AC blowing warm while idling - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 13 (permalink) Old 03-20-2017, 07:02 PM Thread Starter
Quoted: 6 Post(s)
Hi all!
My Tundra just recently started blowing warm/outside temp air while idling. When driving, the AC blows ice cold. I've checked the pressure and everything is within range. Any suggestions? I've seen everything from cleaning the compressor to the clutch fan going out.
2010 Tundra
Speck2190 is offline
post #2 of 13 (permalink) Old 03-20-2017, 07:23 PM
molunkus stream's Avatar
Quoted: 13 Post(s)
Have you Tried blowing compressed air through the condenser. Sounds like a lack of air flow
molunkus stream is offline
post #3 of 13 (permalink) Old 03-20-2017, 07:47 PM Thread Starter
Quoted: 6 Post(s)
I've thought about that or running water through it. Where is the condenser on a 2010? I've looked online but can't really get a good answer.
post #4 of 13 (permalink) Old 03-20-2017, 10:28 PM
Quoted: 510 Post(s)
Originally Posted by Speck2190 View Post
Hi all!
My Tundra just recently started blowing warm/outside temp air while idling. When driving, the AC blows ice cold. I've checked the pressure and everything is within range . Any suggestions? I've seen everything from cleaning the compressor to the clutch fan going out.
2010 Tundra
Obviously not
l1tech is offline
post #5 of 13 (permalink) Old 03-21-2017, 08:10 AM
Quoted: 8 Post(s)
When mine blows warm at idle it's always low on Freon. I just put a can of AC Pro in it, I've been doing that every summer for the past 3 years. If you happen to over fill it the compressor will stop working and all you need to do is bleed some Freon off.
200K+ is offline
The Following User Says Thank You to 200K+ For This Useful Post:
Speck2190 (03-21-2017)
post #6 of 13 (permalink) Old 03-21-2017, 01:17 PM
Mickleford's Avatar
Quoted: 38 Post(s)
Fan Clutch crapping out on you?
At idle, no air is moving across the condenser to exchange the heat causing the warm vent air. Once you get going, air is moving across the condenser exchanging heat causing cool vent air.
This of course assumes the refrigerant is properly charged.
2016 CM SR5 TRD | Silver Sky Tundra Club Member #248
Mickleford is offline
The Following 2 Users Say Thank You to Mickleford For This Useful Post:
MetalMonkey (03-21-2017), Speck2190 (03-21-2017)
post #7 of 13 (permalink) Old 03-21-2017, 08:24 PM
Quoted: 6 Post(s)
Had this issue on my highlander. Turned out it was a pin hole in the condenser that slowly leaked.
HawkeCRt is offline
The Following User Says Thank You to HawkeCRt For This Useful Post:
Speck2190 (03-22-2017)
post #8 of 13 (permalink) Old 03-21-2017, 09:50 PM
koditten's Avatar
Quoted: 506 Post(s)
The condenser may be incorporated with the radiator. There was a design change in the earlier years.
Follow the A/C pump hoses to the radiator/ condenser to see if you have the combination type( expensive) condenser/radiator.
If you have the conventional type of condensor(<$100),then look for oil stains on the fins. This will tell you if you have a leak.
Report back.
KO
TWAC (formally know as TWAT) #69
Mods:
AIP delete
TPMS delete
Rear camera install
koditten is online now
The Following User Says Thank You to koditten For This Useful Post:
post #9 of 13 (permalink) Old 03-22-2017, 10:00 AM
Quoted: 510 Post(s)
Report back.
I believe that it was the trans cooler and ac condenser that were all in one and not the radiator and the condenser
l1tech is offline
The Following User Says Thank You to l1tech For This Useful Post:
post #10 of 13 (permalink) Old 03-22-2017, 10:19 AM
koditten's Avatar
Quoted: 506 Post(s)
Yep, you are correct. Got them mixed up.
KO
Mods:
AIP delete
TPMS delete
Rear camera install
post #11 of 13 (permalink) Old 03-22-2017, 11:14 AM
Radial GT's Avatar
Quoted: 6 Post(s)
My fan clutch caused this in my old 4runner. New fan clutch, HUGE air change across condenser, and everything worked good after that.
Radial GT is offline
The Following 2 Users Say Thank You to Radial GT For This Useful Post:
MetalMonkey (03-22-2017), Speck2190 (03-22-2017)
post #12 of 13 (permalink) Old 03-22-2017, 03:14 PM Thread Starter
Quoted: 6 Post(s)
I'm going to try this. I cleaned out the condenser and am still having the warm air at idle issue.
post #13 of 13 (permalink) Old 03-22-2017, 03:25 PM
Radial GT's Avatar
Quoted: 6 Post(s)
One way to check it is you know the crazy wind sound it makes when you start the truck cold? It should make a similar sound when it is really hot too. You can rev it when hot and it should make a similar sound of moving air.
