ASP Pulleys - Page 19 - TundraTalk.net - Toyota Tundra Discussion Forum
Old 11-20-2012, 12:36 PM   #271 (permalink)
TRD_Tundra's Avatar
Originally Posted by BRX View Post
We kept testing until we found one that fit. I can't remember exactly which thread size we used. Maybe toytec could chime in on this as he recently installed his...
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Been delayed on the install for these past 2 days now due to this. Tried almost every bolt but all of them are either too small if not they only thread in for the 1st two turns then jams.
TRD_Tundra is offline   Reply With Quote
The Following 2 Users Say Thank You to TRD_Tundra For This Useful Post:
Mr. Creosote (11-20-2012), TundraStruk (11-21-2012)
Old 11-20-2012, 03:23 PM   #272 (permalink)
Supercharged's Avatar
You can get a Loan a Tool from Autozone. This tool will put the new pulley on. It will not remove it. It also has the bolt that will fit into the supercharger.
Power Steering Pulley Puller/Installer | AutoZone.com
First 11 Second Tundra
Best 1/4 mile time: 11.940 @ 113.19 mph
1.66 second 60' time.
http://www.youtube.com/watch?v=Bb9MNYFwUFA
12.034 @ 113mph
http://www.jdmtube.com/video/657/Toy...PH-PBIR-Moroso
12.1 @ 112mph. Tundra vs 600hp Challenger
http://www.youtube.com/watch?v=Fa8JI...e_gdata_player
Supercharged is offline   Reply With Quote
The Following 4 Users Say Thank You to Supercharged For This Useful Post:
BRX (11-21-2012), Mr. Creosote (11-20-2012), TRD_Tundra (11-21-2012), TundraStruk (11-21-2012)
Old 11-21-2012, 03:14 PM   #273 (permalink)
TRD_Tundra's Avatar
Wend to ASAA Racing in Houston. They got it out. I had messed up the threads so they had to re-tap it.
I took alot of pics and posted them here of the S/C install
Tundra SuperCharger Install
2011 FFV Tundra Limited: SuperCharged (TRD Forged 22"s, Lucchese, ASP pulley, Valve Body, DT Long Tubes, TRD Swaybar, Deleted all cats, AEM F/IC-8 Tuned, Dual e-cutouts)
2006 Silverado 5.3 (76mm Turbo,Cam 216/220, AEM TruBoost, AEM Wideband, Built 4l80e, Dual springs, Bosch 60# injectors, Aeromotive 340, AEM Meth injection... Boost is at 12psi on meth) Tuned by TELLEZ
Mr. Creosote (11-21-2012), TundraStruk (11-21-2012)
Old 11-21-2012, 04:06 PM   #274 (permalink)
Did you see what tool they used to remove the pulley?
12.034 @ 113mph
The Following 3 Users Say Thank You to Supercharged For This Useful Post:
BRX (11-21-2012), Mr. Creosote (11-21-2012), TundraStruk (11-21-2012)
Old 11-21-2012, 08:03 PM   #275 (permalink)
TRD_Tundra's Avatar
It was a 3-jaw pulley puller. I didn't get to see what brand but the quality was noticeable compared to my rent tool at o'Reilly's that broke a jaw. He just used an impact drill and came out in no time. To install it, it looked like he used a Stud sorda of tool with a nut on one end. These are the only pictures I got. In one pic he's re-taping the threads as I had stripped them out.
Old 11-28-2012, 10:50 AM   #276 (permalink)
Tech_Greek's Avatar
That looks like a seal remover set.
Impact is always the way to go as the quick pounding doesn't put as much torque on one specific bound up spot of the bolt (in your case the cross threaded section).
Tech_Greek is offline   Reply With Quote
The Following User Says Thank You to Tech_Greek For This Useful Post:
Mr. Creosote (11-28-2012)
Old 11-28-2012, 11:50 AM   #277 (permalink)
Whatcha waiting for Tech, go on and get you a charger.
2008 RCSB 5.7
13.711@100.73 on 22's, Intake and Exhaust
TRD Supercharged times coming soon........
HULZAZZ is online now   Reply With Quote
The Following User Says Thank You to HULZAZZ For This Useful Post:
Old 11-28-2012, 11:55 AM   #278 (permalink)
Tech_Greek's Avatar
Trust me its been in my mind constantly but with the economy the way it is right now and seeing businesses shutting down left and right here I've been stuffing under my mattress.
The other thought of paying for it would be to sell my Lexus and just use the money to do that so I'm not out of anything at all. That's the one that is getting me
Old 11-28-2012, 12:05 PM   #279 (permalink)
I hear ya. Thought about selling the Civic and doing the same, but I just can't bring myself to do it.
2008 RCSB 5.7
Old 11-28-2012, 12:08 PM   #280 (permalink)
Tech_Greek's Avatar
Yeah that's why I haven't done it yet. The pure labor that has gone into my car and cost would be a loss big time but the thought of having a blown daily excited me
Old 11-28-2012, 12:39 PM   #281 (permalink)
RIjon's Avatar
Worth it!
2008 Tundra 5.7L RCSB 2wd Supercharged, IPT Valvebody, Auburn, Sequoia sway bar, ect.
Needs new tires....
Custom switch panels & emblems
www.gaugeplates.com
Si vis pacem, para bellum
RIjon is offline   Reply With Quote
The Following User Says Thank You to RIjon For This Useful Post:
Old 01-04-2013, 08:17 AM   #282 (permalink)
Supercharger
Did you ever get the stock sc pulley off for that asp pulley? If so which puller did you use? Thx
randomwalk101 is offline   Reply With Quote
The Following User Says Thank You to randomwalk101 For This Useful Post:
Mr. Creosote (01-04-2013)
Old 01-04-2013, 09:45 AM   #283 (permalink)
^^^ No. I decided not to install it since I already have the other two pulleys. My goal is to run high 11s without using all three pulleys.
A heavy duty jaw puller is what appears to work good on the crewmax. I tried a 2 ton one and it did not budge.
12.034 @ 113mph
The Following User Says Thank You to Supercharged For This Useful Post:
Old 01-04-2013, 09:54 AM   #284 (permalink)
Wow...this is even when it's cooled? Can you use an impact wrench on it or not enough room? I'm thinking of getting the asp pulley but the install kind of shy me away lol
Old 01-07-2013, 11:52 PM   #285 (permalink)
I called asp today and they ran out of the sc pulley. They just sold all their lot of stock to a dealer (20 sc pulleys). WTH?
Mr. Creosote (01-08-2013)
