Im looking to replace my headlight bulbs on my 2014 crewmax.i looked at it quick today and theres a peice attached to the headlight were the bulb is ,im guessing this is the headlight ent motor .does anyone know how to change the bulb or have a link to a video or something
Its pretty easy but more work than on other vehicles. You have to pull the headlight out to get to the bulb. To do that you have to remove the grille held in by i think 4 bolts and 2 push pins. Then you can pull it out. Then remove the plastics from below the light. They are just clamped in. Then there are three bolts that hold the light 2 on top and one on bottom i believe. from there you can remove the bulb
This video is for installing drl's but it shows how to do eveything up to taking the headlight out
hmmm...well just type in youtube "2014 tundra led install" when i typed it in it was the 3rd video the 1st one that didnt say ad. But yeah my only issue doing it was pulling the grille i didnt want to break any tabs or crack the plastics so i watched the video and you just tug it out. I was worried though because i felt like i was pulling it hard already. But it came out fine with a quick hard tug
This, you don't need to remove the head light at all. Unless you're installing a LED with a huge heat sink as I couldn't get the LED's into mine because of the heat sink size.
i heard theres not much space doing it that way so i didnt even try that. but i was also installing hids so i want to have more space and be able to see everything
none of mine broke but either way will work and i didnt want to get into it and find not having enough room to work so i went through the front. but either way
You are right there isnt much room with inner fender way. I will be doing some wiring here soon I have 3 amber LEDs to install on the grill on the hood on my 2014. And I might put some clear led strips under my headlights
So if im just changing the bulbs out i should be able to take the inner fender plastivs off and get access to the heaslight ?it looks like i def need to do that to get to the fogs .im hoing to get the sylvania xbe bulbs ...are they any good ?
Yes I have a 14 also and I have a little black relay or motor for the head to adjust them ..
