#16 (permalink) |
The Tundra rear is an open diff, if the traction control system notices wheelspin it will decrease throttle and apply brake to the spinning wheel to transfer powerto the wheel getting traction. You can turn off the throttle pull back by hitting the button once and turning on only the Auto LSD. You can turn off the Auto LSD by holding the button down for three seconds. In a 4wd you can only turn off the Auto LSD in 4wd, no "one wheel peels" in a 4wd
#17 (permalink) |
That's where I get lost. An open differential won't transfer power to the other tire....but somehow the tundra does, whether it be from the brake or some other force of nature. This rear end is just so confusing!!
07 DC Limited 4x4 TRD Tundra 00 S-10 Xtreme Race Truck |
#18 (permalink) |
![]() They do spin pretty easily .
#19 (permalink) | |
08CMAX C.M.T.T.F.F. 2008 Crewmax SR5 Billet Grill 20" ProComp Wheels Toyo 35s 6" ProComp Lift TRD Air Intake TRD Dual Exhaust |
#20 (permalink) |
ramoine -- did your truck feel weird after that burnout? How fast did you get the tires going? I did that once, up to 4th gear and had a weird scrubbing when turning after that. It lasted about 1 minute. I saw another post on here, where the guy had to reflash his vsc computer???????
07 Tundra DCab 4x4 SR5 TRD 5.7L, Leer 180R shell, BFG AT KO LT285-65-18 85 VW Westfalia Vanagon (w/ locker and granny gear) 56 VW Ragtop 04 Honda Accord (wifes car) |
#21 (permalink) | |
#22 (permalink) |
If someone doesn't mind, can you give a basic details of what happens with those 2 buttons (RSCA Off, and the car with the swigily lines), when you activate them seperately as well as together. What do they change on your truck and when is a good time to use them. I have read through the manual a few times and it still doesn't make sense.
07' 5.7 DC Limited - Silver Sky Metallic Electric Retractable Tonneau Cover - Pace Edwards Line-X Spray in bedliner Sportz Truck Tent III Sacramento, CA. |
