2007 Tundra Fuse List by Electrical System - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 13 (permalink) Old 10-16-2007, 01:14 AM Thread Starter
When I looked through the “Owners Manual” that came with my truck, I couldn’t find anything that I would consider helpful if I were stuck on the side of the road trying to troubleshoot a blown fuse problem.
What fuse does what?
What fuses provide current to which electrical systems in the truck?
I had no clue and Toyota doesn’t seem to want to share that info in the Owners Manual.
I wanted this information so I took the time to do this myself.
At the bottom of the page you should see a PDF File. Click on it.
This file contains a complete list of all fuses that can and do affect “each electrical system”.
For instance, lets say your Air Conditioning went out on your way to Disneyland with a Crew Cab full of grand kids in late August.
All you need do is look up “Air Conditioning” and you will find any of four different fuses could be your problem, and only two of them are labeled A/C!
The other two fuses that could cuase you’re A/C to not work are labeled “ECU-IG No.1” and “HRT”. (Kinda descriptive I Know! LOL)
Anyway, you will find a table, By Electrical System, listing every fuse that can affect the each of the electrical systems on your 2007 Tundra. Included in the list are Fuse Amp Rating, Toyota Fuse Name, and Location of Fuse Box.
(There are two fuse boxes, one in the engine compartment, and the other near the drive's side kick panel inside the cab.
I believe this list is 100% accurate as I traced every schematic in the Tundra Electrical Diagrams to create it. I have triple checked this information.
That said, I have been known to make mistakes from time to time, PLUS when I received my EE degree electricity flowed from Negative to Positive. (Guess they fixed that error in these new trucks!)
If anyone finds an error I would greatly appreciate you pointing it out to me so that I can correct this file.
I plan to print this list off and keep it in my glove box (Lower one. I use the upper one for gloves! LOL)
Perhaps some will find this list useful.
God Bless,
Frank
Daless2 is offline
The Following 7 Users Say Thank You to Daless2 For This Useful Post:
5.7Barcelona (03-17-2012), bschuler (11-28-2010), grelder (08-06-2013), jefferychappell (08-28-2011), jon1996 (03-25-2012), RadiantRedTRD (06-27-2013), waveleft (03-24-2012)
post #2 of 13 (permalink) Old 10-16-2007, 01:56 AM
RunItHard's Avatar
Thanks Frank!
Frank
Frank,
Thanks from all of us for taking the time to map out the fuses and share it with us. As you indicated, this information can be very useful to us truck guys.
Thanks again
RunItHard is offline
post #3 of 13 (permalink) Old 10-16-2007, 09:41 AM
I've filed it. Thanks
BlackMax is offline
post #4 of 13 (permalink) Old 10-16-2007, 03:19 PM
daytripper's Avatar
Thanks. I guess I could go outside and get the owners manual but I will ask the question. Where are the fuses located in 'Kick Plate"
daytripper is offline
post #5 of 13 (permalink) Old 10-16-2007, 08:30 PM
JackMS's Avatar
Printed this out this morning and put in my "glove" box. Great job. Toyota should buy this from you for their owners manuals and there techs. Would make a great quick reference section in the manuals. Thanks.
2007 Tundra D/C Ltd 4wd
2005 Tundra D/C SR5 2wd
2004 Sequoia SR5 2wd
JackMS is offline
post #6 of 13 (permalink) Old 07-17-2009, 06:37 PM
So which fuse is the parking lights or headlights?
dociledragons is offline
post #7 of 13 (permalink) Old 11-23-2009, 01:43 AM
Sorry to bring up a dead thread, but can someone PM me this file? I was unable to save it. Still trying to figure out an issue with my door chime so I want to just pull the damn fuse! Thanks.
nocoast is offline
post #8 of 13 (permalink) Old 11-23-2009, 08:37 AM
mendonsy's Avatar
I believe that there is something wrong with the server. All the PDF files seem to be locked.
07' SR5 DC, 5.7, TRD
Toyota SS steps, ARE MX cap
AMP bed step, DIY underseat storage
Weathertech Floor Liners, Weathertech Vent Visors
Cooper Discoverer AT3s, Techstream
TWACC #7
mendonsy is offline
post #9 of 13 (permalink) Old 11-23-2009, 10:37 AM
"Toy Master"
tundratom's Avatar
bump bump. can somebody post this again?
tundratom is offline
post #10 of 13 (permalink) Old 11-23-2009, 09:15 PM
SP
Moderator
SP's Avatar
Quoted: 370 Post(s)
I would like this file too bump!
2014 CM 5.7L 1794 edition
Front tint*OEM look alike Brushed steps*GENSSI® ELITE G7 H4 Led's*morimoto LED fogs(excellent)*interior canbus LED's*Husky Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*LowPro Rollup Tonneau cover*20 inch Black Rhino black wheels*Sotck nit size terra graplers*Bully Dog tuner AWESOME*
SP is offline
post #11 of 13 (permalink) Old 06-29-2010, 09:08 PM
SP
Moderator
SP's Avatar
Quoted: 370 Post(s)
good pdf thanks
SP is offline
post #12 of 13 (permalink) Old 06-30-2010, 06:07 PM
Originally Posted by lotust View Post
good pdf thanks
Nice job. I also found the owner's manual useless when I blew a fuse doing the Info button conversion. I ended up guessing and found the blown one on the third try. I printed this and put it in my owner's manual.
mm49061 is offline
post #13 of 13 (permalink) Old 03-24-2012, 06:25 PM
This is awesome thank you for the time in making it , where would be a good place to hook up an air bag suspension compressor controller ? I am looking for an ignition control empty fuse socket that I can tap into for power ,Do you have any Ideas ?
waveleft is offline
