Old 07-10-2009, 06:42 PM   #1 (permalink)
WTVa's Avatar
Working on a new Project...
I don't get over on this board and post as much as others but I still believe in sharing with my Tundra brother and sisters.
I have never been a real fan of some of the silver dash parts nor any of the aftermarket carbon fiber kits out there casue they were just overlays.
So I been doing some research for months on diffrent things and order up some supplies and finally had a few hours to play with a dash piece this morning. Let me know what you think this should be a good alternative to some of the stuff out there plus I do enjoy doing stuff like this too.
I took my time this morning since I wanted to get some extra pictures.
Since I didn't want to just post a thread with out some teaser pics, so here you go for now. I may get time to finish some other parts this weekend if not it have to wait till I have more time. Enjoy .....
--- Edited Added updated pics and some other information w/mini DIY ---
First off the material in question can be gotten offline from multiple source depending of quality and costs (carbon fiber cloth). Like I said I picked mine up for $35.00 a yard and a yard should be plenty to cover most parts on the Tundra unless you run into a problem. I seen stuff as cheap as $12.00 a yeard and as high as $50.00 a yard. So either ask for samples of what you like or get a referal from someone else. The stuff looks a lot better in person applied than sittign on the table from the pics.
I will say the stuff I got looks the closet to carbon fiber that I have seen without it actually being carbon fiber its a synthetic blended/made item and you can actually feel the fiber patern so it makes it more real. As I have said before it also easy to work with since its just a cloth material that you sticking to existing hardware so it confroms properly to the truck parts without to much work. I used 3M 77 to hold the material to the dash part and it seems to be pretty good for the most part. Be sure to try and get the problem corner first so the glue does not stick to fast or re-apply as needed as you take your time in getting things done. Since the products streatchable it makes it easy to pull and tug around the curved parts but like I said make sure you either do them parts first to get a good grip or re-apply when needed. There have been talk of using contact cement to hold this stuff down too but I wait and see how this works in a few weeks, woste case I pull it off and re-apply it.
Well thats it for the materials I used, so I will get onto some pictures and ideas of the steps I took along the way.
Well fist step pull the dash part from the truck I wont go into details there, so if you got any direct questiosn on that just ask. Lots of connectors and snaps so be carefull.
Products I used to perform my DIY:
Dash as I was removing swicthes on the surgery table. all were push clips.
Now its onto pulling the silver face rings and black housings. This pictures shows one of the plastic melted retaining clips that I wanted to show one poped off (Left) and one still on (Right). Remove these with a small flat blade screw driver they will just pop off and the other parts snap out with clips.
Clean dash part with all swicthes and trim rings removed. I also at this time used a good alchohol and water souluion to remove light grease and any possible contaminats on the dash parts before applying glue.
After the 2 light coats of 3M 77 material. let it set a maybe 2 minuites before putting the carbon cloth material on.
Start by smothing things out from the center as you go and pull some of the corner down to stick it down now before the glue starts to dry to quick. you will come back and cut and clean up the cutout after you get the main parts done. You can also see how I handled some of the cut outs by putting slits in the materail with a razor blade and folding it, be carefull in some of the corners and know what parts still be exposed after re-assembly <- small tip.
Reassembly of the dash covers and rings....
Completed project on the sugery table allowing it time to dry before re-install
Other completed pictures after install inthe truck...
Okay thats how its all done, now I got to get some free time to do the other pieces but figured not to hold off showing you guys till I finsihed casue that maybe a while and wanted to give you a idea of what I been working on lately for the Tundra.
If there any questions, or just looking for a different angle picture I may already have it just didn't post it up, let me know.
WTVa is offline   Reply With Quote
The Following User Says Thank You to WTVa For This Useful Post:
cyberjeff (10-07-2009)
Old 07-10-2009, 06:44 PM   #2 (permalink)
Estupido's Avatar
Gameroom cash: $2631368
That looks sweet! I need one asap.
Estupido is offline   Reply With Quote
Old 07-10-2009, 06:54 PM   #3 (permalink)
algolfer69's Avatar
Gameroom cash: $1021208
That looks great bro!!! What did you put on it? We have the same interior.
HAVE A NICE DAY!!!
WHITE TUNDRA CLUB MEMBER #5
algolfer69 is offline   Reply With Quote
Old 07-10-2009, 07:12 PM   #4 (permalink)
westdl's Avatar
Nice. I Gotta Have It!!!
08 Tundra 4x4 D-Cab SR5
Salsa Red Pearl
5.7L DOHC 32v iForce V8
381HP/401 Lb-Ft
Engine Immobilizer
Alarm activated
Auto LSD
Rear Diff w/10.5" Ring Gear
Tow Package
Sliding Rear Window w/Privacy Glass
Front Windows Tinted
Clear Bra on Hood, Front Cap, and Front Door Pillars
Brushed Stainless Steel Stepboard
Tire Pressure Monitoring System
Line-X bedliner
These are nice for Colorado...
Remote Start
Heated Mirrors
All Weather Mats
westdl is offline   Reply With Quote
Old 07-10-2009, 07:34 PM   #5 (permalink)
jggazzola's Avatar
you got all the switches under your wheel, someone is organized
Giovannino Guiseppe Gazzola
Ontario, Canada
SOUTHERN ONTARIO TOYOTA TRUCKS - SONTT
jggazzola is offline   Reply With Quote
Old 07-10-2009, 08:32 PM   #6 (permalink)
Slate CrewMax's Avatar
Very nice, looks like real carbon fiber.....
Slate CrewMax is offline   Reply With Quote
Old 07-11-2009, 09:49 AM   #7 (permalink)
WTVa's Avatar
Updated first thread with more information and picture to share...
Old 07-11-2009, 10:14 AM   #8 (permalink)
algolfer69's Avatar
Cant wait to see it when the rest is completed, nice job!!!
HAVE A NICE DAY!!!
Old 07-11-2009, 10:17 AM   #9 (permalink)
Banned in all 57 States
Beericus's Avatar
Gameroom cash: $1000002885
nice work man.......................
Beericus is offline   Reply With Quote
Old 07-11-2009, 12:02 PM   #10 (permalink)
richard14's Avatar
Send a message via Yahoo to richard14
Real nice. How long did it take to complete i wanna do this
08 dc 4x4
Flowmaster 40 series Dual out the back
Fat Bobs Garage 3/1 kit
Black Headlight mod
richard14 is offline   Reply With Quote
Old 07-11-2009, 01:16 PM   #11 (permalink)
Moderator
jpnca's Avatar
did you need to add wire when you moved your switches? I was thinking about moving them the other direction.
Old 07-11-2009, 01:25 PM   #12 (permalink)
"The Boss"
your truck has peices i've never seen before!! lol awesome write up tho!!
tundra357 is offline   Reply With Quote
Old 07-11-2009, 08:08 PM   #13 (permalink)
Nice work. It looks good.
bonkers4ever is online now   Reply With Quote
Old 07-11-2009, 10:58 PM   #14 (permalink)
catalyst105's Avatar
Can you post a link to where you got your material? I'm gonna have to do this for sure. Thanks WT for yet another great mod and DIY.
_______Cardomain_______
catalyst105 is offline   Reply With Quote
Old 07-12-2009, 12:17 AM   #15 (permalink)
WTVa's Avatar
Like I said I only done this one piece so far to get a idea on how well it hold up and how well the material was going to look once its set. I will say today noticed I need a little more glue in a few places. I had some say try super glue in some of the tight corners but I still need to test that. I think this would of been the hardest piece since the curves and cut outs. My best guess is 1.5hrs - 2 hours.
No all my switches moved without extending any wires and if memory serves me right if your going the other way your set since the wires come more from that direction.
I was actually going to get it from this one company cause of great reviews from other on other than toyota forums but they been out of stock for weeks to months, so I found a guy on ebay offering what looks to be the same stuff so I figured I try it first and see if it looks good. I will PM you the link since I actually end up buying from the seller direct via paypal and he shipped very quickly. I also found anothe source that looks real promising for just 12.00 or so a yard which is better than my last 35.00 a yard price I got.
Sponsors
