My Tundra Won't Start, My Record Broken - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 45 (permalink) Old 09-21-2013, 12:35 AM Thread Starter
2011 Tundra 5.7L Platinum CM 4X4, 55k one owner miles, immaculate. Pulled into the hotel tonight where it sat for an hour, then we went to leave and it cranks over but won't fire. Spins like mad and I can get a single cylinder cough or two every now and then, but nada, zip, zilch. It has a half tank of gas. I let it cool down for 3 hours and no change.
One weird thing...the key seems to stick in the start position every couple of tries and the starter seems to be staying engaged unless I key it back off. I wonder if its doing that because it doesn't release until it actually starts, or if its a new an contributing factor.
So my record is about to be broken...this is my tenth Toyota and not one time have I ever had to be towed in. Bad news is I am traveling and have no ability to do any troubleshooting.
Has anyone experienced this?
TX2010Crewmax is offline
post #2 of 45 (permalink) Old 09-21-2013, 12:43 AM
serberus's Avatar
Quoted: 10 Post(s)
I had something similar once but it was due to loose terminal wire on the battery... have any corrosion on your battery terminal that might be causing a bad connection ? Giggle them or tighten them if there loose ?
CAMBURG COIL OVERS, DEVER 5 LEAF + 3" BLOCK, 20" RBP 96R WRAPPED IN 34" BFG KO, PUTCO FRONT WIND DEFLECTORS, MGHLM, DISCONTINUED SHIFT KNOB, TRD CAI, TOW MIRRORS, DEBADGED, DIPPED BUMPERS,ORACLE COLOR SHIFT HALOS, WEATHER TECH DIGIFIT FLOOR LINERS, GOPRO SILVER EDITION DASH CAM
POTOOWA MEMBER #2
serberus is offline
post #3 of 45 (permalink) Old 09-21-2013, 12:47 AM
MaylonTRD's Avatar
Quoted: 51 Post(s)
If its turning over strong then it's not the battery. I had a loose terminal once and it would go completely dead, not even an interior light.
2014 4Runner Limited Blizzard Pearl- Wife's
2014 Tundra SR5 TSS Edition 5.7L
ProComp 6" lift, XD809 18x9 -12 offset, Trail Grappler 35x12.50, Hypertech Speedo Calibrator, Drivers Handle, Coachbuilder Driveline Spacer
MaylonTRD is offline
post #4 of 45 (permalink) Old 09-21-2013, 12:47 AM Thread Starter
First step was to disconnect battery, reconnect and check clamps. All good. Checked every fuse related to fuel and ignition. No luck. It almost has to be fuel pump/circuit related. Weird-a** igntition key behavior is puzzling though.
post #5 of 45 (permalink) Old 09-21-2013, 12:50 AM
serberus's Avatar
Quoted: 10 Post(s)
Try pushing down the gas pedal when cranking it ? Wont fix the problem but might get it started...
POTOOWA MEMBER #2
serberus is offline
post #6 of 45 (permalink) Old 09-21-2013, 12:52 AM Thread Starter
Tried that, no effect.
post #7 of 45 (permalink) Old 09-21-2013, 12:53 AM
Banned
Quoted: 23 Post(s)
Same exact issue this guy had....
http://www.tundratalk.net/forums/tun...ont-start.html
Turned out to be two wires in the bundle to the firewall were grounding the truck out.
prime81 is offline
post #8 of 45 (permalink) Old 09-21-2013, 12:57 AM Thread Starter
Originally Posted by Bad Dad's Tundra View Post
On our trucks, I'm pretty sure once you move the key forward to start, you can release it, but it will continue cranking....a cool feature kinda like our tailgates, open it and let it go
Yep and that's how I start it. But the starter seems to be staying engaged, which I assume is because its waiting to start before releasing. I thought the key was sticking in the start position but its not, just the starter continuing to spin.
If I have wire chaffing at 55k highway miles, it might be Raptor time.
The Following User Says Thank You to TX2010Crewmax For This Useful Post:
serberus (09-21-2013)
post #9 of 45 (permalink) Old 09-21-2013, 01:04 AM
serberus's Avatar
Quoted: 10 Post(s)
Or a rodent problem
POTOOWA MEMBER #2
serberus is offline
The Following 2 Users Say Thank You to serberus For This Useful Post:
MaylonTRD (09-21-2013), MotoPilot25 (09-23-2013)
post #10 of 45 (permalink) Old 09-21-2013, 08:02 AM
WTVa's Avatar
Quoted: 3 Post(s)
Could be immobilizer chip not being seen or the circuit for it. Try flipping the key odd but heard its worked for some folks before. Also look at the dash were the little Key is that shows immobilizer is working but do it before inserting key in the ignition and look again when key is in ignition it should change states fro9m flashing to solid if memory serves me right. If your not seeing a change the key is not being seen by the immobilizer circuit. This maybe why the truck cranks and not actually fire. Just another idea. I would say try your second key but since your traveling you may not have it with you.
WTVa is offline
The Following 2 Users Say Thank You to WTVa For This Useful Post:
MaylonTRD (09-21-2013), SP (09-21-2013)
post #11 of 45 (permalink) Old 09-21-2013, 11:12 AM
scotch's Avatar
Quoted: 18 Post(s)
This. The use of a non-paired key will cause the starter to turn forever until you turn the key off.
2010 5.7L DC TRD 4x4
2005 4.7L 4Runner
Method 20x9 Fat Fives, 305/55/20 Duratracs, Toytec Ultimate, Bilstein 5100, LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc...
Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
scotch is offline
post #12 of 45 (permalink) Old 09-21-2013, 12:13 PM
Quoted: 44 Post(s)
You didn't just have an autostart installed did you?
MontanaTundra is offline
post #13 of 45 (permalink) Old 09-21-2013, 12:17 PM
TAMUTUNDRA's Avatar
Quoted: 87 Post(s)
If you have remote start...did it work?
08 Salsa Red and stuff...
RYRWDBTTBYCDI #18
SALSA RED CLUB #12
TXTC # 102
TAMUTUNDRA is offline
post #14 of 45 (permalink) Old 09-21-2013, 06:06 PM
MaylonTRD's Avatar
Quoted: 51 Post(s)
Did you recently get your keys wet?
post #15 of 45 (permalink) Old 09-22-2013, 09:19 PM
supton's Avatar
Quoted: 56 Post(s)
I hate this feature.
Now when I get into any other vehicle I am always at a loss at why it won't start properly. Then I realize I have turn and hold they key. Three months of owning and now all my other vehicles are "defective."
Darn you Toyota!
2010 Double Cab, 4.6L, 4x4, tow, Brillant White, 129kmiles
2011 Camry, 2.5L 6spd manual, 119k
supton is offline
The Following 4 Users Say Thank You to supton For This Useful Post:
Bad Dad's Camrys (09-22-2013), Cruzrtwdgt (09-22-2013), Powertechn2 (01-12-2015), TundraTigger (03-31-2014)
