Slip Indicator coming on at highway speeds? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 45 (permalink) Old 04-13-2017, 08:34 AM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Sorry if this is in the wrong spot, I didnt know exactly where to put it. I just got new wheels and tires the other day along with an alignment and now when i punch the gas moving from the on ramp to the highway the slip indicator comes on and the traction control or whatever engages.
I tried searching this but everything i found talked about having to do a zero point calibration if i got the truck lifted but my suspension is stock. I went from the factory platinum 20" wheels and tires to 18" wheels with 275/70r18's. Do i still need to do a ZPC?
Platinum Member #51
chaded is offline
post #2 of 45 (permalink) Old 04-13-2017, 08:41 AM
Mickleford's Avatar
Quoted: 38 Post(s)
Wouldn't hurt. Its easy enough to do with a paper clip.
2016 CM SR5 TRD | Silver Sky Tundra Club Member #248
Mickleford is offline
post #3 of 45 (permalink) Old 04-13-2017, 08:48 AM
Mickleford's Avatar
Quoted: 38 Post(s)
Instructions
The Following 2 Users Say Thank You to Mickleford For This Useful Post:
chaded (04-13-2017), Dixon Cider (04-13-2017)
post #4 of 45 (permalink) Old 04-13-2017, 09:04 AM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Thanks for the pdf. Im not sure if im going to tackle this myself or not. Ive noticed my steering wheel isnt straight either with it being off to the right some and when I straighten it driving my truck goes left. If i understand the pdf instructions correctly, the alignment and ZPC would have to be completed together?
Platinum Member #51
chaded is offline
post #5 of 45 (permalink) Old 04-13-2017, 09:20 AM
mendonsy's Avatar
Was your steering straight before you changed those wheels and tires??
07' SR5 DC, 5.7, TRD
Toyota SS steps, ARE MX cap
AMP bed step, DIY underseat storage
Weathertech Floor Liners, Weathertech Vent Visors
Cooper Discoverer AT3s, Techstream
TWACC #7
mendonsy is offline
The Following User Says Thank You to mendonsy For This Useful Post:
post #6 of 45 (permalink) Old 04-13-2017, 09:21 AM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Yes.
Platinum Member #51
chaded is offline
post #7 of 45 (permalink) Old 04-13-2017, 11:31 AM
MallWheeler's Avatar
Quoted: 42 Post(s)
My FJ did that when I had new tires installed,turned out that the tires had to much air in them and that apparently messes with the traction control.
MallWheeler is offline
post #8 of 45 (permalink) Old 04-13-2017, 02:00 PM
mendonsy's Avatar
Make sure the tire pressures are all where they are supposed to be.
Also check to make sure all 4 of the new tires are the same size. Yes, I know, but strange things do happen!!
TWACC #7
mendonsy is offline
post #9 of 45 (permalink) Old 04-13-2017, 02:53 PM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Tires are cooper st maxx's and all the same size. Pressure is at 55 for front and right rear and 57 for the left rear.
Platinum Member #51
chaded is offline
post #10 of 45 (permalink) Old 04-13-2017, 03:37 PM
theoat's Avatar
Quoted: 427 Post(s)
Definitely do the ZPC after an alignment !
I gave my shop the instructions so they could do the paperclip method if all else failed, but they said it wasn't an issue.
theoat is offline
The Following User Says Thank You to theoat For This Useful Post:
post #11 of 45 (permalink) Old 04-13-2017, 03:56 PM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
I must be an idiot because i have been trying this paperclip thing for the past 15 minutes and its not working. I put it in and out 4 times within 8 seconds and no light comes on.
Platinum Member #51
chaded is offline
post #12 of 45 (permalink) Old 04-13-2017, 04:17 PM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
So the first step is to clear the ZPC data. I dont know if that worked because the slip indicator light never came on. So of course i just skipped that step and moved on. Next. So i connect the terminals with the paper clip and turn the ignition ON. Kept the vehicle stable for 1 second or more. THEN it says to "check that DTC C1336 is erased." Now how in the world do I do that!? The lights just keep blinking on the screen and it says "FF" I have no idea what that even means unless it means i Freakin Failed.
Since I have no idea I just assume it is right and turn the ignition off like it says to do next. Did the battery thing and now Im just typing this out because I dont even know if it worked. Lol.
Platinum Member #51
chaded is offline
post #13 of 45 (permalink) Old 04-13-2017, 04:28 PM
mendonsy's Avatar
C1336 = Zero Point Calibration of Acceleration Sensor Undone
TWACC #7
mendonsy is offline
post #14 of 45 (permalink) Old 04-13-2017, 04:49 PM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Is that code supposed to show on the screen or what?
Platinum Member #51
chaded is offline
post #15 of 45 (permalink) Old 04-13-2017, 05:13 PM Thread Starter
chaded's Avatar
Quoted: 22 Post(s)
Okay here is a video of what i am doing. Keep in mind i am not doing the battery disconnect here. Just want to show what the dash lights are doing.
Platinum Member #51
chaded is offline
