Firestone airbag install - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 32 (permalink) Old 03-18-2017, 10:12 PM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
Finished up the install of the firestone airbags #2445 today. I had to also buy the bracket extenders due to my lift. Ended up going with a "tee" line and fill valve in the gas cap area. Aired them up to 70 and will let sit tonight and see if any leaks. Did the soap test and seemed ok. Really excited to help out with squat when loading up and pulling trailer.
2017 Limited Crewmax TRD 4x4 Super White
6" readylift w/billstein 5100 rear shocks
Fuel Mavericks 20x9 +20
Toyo RT 35x12.50x20
Retrax one mx bed cover
Bedrug bed and tailgate mat
Tows 2017 forest river Cherokee 274dbh
kfcflores is offline
The Following 2 Users Say Thank You to kfcflores For This Useful Post:
Redwoods Jay (03-20-2017), W27 (03-18-2017)
post #2 of 32 (permalink) Old 03-18-2017, 10:28 PM
Quoted: 48 Post(s)
What does the extender bracket do? Is it just extra support from going sideways
edelbrock231 is offline
post #3 of 32 (permalink) Old 03-18-2017, 10:44 PM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
U need them if your lifted. The bracket needs to rest on the axle for proper support. I'm lifted 6"
Toyo RT 35x12.50x20
post #4 of 32 (permalink) Old 03-18-2017, 11:38 PM
theoat's Avatar
Quoted: 412 Post(s)
Install looks nice !
Do you actually need extensions with lift blocks or just shackles?
(I would have thought with blocks the distance from frame to leafs would be the same...
I've got +2 CB shackles....from what I've read I don't need the cradles, but if you go to +3 you do.
theoat is offline
post #5 of 32 (permalink) Old 03-18-2017, 11:42 PM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
Every set up is a little different. If u just have coach +2 probably fine with stock pieces in kit.
Toyo RT 35x12.50x20
The Following User Says Thank You to kfcflores For This Useful Post:
theoat (03-18-2017)
post #6 of 32 (permalink) Old 03-18-2017, 11:53 PM
Quoted: 48 Post(s)
Is that a universal bag or tundra specific
post #7 of 32 (permalink) Old 03-18-2017, 11:53 PM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
Tundra specific kit. No drill install.
Toyo RT 35x12.50x20
theoat (03-18-2017)
post #8 of 32 (permalink) Old 03-18-2017, 11:59 PM
theoat's Avatar
Quoted: 412 Post(s)
I wonder how much of a stability difference it makes when you Tee like you did as opposed to having 2 dedicated lines.
I like your fill location. Was it too tight for 2 fill ports or did you like the idea of 1?
theoat is offline
post #9 of 32 (permalink) Old 03-19-2017, 12:08 AM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
I just went with one. There is plenty of room to do two. I've read people saying not to tee and also read people that have no issues with tee. I can always take out tee and do dedicated valve for each if need be. Here is a pic with 2 in cap area
Toyo RT 35x12.50x20
theoat (03-19-2017)
post #10 of 32 (permalink) Old 03-19-2017, 02:58 AM
DIABLODALTON's Avatar
Quoted: 44 Post(s)
Extension kit part#?
Do you know the ext kit part #?
BLACK SUNSHINE - 2017 CrewMax TRD Supercharged
BIG RIG CLUB MEMBER #56
Thank you to our Active Duty Military and Veterans... ALL GAVE SOME AND SOME GAVE ALL!
SEMPER FIDELIS!!!
DIABLODALTON is offline
post #11 of 32 (permalink) Old 03-19-2017, 07:42 AM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
The part I needed was #2508 . Got mine on amazon for $50 shipped.
Toyo RT 35x12.50x20
post #12 of 32 (permalink) Old 03-19-2017, 10:37 AM
Quoted: 48 Post(s)
Where'd you get the full kit from? I keep finding ones but are bolt in and have extra crap and are like 400
post #13 of 32 (permalink) Old 03-19-2017, 10:56 AM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
Amazon
Toyo RT 35x12.50x20
post #14 of 32 (permalink) Old 03-19-2017, 12:03 PM Thread Starter
kfcflores's Avatar
Quoted: 57 Post(s)
UPDATE!!! Went out and checked pressure today and had dropped from 70 to 60. Did the soap spray again and caught bubbles at one of the fittings at the tee. Tried to push in for better deal but still bubbles. Let all air out. Disconnected fitting..cut again and re inserted. Filled back up did soap test and no bubbles. Should be good now.
Toyo RT 35x12.50x20
theoat (03-19-2017)
post #15 of 32 (permalink) Old 03-20-2017, 08:52 AM
RyDane's Avatar
Quoted: 8 Post(s)
I have the same setup less the extension for the lift. I went with the same union tee as well, and think that is the weak point. I had the same logic, if I end up not liking them plumbed together I will run two lines. It seems to be all about the straight cut on the tubing. If the cut is straight it will hold air well. Mine has been @ 5lbs for about 4 weeks now.
Ryan
2016 CM LTD TRD MGM
5100 Mid Setting w/ 1 Shim
275/70r18 Ridgegrapplers
Firestone Ride Rite's in the rear
RyDane is online now
The Following 2 Users Say Thank You to RyDane For This Useful Post:
Redwoods Jay (03-20-2017), theoat (03-20-2017)
