help 07 tundra scraping or grinding noise - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 22 (permalink) Old 09-02-2011, 08:28 PM Thread Starter
ok
my tundra makes a scraping/grinding noise only when i turn the wheel to the left. i checked the front end pulled tires off checked drive shaft checked muffler/exhaust to see if it was loose and hitting something checked brakes,rotors, and rotor dust shields and ball joints and i have no idea what is making the noise. sounds like its coming from passenger side front
anyone have an idea or know what it could be ???? wheel bearing ??
07 tundra is offline
post #2 of 22 (permalink) Old 09-02-2011, 08:55 PM
eldog's Avatar
Quoted: 8 Post(s)
u sure its not the wear indicator on the inside brake pad? i just fixed mine from doing the same thing but it was the driver side.
2014 4wd CrewMax SR5 with upgrade package
TRD Offroad Package.
Undercover Flex Tonnaeu
6" pro comp stage 1
20x9 XD Misfits
35/12.50/20 Kumho Venture m/t
Icon coilovers
NFAB bars
Xact Contour mats
eldog is offline
post #3 of 22 (permalink) Old 09-03-2011, 12:09 AM
red dragon's Avatar
Mine was doing something similar but driver front side. Ended up being a broken wheel stud
2007 double cab sr5, 20in moto metal 962 wheels, zero offset, nitto 305/55/20 terras, fat bobs 3/1 , blacked out rear bumper and tails, black prerunner front bumper, bhlm, mtx sound system, magnaflow stainless exhaust.
red dragon is offline
post #4 of 22 (permalink) Old 09-03-2011, 05:53 AM
Powertechn2's Avatar
Quoted: 985 Post(s)
what kinda scraping noise?
metal on metal? rubber grinding noise, just rubbing noise, clicking noise>?
u pulled wheels, but didn't say if you verified that its not teh tires rubbing when you turn...
Had/gone 2010 CM RW that was sweet,
NOW: 2017 Platinum. Tinted, trd duals, Exo Grapplers.
I like weapons.
and you can call me Power.
Powertechn2 is offline
post #5 of 22 (permalink) Old 09-03-2011, 08:04 AM Thread Starter
metal on metal not real loud and only when turning to the left
post #6 of 22 (permalink) Old 09-06-2011, 08:03 AM
mine is doing the same thing
I'm debating taking it to the dealership today
anybody have any insight on what's happening?
Searching has revealed the question asked a few times but never answered
SilentJohn is offline
post #7 of 22 (permalink) Old 09-06-2011, 08:11 AM
Same thing here. Proably a rock lodge in the wheel someplace. I'm do for tire rotation so I will take it off and take a look at one of these days.
10 Toyota Tundra TRD Rock Warrior His
09 Yamaha R1 Raven
His
08 VW Jetta GLI
Hers
2008 Yamaha Raptor 250
Hers
05 YAMAHA R6 Raven
His (track bike)
04 wr250f plated!
His
EdgeR6 is offline
post #8 of 22 (permalink) Old 09-06-2011, 09:37 AM
Quoted: 291 Post(s)
could it be busted tie rod booth or CV join booth or something?
randomwalk101 is offline
post #9 of 22 (permalink) Old 09-06-2011, 04:00 PM
straussr's Avatar
lol....I thought i was the only one with this problem. It's a cover around the rotor that's rubbing. I can't remember if it's hitting the axle or not. American Tire bent it back for me and it hasn't made the noise since. And yes, it's only during left turns......weird. I'll post some pics later, so you can do it yourself and save $70.
straussr is offline
post #10 of 22 (permalink) Old 09-06-2011, 04:05 PM
mikestoyotatundra's Avatar
I had the same thing. Took it tot he dealer, they couldn't figure it out. The one day while washing the tundra and noticed the the wheel well protector had bent in and was making contact when i turned left. I pushed it back into shape, problem solved.....
mikestoyotatundra is offline
post #11 of 22 (permalink) Old 09-06-2011, 04:19 PM
straussr's Avatar
A couple inches below the bolt in the middle of the picture is where the cover makes contact with the axle, causing the grinding noise that sounds like you need new brakes. The stupid noise forced me to prematurely replace my brake pads. Hope this helps!
straussr is offline
The Following User Says Thank You to straussr For This Useful Post:
SilentJohn (09-06-2011)
post #12 of 22 (permalink) Old 09-06-2011, 05:06 PM
Quoted: 291 Post(s)
Thanks for posting the pics..but there are a few bolts...or at least two sort of "in the middle"..which one were you talking about? Also, which part did they bend? Thx. See pics.
post #13 of 22 (permalink) Old 09-06-2011, 05:41 PM
blushin's Avatar
Quoted: 20 Post(s)
holy shit, this might be exactly what the issue im having is, i just put an lro level kit on my crewmax last week and noticed this goofy kind of rubbing noise every once in a while when i turn full lock, sometimes it happens full right, sometimes full left.
2016 Crewmax 1794 4x4, Super White, 285/65r20 BFG KO2's, Line-X Premium, LRO 3/1, Gibson Stainless 4" Single Exhaust, Bakflip Fibermax, TRD PRO Grill, AMP RESEARCH powersteps
2007 Crewmax Limited 4x4, Super White, 285/65R20 BFG all-terrains, Line-X Premium, LRO 3/1, Gibson Stainless 4" single exhaust, Bakflip Fibermax (SOLD
1995 Toyota 4Runner 4x4 lifted and bfg all terrains (SOLD)
blushin is offline
post #14 of 22 (permalink) Old 09-06-2011, 09:39 PM
Thanks for the pic and info, something to try.
I hope it works!
post #15 of 22 (permalink) Old 09-07-2011, 09:42 PM
straussr's Avatar
I believe the contact was directly below bolt number 1. The cover wraps all the way around and comes close to the axle in many places, so you may have to bend it in a different location. It's very flexible and you can do it by hand. You'll see when you get under there.
straussr is offline
