#91 (permalink) |
I need to add a warning to this one. Don't use a 6 quart plastic catch pan for 7 1/2 quarts of oil. I caught it in time to stop the overflow, but the container was full. In the process of dumping it into my 5 gallon container, it buckled a little in the rear, basically destroyed my $150 running shoes with oil. Hell, it was time for a beer with that screw up. The truck part went great. Thanks for the info.
08 Tundra DC, 4X4, 5.7, Tow Package. |
#92 (permalink) | |
#93 (permalink) |
Black and white sneekers.
Asphalt Camo!
2006 Tundra replaced a 98 Dakota 3.9 automatic, long bed. Retired with broken A/C, July 2008. 623,000 miles. On original engine and transmission, using Amsoil by-pass filters and lubrication. +Everybody knows something you don't know. +Truth does not need to be 'balanced' and it ain't caused by voting or consensus or polls or yelling louder or silencing someone. +Artists prove truth can be in forms you don't understand. |
#94 (permalink) |
I'm in the middle of an oil change and have a small rubber o ring that I don't know what to do with?
I got the Fram filter and it has 1 large rubber o ring and a small rubber o ring and this white plastic thing that I still haven't found a place for. The stock doesn't have this little rubber o rong that I can find. |
#95 (permalink) |
It is entirely possible nothing is wrong.
May be that those are for other vehicles that use that filter.
#96 (permalink) | |
Orings
![]() ![]() Yeeman15 08 Silver 5.7 DC SR5 4x4 K&N Stock Replacement Air Filter Stant 10504 Locking Gas Cap |
#97 (permalink) | |
#98 (permalink) |
My First Oil Change Experience
I just changed the oil on my RCSB 5.7 at 4,000 miles. Because of info like the instructions on this forum, the job was fairly easy. It wouldn't have been so easy otherwise. First, the skid plate was a little awkward but it the complaints seem overrated. I didn't have any trouble removing or re-installing it other than the time working with the excessive number of screws and bolts. The picture showing which holes that the "hooked brackets" fit into was very helpful for the re-install. The statements that the oil drains quickly towards the passenger side tire/wheel and makes a mess are understatements. The oil covered my tire with oil!! The next time I do this, I'm going to cover the tire with a plastic bag or something.
Some have said that the oil drain plug (bolt) doesn't have a washer but there is a fiber washer that stayed stuck to the oil pan. Mine was in good shape so I re-used it but I may change it next time. I used a Purolator filter purchased from Pep Boys that came with a "screw on" oil filter drain. It worked good to easily drain the filter assembly. Next, removing the filter housing requires a good filter wrench. The KD tools wrench worked well but I had to tap it into place because it fit pretty tightly. I don't know how anyone could remove the housing with a plastic tool because I had to apply quite a bit of force to break it free (get the KD tools #3253 or equivalent). With the filter removed from the housing, I saw some small metallic particles but they were extremely hard to clean from the filter housing. The filter slips over a perforated tube that is held in place by brackets on the bottom of the housing. The metallic particles under the bracket were a living hell to get to. Another problem was that the holes in the perforated tube were not machined smooth so small pieces of the filter broke loose when I slipped on the new filter. I cleaned these as best that I could but a dealer certainly wouldn't take the time to do this. Consequently, the particles would probably cycle through your engine at least once until they burn up or are caught by the filter after they're circulated. This is a ridiculous design idea. It may be better for the environment, but it's at the expense of the protection to your truck's engine. Anyway, the assembly went back together pretty easy and I filled the truck with Pennzoil Platinum. By the way, I don't particularly like Walmart, but the oil there is much cheaper than anywhere else that I've found (another fact that I learned in these forums). I got the Pennzoil for about $4.00 per quart vs about $6.99 everywhere else I looked (Mobil 1 was much cheaper there too but I've had good luck with Pennzoil in the past). All in all, the job took me about 1.5 hours and will only take about 0.5 hours next time now that I know what to expect. |
#99 (permalink) |
Hi everyone, I asked my wife to take my truck and get the oil changed at our normal place (not the dealer). They changed the oil but not the filter. They didn't have one and they told her it wouldn't be a big deal. I didn't want to go to the dealer because I took the carbon filter off and I didn't want to glue it back on just for an oil change. Other then adding the filter my self, What do you guy's think I should do? I have an 07 crew max btw.
#100 (permalink) | |
#102 (permalink) |
Its probably ok to not change the filter every time if you are going 5000 miles or less between changes. This new filter design has a bigger element than the tiny spin on filter that Toyota used in the past. Honda only requires it every other oil change. Toyota technically requires it. Did the invoice for the oil change specify that the filter was not changed?
#103 (permalink) |
as cheep as these filters are, youd be dumb not to change it every time.........
2008 DC, 4x4, TRD 5.7L * 2.4 Ready-Lift, Airaid intake, Lorado tonneau cover * 305/55/20 Mickey Thompson Baja ATZ's on 20'' Ultra Goliath's and 285/65/18 BFG AT's on stock TRD rims * grille surround, door handles, and tailgate handle painted to match body, black headlight mod * Alpine CDA-9857, Kicker KX600.1, Rockford 450.4, Kicker Resolution 6.5'' components front and rear, Kicker 12'' L7
#105 (permalink) |
oil draining from a 12 inch lift makes it SUPER MESSY.... i had splash radius of like 5 feet around the oil catch!... then that plastic thing that drains the filter popped out cause i put an o ring on it and the existing one was there also ..and that made even more mess... this is the worst oil change EVER!
