XB FOGS GROUP BUY ROUND 2
GROUP BUY IS NOW CLOSED! Fog Lights will begin shipping TODAY Monday the 28th.
PLEASE CHECK YOUR EMAIL FOR SHIPPING AND TRACKING INFORMATION TODAY/TOMORROW.
XB FOGS TYPE T (14-Present) TOYOTA (OVAL): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale
XB FOGS TYPE T2 (07-13) TOYOTA (ROUND): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale
XB FOGS OTHER VEHICLES FOG LIGHTS - Retrofit Wholesale
SPECS
- Light Source: 3x Philips Luxeon-T
- LED Optics: Kuria-2 Projector Fog Lens
- Intensity: 2400 Lumens
- Kelvin Rating: 5500K (pure white)
- Input Socket: Sealed H11 Male
- Weather Rated: IP67 Waterproof
- Lens Material: High Impact Polycarb (UV-Resistant)
- Shell / Heat Sink: Powder Coated Cast Aluminum
10 Year Warranty!
XB FOG LIGHT INSTALL GUIDE
XB FOGS ARE A DIRECT SWAP
Gen 2
1. You need to go through the wheel well liner. Once you remove it, you will have access to the fogs.
2. Disconnect the fog lights connector.
3. Theres 1 Plastic retainer that holds the fog light in place. Use a flat head screw driver to unlock it. Remove the fog light by pushing foward and out.
4. Get your new XB fogs. The fog lights are L/R Oriented. Look on the back of the lights to locate the L/R letters to know which side. R= Passenger, L=Driver.
5. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientation of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
6. Slide the XB fogs in its place and use the plastic retainer to lock it in place.
7. Connect the Fog Lights to OEM connector.
Gen 3
3. Disconnect the fog lights connector.
2. There are two slots and 1 screw that holds the stock in place. Remove the scew and slide the stock fog light.
3. Get your new XB fogs. The fog lights are L/R Oriented. Look on the back of the lights to locate the L/R letters to know which side. R= Passenger, L=Driver.
4. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientaion of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
5. Slide the XB fogs in its place and either use the new screw that came with the fogs or re-use the old. Its a tighter fit as the tabs on the XB are thicker. Tighten the screw down.
6. Connect the Fog Lights to OEM connector.
AIMING
Since everyone has different heights on their truck, I cant give you a specific way to aim them. Best way is before removing your old fogs, drive back 10-15ft from a wall or ground and use tape to mark where your lights are.
The XB fogs are projector base LED's so the light will be more focused. Start by aiming them to the stock levels. Drive around without headlights on (parking lights off) so you can see where the spread is.
Spread should be about 4-10 ft in front of your truck depending on your headlights.
For those with retrofits, you want the XB fogs to end right at the beginning for your main HID or LED projector beam spread.
For those with stock halogen reflectors (with or without hid or led upgrades in reflector housings), you want the beam to end towards the middle of the main headlights beam spread.
Raise and lower to get your optimum desired height.
Hope this helps guys
