very rigid and is used on alot of car parts already and priced very well, black phenolic.
gm makes brake calipers with phenolic pistons, it holds up to that LOL
'12 Rock Warrior Crewmax
magnaflow / 2" leveling kit / airlift loadlifter 5k / afE pro dry s / XSP LED DRL's
j_fuggin_t is offline   Reply With Quote
The Following 3 Users Say Thank You to j_fuggin_t For This Useful Post:
Mr. Creosote (11-06-2012), Ogtoyfan (11-25-2012), wacked (11-06-2012)
Old 11-08-2012, 11:05 AM   #242 (permalink)
Here is the thing, yesterday I spent about two hours with the company that will cut these out for me, because we decided that ABS will not handle the heat, so we are researching trying to find the correct plastic to handle the heat and be rigid enough so it won't flex with the fans. At the moment I am building a kit for a guy that ordered one and I have already ordered the variable controller, the fans and everything else I need. My patern is with the company with all the specs just waiting for the correct material, but I have time due to the fact that the controller takes a week or two to get built. If I cannot find the correct plastic I can always revert back to the aluminum as it is rigid enough and will handle the heat, these kits are ready for sale as I am pretty buch custom building them anyhow, I prefer to talk business on the phone.
660-441-4054
Thanks.
2008 CrewMax 5.7, TRD, Supercharger, Dual exhaust, 12" lift with coilovers, 38" Toyo M/Ts, Procomp rims, carrier bearing bracket, Backflip F1, Hypertech calibrator, Bushwacker flares, 4.88 gears, Auburn LSD, Total Caos UCAs w/heims, Readylift Heavy Duty Steering kit, Rangers electric fan kit
My other cars:
2007 Chrysler 300C SRT8-AFE, Zoomers, Diablo
2004 Mustang Cobra-560 rwhp/510 rwtq
1992 Corvette ZR-1-SLP, Magnaflow, chipped
1967 Camaro RS-327/4spd
1957 Chevy BelAir-350/4spd
WikedTundra is offline   Reply With Quote
The Following 3 Users Say Thank You to WikedTundra For This Useful Post:
Mr. Creosote (11-08-2012), Ogtoyfan (11-25-2012), wacked (11-08-2012)
Old 11-11-2012, 01:48 AM   #243 (permalink)
I'll post to subscribe and express my interest. It might be a little while until I have the extra $$ to do this, but I will follow this thread along until I can buy.
WVTundra2012 is offline   Reply With Quote
The Following 3 Users Say Thank You to WVTundra2012 For This Useful Post:
Mr. Creosote (11-11-2012), Ogtoyfan (11-25-2012), wacked (11-11-2012)
Old 11-11-2012, 04:50 AM   #244 (permalink)
I am getting anxious to get my parts so I can put it together and test it on my truck with the new mounting plate and variable controller.
texasranger96 is online now   Reply With Quote
The Following 3 Users Say Thank You to texasranger96 For This Useful Post:
Old 11-16-2012, 01:47 PM   #245 (permalink)
Upgrades in work, will post next week!
Mr. Creosote (11-16-2012), Ogtoyfan (11-25-2012), wacked (11-16-2012)
Old 11-22-2012, 10:01 PM   #246 (permalink)
So here is the updates I promised, I have spent about two keeks getting drawings made for programs to be produced so that the mounting plates could be cut out on a CNC plasma for more quality and precision. I currently have enough to do five kits not including the parts, I have also went to the DC controls PWM controller that variably controls the fans according to the engine temps. Something else that I am very happy about is the parts are now beeing powder coated with a textured black paint that is very similar to the under hood parts.
I currently have an updated kit installed on my Tundra that is working very well with no problems, the new kits do not require the upper hose to be cut due to the probe that just pushes into the radiator fins and only rquire two wires to be hooked up power and ground. The controller has wires that can be hooked up for fan operation with the A/C on and wires so the fan can be turned off for low water crossing. I am asking in the $5-600.00 range for the kits not including shipping. Here is some new pics with directions, Thankyou for beeing so supportive!
Here is what is included in the kit, fan assembly prewired, extra wiring for optional A/C and manual control, and new bolts for clutch fan delete!
1.The first step is to disconnect ground from battery and driverside fender.
2. Remove engine cover as it well help to have it out of the way.
3. Remove fuse cover and disconnect power wire using a 10mm and then with a small flat head insert into tabs to slide power wire up along with plastic cover and then remove the cover as it will not be needed.
4. Remove lower engine cover with ratchet and extension, 3 10mm in front and 2 12mm in front and 3 12mm in back, ounce removed the cover will held on by two hooks in front so slide them to driverside and lower.
5. Locate the drain cock on the bottom of radiator and drain about half a gallon of coolant into a clean container as it will be reused later. Note: this will make it possible to remove upper radiator hose and the cap can be taken off to increase flow ounce a little of the pressure has been relieved via hose.
6. Remove upper hose to gain access to radiator area and to remove shroud.
7. Locate clutch fan bolts and remove the nuts by holding one bolt with wrench to keep the pulley from spinning while loosening another. Note: The nuts will come off but not the studs, the studs will have to be accessed ounce the shroud and clutch fan is removed, the studs have to be removed to install the new bolts, by tightening two nuts together on each stud efectively creating a way to remove studs with ratchet.
8. Disconnect overflow hose from radiator near cap, and unfasten hose clamp from transmission hoses from passenger side shroud using a long slender flat head screwdriver and move hoses out of way for reoval of shroud.
9. Remove the two screws holding the shroud at the top, and remove both the shroud and clutch fan together, taking care not to damage radiator fins and spilling the coolant out of shroud overflow tank.
10. At this time you may remove clutch fan studs and install new bolts per vehicle torque specs.
11. Now install the new electric cooling fan assembly and take care not to damage radiator fins. Note the lower radiator hose will make diffcult to slide into place but it will fit, now install bolts per vehicle torque specs.
12. Locate a clean rag and some alcahol and clean raditor hose and water necks contact points of coolant as there is a possibilty of leaking, and then install factory radiator hose with there spring clamps.
13. Locate factory shroud/overflowtank and drain the remainder coolant into the clean container for reuse and remove hose and reinstall onto new overflow tank.
14. Run the two wires for power and ground from the cooling fan kit to driver side fender, using a zip tie and a the supplied wire clamp to left cooling fan bolt, and then attaching black ground to the driverside fender grounding point and the power wire to fuse box power lug and tighten all hardware to vehicle torque specs.
15. Reinstall negative batter cable to factory torque specs and reinstall fuse over.
16. Gain access to the black sensor wire behind lower cooling fan rubber relief valve and insall end into a cooling fin, at this time you may reinstall lower engine cover and remove all tools from engine caompartment making sure to refill radiator and coolant tank with the used coolant.
17. Drive and test the operation of the fans as it is set for a 180* theremostat and can adjusted via side screw, read directions for fan controller carefully!
If there is any questions regarding the kit contact me at 660-441-3569, I will include the shipping container for the fan controller and directions. If there is any questions regarding the controller the manufacturers contact info is in there as well, save the electric fan controller box for warranty issues!
The Following 7 Users Say Thank You to texasranger96 For This Useful Post:
BRX (11-23-2012), jbroas (11-23-2012), Mr. Creosote (11-22-2012), NordicMist (12-08-2012), Ogtoyfan (11-25-2012), Vettelover84 (11-22-2012), wacked (11-22-2012)
Old 11-22-2012, 10:12 PM   #247 (permalink)
wacked's Avatar
Looking good dude!
Born in TEXAS built by TEXANS
aFe Stage II Pro-S Dry Si
wacked is offline   Reply With Quote
The Following 3 Users Say Thank You to wacked For This Useful Post:
Mr. Creosote (11-22-2012), Ogtoyfan (11-25-2012), Vettelover84 (11-22-2012)
Old 11-23-2012, 12:07 AM   #248 (permalink)
Yeah man you wouldn't believe the crap that I have went through to make it this point I am very happy how it has turned out, it was really nice driving it earlier with the new PWM controller very quiet as it only requests the required fan speed for the given temp, thanks for the compliment!
The Following 4 Users Say Thank You to texasranger96 For This Useful Post:
Mr. Creosote (11-23-2012), Ogtoyfan (11-25-2012), Vettelover84 (11-23-2012), wacked (11-23-2012)
Old 11-23-2012, 01:29 AM   #249 (permalink)
BRX
BRX's Avatar
wow! someone is gonna be very happy with this one
How hard would it be to switch from the dakota to the PWM controller? I love the idea of having variable fan speeds.
'07 2WD RCSB 5.7L Tundra
TRD SC, ASP SC Pulley, Spoolin Shift Kit, AIRAID Intake, Hayden Transmission Cooler 1679, Ranger Fan Kit
Doug Thorley Long Tube Headers, True-Dual BAMufflers, Deleted Rear Cats
TRD Sway Bar, Tundra Racing Lowering Kit, Caltracs Drag Profile Traction Bars
TRD Forged 22" Wheels, Toyo Proxes ST II
Key-colored Door Handles & Mirror Caps
Alpine INA-W910 W/ Back-up Camera
White Gauges & A/C Control LEDs
11.866 @ 116.61 MPH Video
Youtube Channel
BRX is online now   Reply With Quote
The Following 4 Users Say Thank You to BRX For This Useful Post:
Old 11-23-2012, 01:54 AM   #250 (permalink)
Not hard at all!
Old 11-25-2012, 05:39 AM   #251 (permalink)
Vettelover84's Avatar
I am SOLD.... The wife's shiny stuff is on order too... Need to distract her a bit..
2010 Tundra CrewMax 5.7L V8 4x2 4.5/5 Drop.. TexasRanger96 Electric fan Kit
"Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!"
Vettelover84 is offline   Reply With Quote
The Following 3 Users Say Thank You to Vettelover84 For This Useful Post:
Mr. Creosote (11-25-2012), Ogtoyfan (11-25-2012), wacked (11-25-2012)
Old 11-25-2012, 09:08 AM   #252 (permalink)
I really appreciate your business I will get the stuff on order immediately, I just don't understand why there is no shipping lablel on paypal, someone help me please.
Old 11-25-2012, 10:38 AM   #253 (permalink)
Looking forward to the install!! I think it due to the payment method...
Old 11-25-2012, 01:19 PM   #254 (permalink)
I think you are correct, that's ok I have an account with UPS, it will be the same price. Ounce I can make some money at this I have other projects in mind for the truck.
The Following 2 Users Say Thank You to texasranger96 For This Useful Post:
Mr. Creosote (11-25-2012), Vettelover84 (11-26-2012)
Old 11-25-2012, 03:17 PM   #255 (permalink)
wacked's Avatar
I sure wish I could do this right now, getting ready to change the water pump and serpentine belt and have too many other big ticket expenses getting ready to hit
The Following User Says Thank You to wacked For This Useful Post:
