Old 07-31-2008, 05:49 PM   #1 (permalink)
Extra batterys
Does toyota offer some type of extra battery tray or somewhere to place a second one i am do plowing and i need to have two batterys i have a 2008 toyota tundra db cab with 4.7 towing
ccfd48 is offline   Reply With Quote
Old 07-31-2008, 07:15 PM   #2 (permalink)
Codiac's Avatar
I am not aware of anything like that. Might have to have a fab shop make something for you unless you are handy with that type of stuff and could DIY it. If you do find something post that info on the site so others are aware.
08 Double Cab SR5
5.7 4x4 TRD
Pyrite Mica
IBTO
Mods:
Tinted Windows
Hurst Shifter
Under Seat Storage Box
Toyota Bed Mat
HD Trailer Brake Conroller
G-Tek Door Sill Protectors
International Brotherhood of Tundra Owners Headquarters
Codiac is online now   Reply With Quote
Old 07-31-2008, 07:36 PM   #3 (permalink)
Deznutjob's Avatar
Great idea, once you've established a location for the second battery you'll need to install an isolator switch. This allows you to isolate the batteries from one another until you need the second battery, then all you need to do is flip a 3 position switch on your dash and the batts are combined. Flip the switch to charge position and you can charge the backup batt of your alternator. Flip it back to isolate and the batts are isolated from each other. I set one of these up on my Yamaha rhino cuz of the offroad lights, the sound system with amps and the winch I'm adding. It works awesome! Easy to install too. Check this link.Hellroaring Battery Isolator/Combiner BIC-75300
07 METALIC SLATE DCWWW.IBTOHQ.COM
Old 07-31-2008, 09:01 PM   #4 (permalink)
jpnca's Avatar
Funny I was just thinking of this. I'm (when I get around to it) going to put a 2nd bat in the Wrangler. The one I found stacks 2 Optama batteries. I will see if I can modify it to work in the Tundra.
Old 07-31-2008, 09:32 PM   #5 (permalink)
ramoine's Avatar
Battery Box, Tray and Case | Battery Boxes, Trays & Cases - Remy Battery
https://id211.chi.us.securedata.net/...ducts_id=1 50
Now if you can find a place to mount this stuff .
2008 Crewmax X-SP
carbon Fiber Dash kit
20" JTI Rims
BFG AT KO 285/55/20
Blacked out Headlight Mod.
Flo~Pro muffler #744
ramoine is online now   Reply With Quote
Old 07-31-2008, 09:41 PM   #6 (permalink)
jpnca's Avatar
This is what I'm thinking Mean Green TJ Dual Battery Tray and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
Old 07-31-2008, 10:05 PM   #7 (permalink)
ramoine's Avatar
jpnca , that's nice for saving some room . But where is there room under the hood for any extra battery ?
The engine compartment looks kind of crammed , especially if you have a C.A.I .
Any guess ?
2008 Crewmax X-SP
20" JTI Rims
BFG AT KO 285/55/20
Old 07-31-2008, 10:22 PM   #8 (permalink)
Mickey's Avatar
I would have to look. I haven't thought of that.
MIDNIGHT RIDER
AVS Bug Shield
AFE CAI
Borla XS Duals
Tundra Weather Mats
Trail FX SS Nerf Bars
Bully SS Step Bar
Reverse Camera
Fire & Ice LED Light Bar
Herculiner
Hellwig Anti-Sway Bar
Extang Black Max
Eurodezigns HID Lights
TRD Shifter
XM Satellite Radio
Samsung MP3
Locking gas cap
DEBADGED
DEER SLAYER
Back In Action
IBTO
Mickey is online now   Reply With Quote
Old 07-31-2008, 10:25 PM   #9 (permalink)
jpnca's Avatar
When I get it I'll see if it will fit. I'll also keep an eye out for other types
Old 07-31-2008, 10:34 PM   #10 (permalink)
ramoine's Avatar
Please post some pics too , it would be a great mod ! Thanks .
2008 Crewmax X-SP
20" JTI Rims
BFG AT KO 285/55/20
Old 07-31-2008, 10:43 PM   #11 (permalink)
AZ Pete's Avatar
Before I retired, I drove a 4x4 at work that was set up with a winch. We had two batteries, with a relay that separated them. One battery was dedicated to the winch. The truck kept both charged, but the one dedicated to the winch would not draw the one dedicated to the truck down (which would strand me out in BF Egypt).. A great side benefit to this was that when I occasionally left the radio and scanner turned on during my day's off. I could use the winch battery to jump start the truck (kind of a self rescue), but needed to use jumper cables, between the barreries to do so. The relays are readily available at 4 wheeler shops that deal in winches.
AZ Pete is offline   Reply With Quote
Old 07-31-2008, 10:49 PM   #12 (permalink)
Deznutjob's Avatar
An isolator switch is what is used in setups like this, go back and read my post then check the hellroaring link. Sounds like the setup in your old work truck was just that, old. The isolator switch is the way to go.
Old 07-31-2008, 11:54 PM   #13 (permalink)
jpnca's Avatar
kinky............. you can jump yourself
Old 07-31-2008, 11:56 PM   #14 (permalink)
jpnca's Avatar
With one of these you don't need cables
Perko Battery Switch - 8501DP - BoatersWorld.com
Old 08-01-2008, 01:32 AM   #15 (permalink)
Deznutjob's Avatar
The bummer with this one is where the heck you gonna put it? Where ever you put it you have to route all the battery cabeling through it. The Hellroaring has a remote 3 position remote micro switch with a red and green diode.
