Aftermarket Cruise Control. - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 11 (permalink) Old 12-15-2011, 10:23 AM Thread Starter
Is there a good aftermarket Cruise Control kit out there? My truck was a barebones "worktruck" with no cruise and barely anything else. Not having cruise is starting to kill me now. I talked to the dealership parts guy and he said they didn't offer anything through Toyota for me and I would have to go aftermarket.
Does anyone have any suggestions or experience with some of the aftermarker cruise control kits? I'd probably have it installed as I'm a little hesitant about rewiring anything myself.
Thanks!
Blueheed
_______
2007 5.7L Tundra Singlecab
blueheed is offline
post #2 of 11 (permalink) Old 12-15-2011, 10:41 AM
nastyn8's Avatar
Quoted: 55 Post(s)
On the 07 base truck you can add cruise with the factory switch and running a wire from the cable reel to the ecu, later models are pre wired. I cant remember the pin locations but i can look it up later. I am sure someone has it on PDF some where
nastyn8 is offline
The Following User Says Thank You to nastyn8 For This Useful Post:
socal57chevy (12-19-2011)
post #3 of 11 (permalink) Old 12-15-2011, 10:58 AM
Big Shasta's Avatar
Quoted: 1565 Post(s)
Here's a start.
http://www.tundratalk.net/forums/tun...e-control.html
I'm Ken and I approve this message -
<~~The Sarcasm is strong in this one.
"Tact is for people who aren't witty enough to be sarcastic"
rac·ist ˈrāsəst/ noun 1. a person who is winning an argument with a liberal.
2012 Black SR5 DC 5.7 - A few upgrades.... (Sold 6-29-15)
Big Shasta is online now
The Following User Says Thank You to Big Shasta For This Useful Post:
post #4 of 11 (permalink) Old 12-19-2011, 03:24 PM Thread Starter
The guy at the dealer told me they didn't have anything factory they could order for me. Am I misunderstanding something or was he wrong?
blueheed is offline
post #5 of 11 (permalink) Old 12-19-2011, 03:32 PM
socal57chevy's Avatar
Quoted: 390 Post(s)
He was wrong. I have a bare bones work truck with cruise control, intermittent wipe, and mpg display.
Where are you located?
ASE Master Technician
socal57chevy is offline
post #6 of 11 (permalink) Old 12-19-2011, 03:57 PM Thread Starter
Located in South Central Louisiana. I think I may need to give the dealership a call today, get this sorted out.
blueheed is offline
post #7 of 11 (permalink) Old 12-19-2011, 04:05 PM
Quoted: 390 Post(s)
If I were you, I'd buy the parts from one of the vendors here on TT and do the work at home.
What year is your truck? Newer trucks are plug-n-play.
The Following User Says Thank You to socal57chevy For This Useful Post:
blueheed (12-19-2011)
post #8 of 11 (permalink) Old 12-19-2011, 04:07 PM Thread Starter
I'll look into that, see what is available for order out there. Thanks.
blueheed is offline
post #9 of 11 (permalink) Old 12-29-2011, 05:02 PM Thread Starter
Alright, so now I've ordered a cruise control switch from TRDSparks. It came in and all it had was the switch, no wires, screws, instructions or anything. Should there be more that I need to put this on? Or is the switch the only thing I need?
Thanks!
blueheed is offline
post #10 of 11 (permalink) Old 12-29-2011, 07:53 PM
nastyn8's Avatar
Quoted: 55 Post(s)
Because you have an 07 single cab you will need to run a wire from the cable reel to the wire hareness in the passenger footwell. Give me a few moments and i will get pin locations and wire color for you
nastyn8 is offline
The Following 2 Users Say Thank You to nastyn8 For This Useful Post:
blueheed (12-29-2011), socal57chevy (12-29-2011)
post #11 of 11 (permalink) Old 12-29-2011, 08:17 PM
nastyn8's Avatar
Quoted: 55 Post(s)
You should go buy the screws and cover for the steering wheel. It would also help to have access to some connector pin repair kits. At the cable reel pin location #1 needs a wire run to the engine room main wire harness. At connector # AJ5 in the passenger kick panel the lavender wire is in pin position #10. It will be on the side that runs to the firewall and not on the side that feeds the rest of the truck. It sounds more complicated than it is.
Pin #2 at the cable reel needs to go to ground, simple.
If you had an 08 or newer you would just need the switch, no wiring needed.
I attached images of the connectors you are looking for, they will be the exact shape and number of pin locations listed. There are several connectors in the passenger kick panel, make sure you find the right one.
nastyn8 is offline
