Emergency brake adjustment - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 14 (permalink) Old 04-06-2011, 02:13 PM Thread Starter
Boudin's Avatar
Quoted: 55 Post(s)
I took my truck to the dealer to have the ebrake adjusted because it goes almost to the floor before engaging, and barely holds. Dealer claimed nothing wrong and wouldn't touch it. My question, is there an adjustment point to tighten it so my pedal doesn't go to the floor?
Sent from my ADR6300 using AutoGuide App
2007 5.7L TRD OFF ROAD
,275/70/18 LTX AT2 ,Bilstein 5100s
Camo Wet Okoles, UC Swing Cases, Westin Steps
DIY Bedliner, Gibson 7101 Exhaust , Satoshi Grille
BHLM, Spyder LED Tails, Dip'd bumpers, Yellow Laminx Fogs
TRD Rear Swaybar, LS460 HID Retrofit ( Pazorell )
Boudin is offline
post #2 of 14 (permalink) Old 04-06-2011, 04:17 PM
mendonsy's Avatar
Yeah, there is. The procedure is a bit complicated though. You might want to download the manual and follow the instructions.
Where to buy Factory Service Manual?
07' SR5 DC, 5.7, TRD
Toyota SS steps, ARE MX cap
AMP bed step, DIY underseat storage
Weathertech Floor Liners, Weathertech Vent Visors
Cooper Discoverer AT3s, Techstream
TWACC #7
mendonsy is online now
The Following User Says Thank You to mendonsy For This Useful Post:
Mickey (04-11-2011)
post #3 of 14 (permalink) Old 04-06-2011, 04:19 PM
crzy2bealive's Avatar
Quoted: 19 Post(s)
when the dealer does it my pedal feels like it has more tension maybe going to another dealer might help
crzy2bealive is offline
post #4 of 14 (permalink) Old 04-06-2011, 04:42 PM
Quoted: 155 Post(s)
mine said the same thing, and wanted to charge me $200 to look at them.
i crawled under and adjusted my brake at the wheels (all good) checked the cables and they were totally slack! there is a cable adjuster about driver door area on the bottom side (inside of the frame).took up the slack and its works great! something i think if the dealership had ACTUALLY looked at it would have been a no charge or a 1/2 hour charge as it took me longer to find the wrench than to actually tighten it
07 Limited 5.7L 2WD DCRB - billet grille, folding rear seat backs, LED frame strip lamps, BAmuffler, Painted TRD rims, AMP research Bed step
2016 Forest River Surveyor 226RBDS
Tundra Campers Club #35
Ditchhooker is offline
The Following User Says Thank You to Ditchhooker For This Useful Post:
Vettelover84 (08-22-2012)
post #5 of 14 (permalink) Old 04-06-2011, 07:49 PM
Powertechn2's Avatar
Quoted: 1090 Post(s)
thats what i need to do, mine wasn't right when i first tried it, and it obviously hasn't gotten any better. if im on even small slopes on last chance to catch before release it wont hold it.
was going to mention it when i took it in in feb for first oil change, but forgot...
and honestly they will prolly eph it up anyways lol
and you can call me Power.
Powertechn2 is offline
post #6 of 14 (permalink) Old 04-07-2011, 12:11 AM Thread Starter
Boudin's Avatar
Quoted: 55 Post(s)
It's under the truck on the drivers side? Would you mind taking a pic of you can? I can't believe the dealer blew it off, it makes me wonder if they actually changed the transmission fluid, which was the main reason I brought it in. I hate dealerships.
Boudin is offline
post #7 of 14 (permalink) Old 04-07-2011, 12:15 AM
Quoted: 76 Post(s)
You really mean stealerships don't you?
cookiedough1 is offline
post #8 of 14 (permalink) Old 04-07-2011, 12:59 AM Thread Starter
Boudin's Avatar
Quoted: 55 Post(s)
It always blows my mind how they try to scam people. They tried to hit me for 700$ saying I needed injector cleaning, throttle body clean, rear diff, tire rotation, etc. I do all my own work but the tranny was beyond me.
Boudin is offline
The Following User Says Thank You to Boudin For This Useful Post:
post #9 of 14 (permalink) Old 04-07-2011, 01:22 AM
Quoted: 76 Post(s)
Yah, I hear yah on the scam part. I told dealer my 09 corolla brakes when applied ONLY in reverse the past few months ONLY make a loud clacking noise ONLY in reverse and never before the last few months made that very loud noise. Dealer said bring it in, we will charge you 45 bucks to do a safety inspection and check brakes, fluids, etc. I said no thanks, fix my brakes ONLY under warranty. They said that brakes are routine maintenance and may need adjusting with brakes moving around with calipers and is a common noise. I asked why now and not 26K miles ago, no good answer except wanted 45 bucks pretty bad. What the heck is a warranty for?
post #10 of 14 (permalink) Old 04-10-2011, 10:29 PM
Quoted: 155 Post(s)
sorry the weather has been the pits the last few days. on my DC it is right where the back of the drivers door and front of rear door meet, on the top, inside of the frame rail. it is applied in this picture!
the nut was about half way from where it is now to the end of it. cable was totally slack. i have a steep driveway so it was a pretty high priority for me.
The Following 2 Users Say Thank You to Ditchhooker For This Useful Post:
desertgorilla (06-23-2016), spiderz17 (09-01-2013)
post #11 of 14 (permalink) Old 04-10-2011, 11:20 PM Thread Starter
Boudin's Avatar
Quoted: 55 Post(s)
Awesome man thanks so much
Boudin is offline
post #12 of 14 (permalink) Old 04-12-2011, 05:34 PM Thread Starter
Boudin's Avatar
Quoted: 55 Post(s)
Btw for those doing it, it's very simple. There are 2 nuts, hold the front one and back out the back one to unlock it, then screw front nut in to tighten then re-tighten back nut to lock back in place.
Sadly they dealer told me there was no adjustment
Boudin is offline
post #13 of 14 (permalink) Old 08-22-2012, 01:57 PM
Vettelover84's Avatar
Quoted: 64 Post(s)
Great info... Its good to know the Tundra doesn't auto adjust...
2010 Tundra CrewMax 5.7L V8 4x2 4.5/6 Drop.. TexasRanger96 Electric fan Kit
"The Tundra hunts its prey. Oblivious to the approaching hungry beast, the Prius grazes on its diet consisting primarily of wheatgrass shakes and hipster espressos"
"Illusion is a sleight of hand, a trick. Can't blame the ones who fall for it. But those who know it's a trick and still believe it...... That's delusion....."
Vettelover84 is offline
post #14 of 14 (permalink) Old 08-22-2012, 03:25 PM
Glenn54's Avatar
I know this was an older thread but thanks for the info. I'm going to adjust mine soon. The E brake doesn't hold worth a darn.
2012 Tundra DC, 4.6L, Texas Edition, SR5
Undercover SE Bed Cover
Husky Weatherbeater Floor Mats
Glenn54 is offline
The Following 2 Users Say Thank You to Glenn54 For This Useful Post:
Buckskin15 (04-11-2014), Vettelover84 (08-22-2012)
