Fishtails on wet roads braking straight - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 9 (permalink) Old 10-12-2009, 11:12 AM Thread Starter
Hi, new to forum, if I have put in the wrong place please move accordingly.
Have a 2006 tundra with tires marked (iirc) 245/70r16. Vehicle has fishtailed on wet roads driving and braking straight twice now at low speeds (less than 20mph easily), the most recent time actually hitting a car adjacent. Very minor damage, but the fact it happens at all is disturbing. ABS light is on at the moment, but the car fishtailed previously before it came on.
I have driven pickups 2 decades, have an older f150 which while it can be made to skid on wet roads braking, has never shifted horizontally on such skids, and am wondering if this is simply a design feature of the tundra or if there is something I can do (tires I assume) to make the vehicle stay straight when braking.
Any help or questions appreciated!
Woofdog is offline
post #2 of 9 (permalink) Old 10-12-2009, 11:28 AM
jpnca's Avatar
any weight in the back? may help
Tundra Dbl cab
5.7 4X4
OME Ft susp
Bilstein Rr shocks
Air Cell bumps
TRD Intake
TRD duel exhaust
TRD rims
G-Tec preformance Sils
305/65R18 BFG KOs
N-Fab light bar w/ PC H11 lights
jpnca is offline
post #3 of 9 (permalink) Old 10-12-2009, 11:35 AM Thread Starter
no weight, the vehicle is almost always empty in back. Do other tundra owners have similar fishtail occurences? It also can happen if I give the car gas right after a turn, though only a small horizontal shift in back unlike when stopping.
Woofdog is offline
post #4 of 9 (permalink) Old 10-12-2009, 11:47 AM
Jesco's Avatar
Quoted: 5387 Post(s)
ABS light is on? Sounds like too much rear brake bias to me.
Jesco is offline
post #5 of 9 (permalink) Old 10-12-2009, 03:32 PM
algolfer69's Avatar
Quoted: 8 Post(s)
Check the wheel cylinders for leakage. If you have drum brakes in the rear, the brake fluid on the shoes will make it lock up.
HAVE A NICE DAY!!!
"That's liable to earn you a Burmese-roundhouse-sphincter-kick with a follow up three fingered eye-jab".
Some Canadien dood.
WHITE TUNDRA CLUB MEMBER #5
algolfer69 is offline
post #6 of 9 (permalink) Old 10-13-2009, 11:13 AM
Is the abs light always on? If so your abs will not work, also what condition are your tires in? Low tread on the tires will make it alot easier for them to lose grip on wet roads. Also what type of tires? I know when I had BFG MT's on my old grand cherokee the rear end would always slid out from under you when their was alot of water on the road.
gmwelder86 is offline
post #7 of 9 (permalink) Old 10-14-2009, 11:30 AM
Tires, and tire inflation pressures, make a huge difference. If it still has the stock ones, those have a "B" traction rating, which is really a wet braking test. Not particularly good.
Under inflated tires also tend to hydroplane, so check that. Sometimes, what is best for dry cornering is not so good in the wet.
Also, the ABS system may have been starting to fail before the light came on. Even on ice, the ABS on our 2005 kept it in a straight line, even with the worn original tires.
nikita is offline
post #8 of 9 (permalink) Old 10-14-2009, 11:40 AM
wildbill23c's Avatar
Quoted: 651 Post(s)
Sounds like you need your brakes adjusted. Its not the truck, its something with the brake system not properly adjusted it sound like.
wildbill23c is offline
post #9 of 9 (permalink) Old 10-17-2009, 06:55 PM
Quoted: 4 Post(s)
Ive seen too many trucks fishtail [including myself] and lose it on wet roads. When the roads go bad and since I dont have weight in the bed I go to H4wd.
2008 5.7L 4x4 CrewMax Salsa Red
Factory options:
- Cold weather package [heavy duty battery, heavy duty starter, heated side view mirrors, de-icing windshield], Fog lights, DRL, Bed liner, 10k Tow package
Mods:
- TRD Supercharger, TRD CAI, TRD sway bar, TRD shifter, Revtek 3/1, 20" Procomp 7031, Terra Grappler 305/55/20, OEM backup camera, Raptor side steps, AVIC 4 headunit, Corsa touring exhaust, Toyota door sills
sensei is offline
