Driveline "bump from behind feeling" - TundraTalk.net - Toyota Tundra Discussion Forum
View Poll Results: Do you have the driveline "Bump"?
Yes 133 82.10%
No 29 17.90%
Voters: 162. You may not vote on this poll
Old 08-13-2008, 11:24 PM   #1 (permalink)
boweebe's Avatar
Unhappy Driveline "bump from behind feeling"
I know this issue has been addressed pretty hard on this site, and I'm very thankful that people have talked about this problem and posted threads and TSB'S on the driveline. They have helped me reslove my "bump from behind" {for now}. Just wanted to give some more FYI, my 08 drive line was replaced with no avail. A thread was posted on removing the boot on the driveline, pulling the spline out of the rear shaft, cleaning and re-greasing the spline with some GM grease and then magic happened, my "bump" is gone! Thanks to all whom took the time to write in and relay all your info on the this issue!
I LOVE MY TRUCK ....AGAIN!
08 Limited 4X4 TRD DC Black.
3"front/1" block back lift.
Volant CAI.
Herculiner
Backup Cam
Motorsport Goliath Chrome Wheels
305/55/20 Toyo A/T
Debadged
Dual 2.25" powersticks
boweebe is offline   Reply With Quote
The Following User Says Thank You to boweebe For This Useful Post:
Mr. Creosote (06-09-2012)
Old 08-13-2008, 11:28 PM   #2 (permalink)
txtundra's Avatar
where are these threads...i think i have the same problem?
2007 Tundra 4x4
txtundra is offline   Reply With Quote
The Following User Says Thank You to txtundra For This Useful Post:
Old 08-13-2008, 11:29 PM   #3 (permalink)
2008_CrewMax's Avatar
i dont think ive had this problem?
White Tundra Club Member #2
The Following User Says Thank You to 2008_CrewMax For This Useful Post:
Old 08-13-2008, 11:30 PM   #4 (permalink)
boweebe's Avatar
Just Back Of The Carrier Bearing. The Black Boot, Inside Of That
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:30 PM   #5 (permalink)
txtundra's Avatar
its real small i stopp at a light than it feels like someones hits you it happened in my last truck too...idk if its the way i drive it or what
2007 Tundra 4x4
Old 08-13-2008, 11:31 PM   #6 (permalink)
boweebe's Avatar
i serached for "driveline" about a week ago and now i can't find them
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:32 PM   #7 (permalink)
txtundra's Avatar
where are the threads on this issue...is this covered under warranty or did you do it yourself...i have an oil chnage coming up and ill have them check t out
2007 Tundra 4x4
Old 08-13-2008, 11:34 PM   #8 (permalink)
boweebe's Avatar
my bump was pretty hard, no clunk or thump but lots of, it seems, movement in the driveline
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:36 PM   #9 (permalink)
boweebe's Avatar
try seaching for "driveline" look hard and i bet you can find them. i had the service tech's do it for me. wish i could tell you where to go look
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:37 PM   #10 (permalink)
boweebe's Avatar
all warranty
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:46 PM   #11 (permalink)
boweebe's Avatar
TSB on driveline
T-SB-0115-08[1].pdf
driveline TSB on 07/08 tundras
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-13-2008, 11:54 PM   #12 (permalink)
txtundra's Avatar
thnx ill have them check it out
2007 Tundra 4x4
Old 08-13-2008, 11:57 PM   #13 (permalink)
boweebe's Avatar
check you inbox txtundra, your welcome! hope it helps
Volant CAI.
Herculiner
Backup Cam
305/55/20 Toyo A/T
Debadged
Old 08-14-2008, 12:23 AM   #14 (permalink)
this is interesting .. i hope i dont have this issue
Old 08-14-2008, 12:39 AM   #15 (permalink)
gadget05's Avatar
I have the same problem on my 05 but i dont have spline style, its all u joints, i pulled the driveline and tried to find somewhere to grease it, even had the driveline removed, replaced one u-joint, and the center support bearing with a better one, seemed ok for about a thousand miles and then it came back after towing my travel trailer. i gave up and just deal with it, dealer told me its normal axle wrap. do i believe them? no
gadget05 is offline   Reply With Quote
The Following User Says Thank You to gadget05 For This Useful Post:
