oil filter cap - Page 3 - TundraTalk.net - Toyota Tundra Discussion Forum
post #31 of 43 (permalink) Old 02-24-2012, 11:37 PM
fosterelli's Avatar
Originally Posted by quiksi View Post
it's possible to break a K-D 3253. I did it when my local dealer (Fred Haas Toyota Country) way over-tightened the housing on my first and last dealer oil change.
Fortunately, another local dealer carries the Assenmacher and since it works on both my Tundra and my wife's RAV4, it was totally worth the $30 or so
Do you still use Fred Haas for service? I moved from them (249 location) to Don McGill Katy...very happy with the change.
2012 Ford F350 SRW CCLB Lariat Ultimate FX4 6.7L PSD 3.55 ELSD
2007 Range Rover Supercharged
1970 Ford Torino Cobra 429
SOLD: 2007 CrewMax Limited 5.7L 2WD
fosterelli is offline
The Following 2 Users Say Thank You to fosterelli For This Useful Post:
Mr. Creosote (03-10-2012), socal57chevy (02-29-2012)
post #32 of 43 (permalink) Old 02-25-2012, 02:07 PM
PSU69's Avatar
Quoted: 66 Post(s)
Custom Oil Filter Wrench
Check this wrench out. I bought one for $10.50 delivered. It is a high quality tool. If he has any left, it would be worth considering. It won't round off the plastic housing.
2012 DC SR5 5.7L 4x4
*** I think, therefore I am a conservative. ***
(With apologies to Descartes.)
PSU69 is offline
The Following 2 Users Say Thank You to PSU69 For This Useful Post:
post #33 of 43 (permalink) Old 02-29-2012, 11:03 AM
Quoted: 67 Post(s)
great idea and design, but be forewarned. I did that same thing using the outside overhanging edges of the cheap black resin composite plastic oil filter housing and snapped one of the 2 sides off very easily. If the oil filter end cap was metal or aluminum instead of black resin composite plastic or whatever cheap material the tundra oil filter end cap is made out of, no problems. But, in time, those 2 tabs can easily break off, trust me, I did it very easily!
cookiedough1 is offline
The Following 3 Users Say Thank You to cookiedough1 For This Useful Post:
Mr. Creosote (03-10-2012), PSU69 (02-29-2012), socal57chevy (02-29-2012)
post #34 of 43 (permalink) Old 02-29-2012, 08:43 PM
Originally Posted by rjmaiorano@hotmail.com View Post
Gotta do metal. My first oil change on the truck I broke 3 plastic oil filter wrenches, that was also probably partly the dealers fault by putting the cap on so damn tight.
LOL! Your right it's supposed to be only 25nm tight which is equivalent to like 12ft/lbs?? Hand tight is what I do, but that damn plastic expands when it's hot and It just makes it harder
09xsp4x4 is offline
The Following 2 Users Say Thank You to 09xsp4x4 For This Useful Post:
Mr. Creosote (03-10-2012), socal57chevy (03-10-2012)
post #35 of 43 (permalink) Old 03-10-2012, 03:34 PM
Usmc1968's Avatar
Ok, so I just did the oil filter cap mod. The Aluminum one is nice. Quick question to those who have done the swap. Which little metal cap did you use? There is a small metal base that the spring sits on. The one that came with my Tundra has more holes in it than the one that came with the Aluminum one. I chose the one that came with my truck (more holes means better oil flow?). Just curious.
Semper Fi
Usmc1968 is offline
The Following 2 Users Say Thank You to Usmc1968 For This Useful Post:
post #36 of 43 (permalink) Old 03-10-2012, 07:43 PM
fosterelli's Avatar
I used my truck's original parts, except for the housing itself.
post #37 of 43 (permalink) Old 03-10-2012, 08:09 PM
socal57chevy's Avatar
Quoted: 6 Post(s)
I believe everyone else has, too.
socal57chevy is offline
post #38 of 43 (permalink) Old 03-10-2012, 08:20 PM
Daggerdoggie's Avatar
My collection of Tundra oil filter wrenches. All have failed except for the silver one on the right.
2012 Rock Warrior DC in black. Alpine CDA-117, Alpine ERE-G180 11 channel EQ, Alpine PDX-F6 4 channel amp, Alpine PDX-M6 Mono Sub amp. 10" Kicker subwoofers, Alpine MRP-M350 with Infinity 860s mid subs, JBL's & Polk Audio component speakers, Memphis speakers in dash. Peragon Bed Cover. TRD Sway Bar. Firestone Air Bags. P3 Brake Controller. LED lights - complete interior, backup, cab & brake lights. Power tailgate actuator. Rear seat mod.
Daggerdoggie is offline
The Following User Says Thank You to Daggerdoggie For This Useful Post:
post #39 of 43 (permalink) Old 03-10-2012, 08:24 PM
Big Shasta's Avatar
Quoted: 1222 Post(s)
I changed my oil for the first time on my 2012 last weekend. I also swapped to the Toyota metal housing at the same time. Swapped the internals from the plastic to the metal one (longer tube inside the cartridge filter) and it worked perfect. I can't imagine the plastic housing...GONE.
I do need to order a filter wrench that fits the housing though, that was a pain to get off.
I'm Ken and I approve this message -
<~~The Sarcasm is strong in this one.
"Give me ambiguity or give me something else"
2012 Black SR5 DC 5.7 - A few upgrades.... (Sold 6-29-15)
My Garage
Big Shasta is offline
The Following 2 Users Say Thank You to Big Shasta For This Useful Post:
NHC45 (04-27-2012), socal57chevy (03-10-2012)
post #40 of 43 (permalink) Old 04-27-2012, 02:23 PM
Does the aluminum housing use the same size wrench as the stock plastic one?
andito77 is offline
The Following User Says Thank You to andito77 For This Useful Post:
socal57chevy (04-27-2012)
post #41 of 43 (permalink) Old 04-27-2012, 05:14 PM
Yes, it is identical in every way except it is aluminum. I changed mine. I put a tiny bit of anti-seize on the threads to make sure I could get it back off easily... You won't regret it.
2010 Tundra, Reg Cab, 4X4, TRD Off Road Package, SR5, Radiant Red, Black Interior w/Buckets & Console. DiamondBack HD/Line-X Tonneau Cover, Rhino Liner in the bed, tinted windows, TRUXX 3/1 Level kit. ( I actually removed the 1" blocks in the back, the truck is truly level without them and the drive shaft "clunk" went away as the axle wrap was diminished a LOT ).
NHC45 is offline
The Following 2 Users Say Thank You to NHC45 For This Useful Post:
socal57chevy (04-27-2012), Usmc1968 (04-28-2012)
post #42 of 43 (permalink) Old 05-28-2014, 11:01 PM
Exclamation
I've bought both the genuine 'Yota part and the Dorman cHineez knock off one from rokauto. The Dorman one is a cost cutted POS, that I highly recommend no one spend their $$ on. I threw mine in the trash. The Doramn AL metal was heavier than the OEM one and the oil filter shaft was made out of very thin metal, reminded me of aluminum foil, that's how soft and pliable it was! It's not worth the $8 in savings.
Part numbers:
OEM AL cap = 15620-31060
OEM plasteek cap = 15620-38010
OEM plug = 15643-31050
Dorman AL cap = 917016
'07 black USK55L-TRTDKA - daily driver
'09 grey Z34 - AAM Comp Xhaust, Nismo shox, O.S. Giken LSD, Frontier 4.36 final, Xedy clutch, Defi, Volk Racing G2s, Yoko AD08R, - mid 13" weekend cruiser
'05 red CT9A-SNDFZ-RS - mid 12" grocery getter/garage ornament
tondruh_ricer is offline
post #43 of 43 (permalink) Old 05-28-2014, 11:21 PM
"Resident Liberal"
OkSlim's Avatar
Quoted: 2320 Post(s)
Originally Posted by oldtimer View Post
I got my filter socket from my local NAPA store; KD #3253. Guarantee you'll not slip this one
I think we have the answer here and can now close this thread.
NAPA KNOW HOW
The voices in my head don't like you.
H. L. Mencken
2008 RCSB 4.7 TRD Offroad 4x4
OkSlim is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Parts & Accessories
