ASP Pulleys - TundraTalk.net - Toyota Tundra Discussion Forum
Old 06-28-2012, 05:08 PM   #1 (permalink)
BRX
BRX's Avatar
ASP Pulleys
As some of you already know, I ordered a smaller SC pulley from ASP Racing. I was going to make the same setup as Supercharged did (Bigger Crank pulley and smaller Water Pump pulley). But he told me to get the SC pulley instead, because its cheaper, easier to install, and most importantly, give the same amount of boost as the other two pulleys together.
I will probably get the other two eventually if Spoolin gets his tuning setup working on our trucks or just another stand alone ECU.
The SC pulley was shipped two days ago and should be at my apartment by Monday. I know a great guy who has a shop that would do the installation for $50. The problem is, he won't be in town for two weeks. And I don't know if I could wait for that long .
One more thing, if the Pulley is smaller I assume the belt should get shorter as well. Any suggestions on how to find the right size?
Thanks guys!
Sent from my Galaxy Nexus using AutoGuide.Com Free App
'07 2WD RCSB 5.7L Tundra
TRD SC, ASP SC Pulley, Spoolin Shift Kit, AIRAID Intake, Hayden Transmission Cooler 1679, Ranger Fan Kit
Doug Thorley Long Tube Headers, True-Dual BAMufflers, Deleted Rear Cats
TRD Sway Bar, Tundra Racing Lowering Kit, Caltracs Drag Profile Traction Bars
TRD Forged 22" Wheels, Toyo Proxes ST II
Key-colored Door Handles & Mirror Caps
Alpine INA-W910 W/ Back-up Camera
White Gauges & A/C Control LEDs
11.866 @ 116.61 MPH Video
Youtube Channel
BRX is online now   Reply With Quote
The Following 3 Users Say Thank You to BRX For This Useful Post:
Mr. Creosote (06-28-2012), Powertechn2 (10-25-2012), RedBullistic (06-29-2012)
Old 06-28-2012, 09:12 PM   #2 (permalink)
Supercharged's Avatar
BRX good luck with the smaller pulley. Make sure to have a wideband AFR before you install the pulley. I think you are the first to try the sc pulley. The belt tensioner should allow for the smaller pulley without changing the belt. Make sure whoever takes the pulleys of the supercharger knows what they are doing.
First 11 Second Tundra
Best 1/4 mile time: 11.940 @ 113.19 mph
1.66 second 60' time.
http://www.youtube.com/watch?v=Bb9MNYFwUFA
12.034 @ 113mph
http://www.jdmtube.com/video/657/Toy...PH-PBIR-Moroso
12.1 @ 112mph. Tundra vs 600hp Challenger
http://www.youtube.com/watch?v=Fa8JI...e_gdata_player
Supercharged is offline   Reply With Quote
The Following 4 Users Say Thank You to Supercharged For This Useful Post:
BRX (06-29-2012), Mr. Creosote (06-29-2012), Powertechn2 (10-25-2012), RedBullistic (06-29-2012)
Old 06-29-2012, 11:20 AM   #3 (permalink)
I'm posting this as a heads-up, not as a slam to ASP. Keep an eye on the pulley. I had an ASP UDP that separated from the center hub. I don't know what caused it, but it happened. ASP makes a good pulley and I've never heard of it happening to anyone else. All I'm saying is to keep an eye on it. If for some reason you do have issues with it, Powerbond makes a one-piece pulley for the Silverado's...not sure if they make them for Toyota or not.
Moze is offline   Reply With Quote
The Following 5 Users Say Thank You to Moze For This Useful Post:
BRX (06-30-2012), Mr. Creosote (06-29-2012), Powertechn2 (10-25-2012), RedBullistic (06-29-2012), Rut (06-29-2012)
Old 06-29-2012, 01:31 PM   #4 (permalink)
RIjon's Avatar
You could also contact March, they will make anything you want.
2008 Tundra 5.7L RCSB 2wd Supercharged, IPT Valvebody, Auburn, Sequoia sway bar, ect.
Needs new tires....
Custom switch panels & emblems
www.gaugeplates.com
Si vis pacem, para bellum
RIjon is offline   Reply With Quote
The Following 5 Users Say Thank You to RIjon For This Useful Post:
Old 06-29-2012, 02:16 PM   #5 (permalink)
The water pump pulley I got from ASP is solid work. I think they are the only company producing pulleys for the SC Tundras. If there is ever a tune for our trucks then more companies will start producing them also.
12.034 @ 113mph
The Following 5 Users Say Thank You to Supercharged For This Useful Post:
Old 06-29-2012, 06:04 PM   #6 (permalink)
Whats the cost for the S/C pulley? I looked on their website and didn't see one. How much extra boost? (maybe 2 pounds) How much of a difference does this make in power?
Thanks.
2008 CrewMax 5.7, TRD, Supercharger, Dual exhaust, 12" lift with coilovers, 38" Toyo M/Ts, Procomp rims, carrier bearing bracket, Backflip F1, Hypertech calibrator, Bushwacker flares, 4.88 gears, Auburn LSD, Total Caos UCAs w/heims, Readylift Heavy Duty Steering kit, Rangers electric fan kit
My other cars:
2007 Chrysler 300C SRT8-AFE, Zoomers, Diablo
2004 Mustang Cobra-560 rwhp/510 rwtq
1992 Corvette ZR-1-SLP, Magnaflow, chipped
1967 Camaro RS-327/4spd
1957 Chevy BelAir-350/4spd
WikedTundra is offline   Reply With Quote
The Following 3 Users Say Thank You to WikedTundra For This Useful Post:
Old 06-29-2012, 06:30 PM   #7 (permalink)
BRX
BRX's Avatar
The SC pulley will hopefully add 2 psi (~50 hp) and cost $160 including shipping. The other two are about $360 if I remember correctly and add the same amount of power. There is a formula that you can find online that shows how to convert psi's to horsepower.
Youtube Channel
The Following 4 Users Say Thank You to BRX For This Useful Post:
Bati (08-12-2012), Mr. Creosote (06-29-2012), Powertechn2 (10-25-2012), Rut (06-29-2012)
Old 06-30-2012, 11:16 AM   #8 (permalink)
Is the factory computer able to compensate for the added boost since we can't tune the trucks yet? Also, does the pulley just come off with a pulley puller or is it more involved. I've changed the pulley on my Cobra many times and that was very easy.
My other cars:
The Following 2 Users Say Thank You to WikedTundra For This Useful Post:
Mr. Creosote (06-30-2012), Powertechn2 (10-25-2012)
Old 06-30-2012, 12:35 PM   #9 (permalink)
Thanks guys!
I could see doing the larger lower crank pulley on our trucks as a way of increasing the boost but the drawback there is that everything is going to be spinning faster minus the water pump if you also purchase the larger pulley that they sell for that.
With regards to the supercharger pulley, its already so small that the belt contact surface is so little that going any smaller could result in major belt slippage. Plus the fact that getting the blower pulley off safely requires a puller that contacts the entire pulley and thats just not possible with the current size and location of the factory pulley.
A smaller blower pulley looks like its also going to require some grinding of the blower snout to obtain the clearence needed.
Ive been installing blower pulleys for the past 15yrs and have just about every puller imaginable but havent found even one that would work safely on our blowers without removing it, and even then its risky because of the tight working area around the pulley. So if your guy said that he could do it fo 50 bucks I say go for it ! I would also like to know what kind of puller he used and your before and after boost readings. Keep us informed on your progress!
DHentz is offline   Reply With Quote
The Following 4 Users Say Thank You to DHentz For This Useful Post:
Mr. Creosote (06-30-2012), Powertechn2 (10-25-2012), shotgun (06-30-2012), socal57chevy (08-02-2012)
Old 06-30-2012, 01:03 PM   #10 (permalink)
BRX
BRX's Avatar
He's been custom building +1000 HP vehicles for the last 30 years. 3 of my close friends have their engines built by him and their solid work. He also has done superchargers, turbos and pro chargers. That's why I'm willing to wait two weeks just to get the job done by him and no one else. And about the $50, that's what he charges for an hour. Since I'm new to all of this I thought a pulley change (specially since its right out there) wouldn't require that long to install . Seems like I need to save a little more money for the installation
Thanks for all the info guys!
Youtube Channel
The Following User Says Thank You to BRX For This Useful Post:
Old 06-30-2012, 05:05 PM   #11 (permalink)
RIjon's Avatar
I can see what Dhentz is sayin. There is not a lot of room to work with around the snout.
I will also be curious as to if he needs to remove material on the snout for the smaller pulley.....It's tight.
Belt slip would be my major concern. I get a some slip now, and I have tried every belt there is.
At what point does this blower become a heat pump?
We have to be towards the upper end of performance level (efficiency) for this CI charger. The Vettes went to the 2300 series. Anyone have a map?
Needs new tires....
www.gaugeplates.com
The Following 2 Users Say Thank You to RIjon For This Useful Post:
Old 06-30-2012, 05:06 PM   #12 (permalink)
RIjon's Avatar
Needs new tires....
www.gaugeplates.com
Old 06-30-2012, 05:58 PM   #13 (permalink)
Jowett Engineering HD Tundra Parts
Your Tundra Tech Advisor
All wheel drive conversions
2008 Tundra DC
All wheel drive Land Cruiser T-case
TRD Supercharger
King IBP Internal Bypass Shocks
37" Yokohama M/T+
Hutchinson Rock Monster dual beadlock Wheels
Lexus IS paddle shift
bjowett is offline   Reply With Quote
The Following 2 Users Say Thank You to bjowett For This Useful Post:
Mr. Creosote (06-30-2012), TundraStruk (11-07-2012)
Old 06-30-2012, 06:29 PM   #14 (permalink)
RIjon's Avatar
So the sweet spot on the 1900 has the blower speed between 7500-10,500ish, is 76%, and has a Pressure ratio of 1.55 to 1.65. That's what....8-10psi ?
Looks like you can up the boost on this 1900 and do well as long as the RPM stays in check. Obviously, the air pump is only as efficient as the supporting components.
Good reading and reference.
Corvette Action Center | Model Center | C6 | 2009 ZR1 | Ultra-Gearhead Blower Briefing
Boost or Pressure Ratio
When most people discuss superchargers, they talk about boost which is the difference between atmospheric and manifold absolute pressure (MAP). For example: if sea level pressure on a standard day is 14.69 psi and the MAP inside the engine of your '09 ZR1 is 25.15 psi, then the blower boost is 10.5 psi.
The problem with "boost" is that, while it's useful in marketing superchargers, for bragging rights and does offer a simple way to quantify a blower's performance, a more accurate benchmark, and the way most supercharger engineers quantify efficiency, is "pressure ratio" which is a measure not skewed by atmospheric conditions or mechanical constraints in the system such as intake restriction.
Needs new tires....
www.gaugeplates.com
The Following User Says Thank You to RIjon For This Useful Post:
Old 06-30-2012, 06:39 PM   #15 (permalink)
Im sure that he does great work. I wasnt doubting that. I was just wondering what kind of a puller he was going to use to get it off safely and the new one on?
I cant see any of the standard pullers being used other than making a custom one up.
Plus the belt slip issue might reduce some of the boost gains.
Even before I got the blower in my shop I was thinking about putting a smaller pulley on it. But after I opened the box and saw how small it was already I thought not going to happen.
Our blowers come with the smallest pulley that I have ever seen on a factory set up.
I hope it works out for you because I think that your the first one that has done the blower pulley ( At least that i know of )
If It works well for you maybe we can get ASP to copy the puller he uses and offer it for sale or rent with the smaller pulley.
I will be next in line to put one on my beast if it works out for you
The Following 2 Users Say Thank You to DHentz For This Useful Post:
Mr. Creosote (06-30-2012), socal57chevy (08-02-2012)
