Old 12-20-2007, 10:26 PM   #1 (permalink)
Night Gauge pics?
Any one have any pics of what the Limited gauges look like at night?
Thanks!
4REF1FAN is offline   Reply With Quote
Old 12-20-2007, 11:44 PM   #2 (permalink)
RunItHard's Avatar
Thanks!
Here ya go... And hey look, it's time to change my oil. Yep, hit 5,000 on the way to work tonight.
BTW, that's an aftermarket GPS I have mounted to the A pillar... It's not part of the Limited package. And the engine wasn't running for these pics, which is why you see all the idiot lights on.
The gauges were a large part of the reason I opted to get the Limited. If they'd have offered them as an accessory I'd have gotten an SR-5. Toyota is smart... They dangle the eye candy in front of you and only let you have it if you opt to drop a few more grand.
Old 12-21-2007, 08:49 AM   #3 (permalink)
jbk23's Avatar
Nice I think I can live with my guages instead of the limited ones.
Old 12-21-2007, 02:32 PM   #4 (permalink)
djb383's Avatar
+1 :d
djb383 is offline   Reply With Quote
Old 12-21-2007, 02:56 PM   #5 (permalink)
Thanks, runithard. Those look really nice. I too, wish they offered those gauges as an option on the SR5 models.
Old 12-21-2007, 05:11 PM   #6 (permalink)
jeffpearlman's Avatar
Runithard, What bracket mount did you use for your NUVI?
08 Crewmax 4x4
Lorado cover
bedrug
aluminum shifter
sport pedals
exhaust tip by valor
Daystar leveling kit, Nitto Terra Grapplers 285/65/R18
Weathertechs for the floor
Garmin GPS, Audiovox back up camera mirror.
jeffpearlman is offline   Reply With Quote
Old 12-21-2007, 07:48 PM   #7 (permalink)
dascrow's Avatar
Those looks nice, I wonder if you can just order the gauge cluster?
dascrow is offline   Reply With Quote
Old 12-22-2007, 09:56 AM   #8 (permalink)
RunItHard's Avatar
It's a permanent mount Nuvi offers on their website, but don't buy it there as you can get it $10 cheaper elsewhere... Here I just did a search, Amazon has it for $20 bucks.
Amazon.com: Garmin Automotive Mount for Nuvi (010-10723-04): Electronics
The mount comes with two different types of double stick mounting tape for the bracket. A semi-permanent tape and a permanent. Because of the curve of the A-pillar molding, neither one will work even though the base is shaped like an oval and isn't as wide as the round suction cup base plate that comes with the unit.
I got it to work by applying the permanent tape, then I cut two extra layers of 3-M automotive mounting tape to match the outline of the base. I then applied these to each vertical side of the base before pressing it onto the A-pillar molding. This makes the mounting tape higher on each vertical side than it is in the middle, and better matches the curve of the molding. It worked very well and is stuck on there tight.
Just make sure you clean the area with rubbing alcohol, and I'd suggest running your windshield defroster on high heat to warm-up the A-pillar first. Then press the base on hard and hold it for about 60 seconds.
Old 12-22-2007, 10:01 AM   #9 (permalink)
RunItHard's Avatar
Knowing what they get for parts it's probably a small fortune.
Old 01-08-2008, 05:24 PM   #10 (permalink)
Modifying the gauge lights?
I have the 2008 SR5 (all orange gauges) and am very instrested in changing my gauge lights to the lights found on the limited. A friend of mine is a mechanic for Toyota and can order me parts for his cost. He also can help me install them, which a big plus! I am just trying to figure out how much something like this would cost and also if it is even something that can be done? Does anyone know more about this sort of thing? I appreciate the help.
Thanks!
Philip
phils_66 is offline   Reply With Quote
Old 03-17-2008, 01:52 AM   #11 (permalink)
What do the sr5 guages look like?
bluestinger90 is offline   Reply With Quote
Old 03-21-2008, 01:45 AM   #12 (permalink)
sxd45's Avatar
i read on tsolutions that you could not switch the limited gauges, i will try to find the link.
White Tundra Club Member #1
Old 03-21-2008, 09:10 AM   #13 (permalink)
Mickey's Avatar
I would think they are interchangeable. But SXD45 is researching it. Runithard at first I thought you took pictures of my interior but then I saw the snow. Not here for a long time.
Mickey is online now   Reply With Quote
Old 03-22-2008, 04:05 AM   #14 (permalink)
sxd45's Avatar
"Response (Sandra) 10/29/2007 08:39 AM
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We appreciate you contacting us with your inquiry.
As the Optitron gauges are only offered on the 2007 Tundra Double Cab Limited V8, they are not available or can they be upgraded on the 2007 Tundra CrewMax SR5.
The Limited and SR5 are different models, and the wiring harness for them are not the same.
Toyota does not recommend modifying its vehicles from their original factory specifications. Modifications could affect the vehicle’s performance, safety or durability, and may violate government regulations. In addition, damage or performance problems resulting from the modification may not be covered under warranty. If it is determined that the computer reprogramming, to accommodate a switch for the instrument clusters, was the root cause of any future concerns the repair would not be covered under warranty.
Your email has been documented at our National Headquarters under file #200710290332. If we can be of further assistance, please feel free to contact us.
Toyota Customer Experience
It looks like the only option for those of us who are not enthralled with the amber setup is to replace the LEDs with a more favorable color.
Ryan" from t-solutions
Old 03-30-2008, 10:30 PM   #15 (permalink)
Ryan" from t-solutions[/quote]
I would love to change out the LEDs. How would you go about doing that?
ndheady is offline   Reply With Quote
