#2 (permalink) | |
MIDNIGHT RIDER ![]() 07 Crewmax Limited Nautical Blue AVS Bug Shield AFE CAI Borla XS Duals Tundra Weather Mats Trail FX SS Nerf Bars Bully SS Step Bar Reverse Camera Fire & Ice LED Light Bar Herculiner Hellwig Anti-Sway Bar Extang Black Max Cosmos Dynamics Halo LED Projection Eurodezigns HID Lights TRD Shifter XM Satellite Radio Samsung MP3 Locking gas cap DEBADGED Blackened Grill IBTO
Have a SR5 or a Limited? You could just leave the head lights on all the time.. They will turn off 30 sec after turning off / locking up the truck.
![]() 07 5.7L Sky Silver Double Cab -EGR Vents/Bug guard -TRD Sway bar -Corsa Touring Exhaust -Charcoal filter delete |
As a fellow canuck, I couldn't help but notice that the "daytime running lights" on my truck, purchased in Canada, are actually the park lights (or whatever term they're using for the outer lights), they are not the headlights. I was wondering if mine was faulty, then I started noticing the other Tundra's in town, and they are the same. Just thought you should know.
![]() 2008 Tundra TRD Double Cab Slate Metalic Aries Step Bars Bac-Flip Tonneau Cover |
#5 (permalink) | |
Its because amber is very easy to see and stands out more than "white" headlights. I can spot another Tundra a mile away.... literally. |
#7 (permalink) |
I agree with you Dale124 . My American bought Tundra has the amber running (front) lights on at all times during engine operation too. And as you pointed out, it seems that "all" Tundras are wired this way.They are.Many minivans have similar running amber lamps. The wiring is normal as per DOT regulation.
#8 (permalink) | |
Attached is a PDF file which you can use to enable your DRL using the Turn signal lights the way the factory has them set up. Hope this helps you out. Frank |
#9 (permalink) | |
