Rear End Gearing 4.30 vs? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 4 (permalink) Old 01-30-2008, 02:31 AM Thread Starter
Question Rear End Gearing 4.30 vs?
I noticed that some Tundra's have the 4.30 gearing I believe and they get better gas mileage than the others. At lest 2-3 gallons per mile according to the sticker.
What other gearing is available?
Was wondering for those that have the 4.30 rear end do you see better gas mileage?
NARC_TUNDRA is offline
post #2 of 4 (permalink) Old 01-30-2008, 05:40 AM
Pretty sure the tow package option on the 5.7 comes with 4.30 gears and the non tow package 5.7 come with 4.11 gears
redlines is offline
post #3 of 4 (permalink) Old 01-30-2008, 02:01 PM
Impelled's Avatar
Usually the higher the gear the lower the MPG. But the higher gears gives you better towing from a stop, better holeshot, but lower MPH also. The 6 spd tranny in the 5.7 Tundra helps boost MPG. Just thinkin back to my drag racing days
07 SR5 DC 4WD TRD
09 Corolla XRS
Impelled is offline
post #4 of 4 (permalink) Old 01-30-2008, 06:53 PM
Ahhhh...gear ratios!! The higher the gear ratio number the more gear reduction there is. 4.30 gear ratio means that the pinion gear will turn 4.3 revolutions to turn the wheels 1 revolution in a straight line. 4.3 gear ratio is a fairly low gearing. This helps with towing but it doesn't help with MPG. The Tundra has a 6 speed tranny to give you a wide range of gear ratios between the engine and final drive. The final drive gear ratio will never change but the engine won't have to rev so high to achieve the 4.3/1 revolutions of the wheels. Thus the 6 speed tranny with it's wide range of ratios helps with MPG while still being able to tow well. Below are the gear ratios for the Tundra. You can see that in 4th the engine and trans output are turning at the exact same speed. Then in 5th and 6th OD the trans output is actually turning faster than the engine, thus increasing MPG. Hope this helps explain gear ratios and how they work a bit.
5.7-liter with 6-speed ECT 1st3.333 2nd1.960 3rd1.353 4th1.000 5th0.728 6th0.588 Reverse3.061 Rear differential ratio/size (in.) 4x2 and 4x4 - Standard or Maximum Payload Package or Sport Appearance Package4.100/10.5 in. 4x2 and 4x4 - Tow Package4.300/10.5 in. Transfer case, high/low (4x4 only) 1.000/2.618
2304 is offline
The Following User Says Thank You to 2304 For This Useful Post:
ZoSo (02-21-2012)
