Best Battery???? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 9 (permalink) Old 11-05-2011, 06:58 AM Thread Starter
Oct 2009 ToTM Winner
xtremelow's Avatar
Quoted: 13 Post(s)
Best Battery????
Looking to get a new battery to help run my off-road lights, stereo, and just day to day driving but not sure what the best available one for under $200 is.
I have run Optima Batteries and have been unimpressed with them so I would like to see what else is available.
Any input would be great.
Thanks
Brandon
Unguided Missile Member #1
2010 DC, King and Deaver for the speed bumps
xtremelow is offline
The Following User Says Thank You to xtremelow For This Useful Post:
Mr. Creosote (11-11-2013)
post #2 of 9 (permalink) Old 11-05-2011, 08:31 AM
berdine3's Avatar
Autozone duralast gold. They have more cca than optima, and you get a lifetime warranty. I ran 2 in my dodge. I am upgrading to 1 when I get my bumper and winch.
2004 Sequoia Limited
2012 Sequoia SR5
Old Truck Mods in Link Below:
http://www.tundratalk.net/forums/tun...build-log.html
berdine3 is offline
The Following User Says Thank You to berdine3 For This Useful Post:
post #3 of 9 (permalink) Old 11-06-2011, 09:33 AM
imcougar's Avatar
Quoted: 17 Post(s)
i am running sears Diehard platinum pm-1, group 31 - Sears: Online department store featuring appliances, tools, fitness equipment and more. it's not under $200 but it has a lot of juice & deep cycle like the optima yellow. it's made by Oddessy but not as expensive. I think it was $450 for the similar oddesy model.
2010 RW DC 4WD w/ Towing / Supercharger / Doug Thorley LT / ARB winch bumper / Expedition Rear bumper / Truck Cover USA Roll Cover / Kenwood DNX9980HD / After market backup camera / MBRP Dual exhaust / Warn 16.5ti winch / OME lift w AAL / ARB front/rear lockers and more
imcougar is offline
The Following User Says Thank You to imcougar For This Useful Post:
post #4 of 9 (permalink) Old 11-06-2011, 10:16 AM
Originally Posted by imcougar View Post
X2 for the Sears Diehard Platinum. I have been hearing good things about this battery. The off road community seems to be filtering over to it because it holds up so well with hard use. A little expensive but from what I’ve heard “well worth it”.
Member #18
2011 Tundra 4x4 Reg Cab, SR5, TRD.
5.7…6 speed column shift.
Tow Package
ARE hard Tonneau.
Anytime fog light mod.
Bilstein 5100 ajustable height front shock.
Tire size 275/70R18 (Michelin LTX M/S2).
Firestone "Ride Rite" air bags.
TRD rear sway bar.
warsw is offline
The Following User Says Thank You to warsw For This Useful Post:
post #5 of 9 (permalink) Old 11-06-2011, 01:13 PM
rockstate45's Avatar
Quoted: 4 Post(s)
I love my Diehard Platinum battery too. Factory one crapped out last year in October. So, after about 12-13 months with the Diehard, it's never let me down. I jumpstarted 2 fully dead diesels with hardly a strain on the alternator. The Cummins had 2 Optima Red tops and the Duramax has the nicer Autozone type store batteries in there.
No corrosion either which is the best part.
rockstate45 is offline
The Following User Says Thank You to rockstate45 For This Useful Post:
post #6 of 9 (permalink) Old 11-08-2011, 07:38 AM
SP
SP's Avatar
Quoted: 242 Post(s)
Does the Diehard Platinum battery fit in with no modifications to the cables?
2014 CM 5.7L 1794 edition Front tint*OEM look alike Brushed steps*LED H4 opt-7 lights(lots of scatter)*morimoto LED fogs(excellent)*interior canbus LED's*Husky Liners X-act Contour Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*LowPro Rollup Tonneau cover*Tire and wheels soon :-)
SP is offline
The Following User Says Thank You to SP For This Useful Post:
post #7 of 9 (permalink) Old 11-08-2011, 08:09 AM
imcougar's Avatar
Quoted: 17 Post(s)
you will have to make battery positive cable connector hole a little bigger with a drill. i think that's it.. i don't recall if there is anything else needed. the cable first seems to be a little short but you can still connect it to the battery terminal
imcougar is offline
The Following 2 Users Say Thank You to imcougar For This Useful Post:
Mr. Creosote (11-11-2013), SP (11-09-2011)
post #8 of 9 (permalink) Old 11-09-2011, 07:09 AM
SP
SP's Avatar
Quoted: 242 Post(s)
thanks man. This will be my battery very soon. I am still on my 08 battery.
SP is offline
post #9 of 9 (permalink) Old 11-11-2013, 09:37 PM
what is a good tundra battery?
Hello everybody,, I love my 2001 Tundra ( no body rot) anyway, did a battery test using the float suction tester.. not all the four colored floats did the same in each of the six cells on my replacement sears diehard that is over few seasons old.. I can't let this thing drain on a radio for 15 minutes or it goes dead ..the battery is a C9 540CCA group size 35 (30035) I suspect it is a minimum size battery because there is plenty of room to spare in the tray for a larger size battery.. any suggestions appreciated as I do travel in sub freezing climate and do want a new battery for this winter. tia, john
john2001 is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Parts & Accessories
