Limited Slip Differential???? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 8 (permalink) Old 02-02-2008, 03:32 PM Thread Starter
Question Limited Slip Differential????
I have a simple question that I cannot get a straight answer to. Does my 2007 Tundra have a limited slip differential? The window sticker clearly states that as standard equipment it has “Automatic Limited Slip Diff (Auto LSD)”. The truck behaves like it is using the antilock brakes to apply the brake to the slipping wheel. The owner’s manual reads like that is using the brakes. I emailed Toyota’s “Ask Toyota” and they responded with a vague answer and quoted the owner’s manual. I don’t think the dips**t that responded even knows what a differential is or where it is located. Ford has a thing they call “traction assist” and it explicitly says that it uses the brakes to control wheel spin. I have used this same technique on farm tractors for 30 years! Tractors can brake wheels individually, whereas cars could not until they came out with advanced antilock brake systems.
Today, I had my Tundra serviced at the dealership where I purchased it. I got into an argument with both the assistant service manager and the parts manager about the differential. They just quoted Toyota literature, which all pointed back to the brakes. The parts manager could not show me anything in the exploded view of the rear axle that would constitute a limited slip. No clutches, no viscous couplers, nothing! Their mechanic agreed with me how by using the brakes you could control slip, but since no one at that dealership has taken a Tundra rear end apart, nothing could be confirmed.
I lifted the rear wheels off of the ground. The transmission was in park so the drive shaft was locked. When I rotated one wheel, the other wheel turned in the opposite direction with no resistance. This is a characteristic of an open differential (not limited slip and not a locker).
I don’t mind “traction control” or “traction assist”, but I will not tolerate the wording “Limited Slip Differential” if there is nothing in the DIFFERENTIAL that can control wheel slip! If no one can prove that this differential has a limited slip then I would like to see a class action lawsuit against Toyota for blatant false advertising!!!
Does anyone out here in TundraTalk land know for a FACT about these differentials?
Larry is offline
post #2 of 8 (permalink) Old 02-02-2008, 03:43 PM
Our diffs are open, you will find it common practice for manufacturers now days to refer to brake activated LS as LSD.
In our trucks we have TRAC, which is a type of brake activated LS that works in normal mode(no button pushed), TRAC can and will cut you throttle the same as VSC does.
Push the button once and TRAC is turned off and A-LSD is turned on. A-LSD does not cut your throttle, but it does have speed restrictions and Toyota doesn't want us to drive with it on all the time.
Push and hold the button and everything is turned off, although VSC will still engage in severe conditions.
In 4WD we have A-TRAC, A-TRAC works like A-LSD only it works on all 4 wheels.
In 4LO A-TRAC provides more brake pressure so it works a little better.
2007 DC 4X4 Limited
TRD,Tow,NAV
Afe CAI, Xcelerator Exhaust
275/65/18 BFG AT/KO
Desert Sand
Skyhammer is offline
post #3 of 8 (permalink) Old 02-02-2008, 05:29 PM
I agree with term Auto LSD is extremely deceptive, shame on Toyota. It is an open diff, no mechanical LSD. My '06 has a Torsen LSD that is tuned beautifully. Other than cost, I don't know why it would have been discontinued. I prefer traction devices like LSD's for vehicle dynamic performance benefits over brake/fuel intervention methods.
hypersonic is offline
post #4 of 8 (permalink) Old 02-03-2008, 07:31 AM
RunItHard's Avatar
The auto-limited slip differential in the Tundra is not a mechanical lock-up "positraction" differential that you're probably thinking about.
The Tundra uses electronics and the breaking system to alternately break the slipping wheel and send power to the one with the most traction. It's somewhat deceiving for those of us who have had true positraction differentials in the past, but it is a pretty effective system none the less.
The same is true for the Tundra 4x4's. While in 4x4 mode you're not actually driving with 4 locked-up hubs.
RunItHard is offline
post #5 of 8 (permalink) Old 02-03-2008, 04:47 PM
Best way for burnouts? push button or hold button till everything is off?
'07 RCSB 4x4, 5.7. Much Faster than my modded Hemi was. Insulated intake & box. Drop in K&N. Removed top filter. Bypassed TB coolant hose to keep intake cold. Valve cover hoses to breather, not intake. 305-50-20 Yoko's on 20 x 9 chrome MB 5 spokes, Debadged, More to come...
WANT TUNER!
Mark-5.7 is offline
post #6 of 8 (permalink) Old 03-07-2008, 08:11 PM Thread Starter
Does anyone know if a true limited slip differential is available for the Tundra?
Larry is offline
post #7 of 8 (permalink) Old 03-07-2008, 08:33 PM
sxd45's Avatar
you would just have to put a detroit,an auburn or a eaton posi in it, I will check some sites to see if they make one yet.
White Tundra Club Member #1
sxd45 is offline
post #8 of 8 (permalink) Old 03-07-2008, 09:16 PM
djb383's Avatar
When one becomes available, I would much prefer to have a locker vs LSD. I installed a PowerTrax No-Slip locker in my old Silverado, only took about 2 hours....... and it was awesome. A locker is essentially a streetable (sp) spool.
djb383 is offline
