Chime Chime Chime!!! diagnosing... - TundraTalk.net - Toyota Tundra Discussion Forum
Old 12-03-2012, 05:59 PM   #1 (permalink)
warrenbeaty2003's Avatar
metallic scratching noise while driving 20 and up. The noise is coming from port side. So far i checked both front and rear rotor linings and they aren't gouged. That's good to know. I only have one car available right now so i can't really start digging into problems, kinda need the vehicle to go to work. This weekend I will start going in-deep in troubleshooting where this noise is coming from. Any ideas? wheel bearing?
http://www.tundratalk.net/forums/tun...un-lovers.html
^^^ My only dignified contribution to this wacky world of Tundra Truck Modding.
IT'S ALL ABOUT WANT! THERE IS NO NEED. Just think about it.
warrenbeaty2003 is offline   Reply With Quote
Old 12-04-2012, 01:15 PM   #2 (permalink)
You drive on any dirt roads?
Could be a piece of gravel stuck in the caliper.
Seen it happen alot up here with different vehicles.
TundraOnTheTundra is offline   Reply With Quote
Old 12-04-2012, 10:41 PM   #3 (permalink)
nope, negative on that bravo leader.
Old 12-04-2012, 10:50 PM   #4 (permalink)
Banned
You hear it more during a curve? Mine did. Ended up being rust on where the backing plate meets the rotor. Dealer fixed for free.
428 78T/A is offline   Reply With Quote
Old 12-05-2012, 05:42 PM   #5 (permalink)
nope. straight driving. driving straight.
Old 12-06-2012, 02:18 PM   #6 (permalink)
Originally Posted by warrenbeaty2003 View Post
metallic scratching noise...
Freddy Krueger?
'I like my women a little on the trashy side" - Georgia Satellites.
______________________________
2012 Tundra Double Cab 4X4 in Silver Sky Metallic
> TRD Off-Road, SR5, and Tow packages
> Westin Step Bars, BakFlip G2 tonneau, K&N air filter, Optima Yellow Top
Aqualung is offline   Reply With Quote
Old 12-06-2012, 02:32 PM   #7 (permalink)
riccnick's Avatar
Year (Make and model if not a Toyota Tundra) cab config, trd package if applicable, mods done to truck, heck even which motor would help my man.
A continuous scratching noise that starts at 20 mph (or kmh?) and continues as speed increases. Does it get louder as you go faster? Change pitch when on/off the accelerator/brakes? My gut is telling me that it could be a cv joint or boot, but the fact that it doesn't change during cornering makes me think otherwise. Where are you located? Even if you don't drive on dirt roads, it still could be some sand from the town sanding the roads you drive one.
I'm Back Jack!
2010 Toyota Tundra DC
5.7l, TRD Off Road, 4WD
Silver Sky Metallic
No Mods....Yet
Gone!: 2012 Subaru Impreza 2.0i Premium
Dearly missed: 2010 Toyota TUNDRA Double Cab
TRD Off Road Pkg. 5.7l iForce V8. Slate Gray Metallic
Flowmaster 50-series muffler / Cat back custom exhaust
HID lights in factory HI/LO headlamps and foglamps
275/65R18 Toyo Open Country A/T
riccnick is offline   Reply With Quote
Old 12-06-2012, 05:42 PM   #8 (permalink)
On my last truck, I had a grinding noise coming from one of the front wheels. It would start at about 20 mph and get a little louder up to around 45 mph, then it would disappear. It would also get louder when I took turns in one direction in the 20-45 mph range and disappear when I turned the other direction in the speed range. It turned out to be a wheel bearing. It's pretty easy to diagnose, just raise the front end (either the whole front end or each corner separately) and spin the wheel in both directions. If it's the bearing, it will make noise, like a grinding noise. It also doesn't spin that freely. If it's not the bearing, it will spin freely and be quiet. On my last truck (an '02 GMC), repair was pretty easy. The bearing came pre-installed in a hub assembly, so all I had to do was change out the hub. Took just a couple hours from beginning the initial diagnosis to completion (time included a trip to the parts store for the hub assembly).
MuellerK is offline   Reply With Quote
Old 12-06-2012, 09:20 PM   #9 (permalink)
Hopefully it's just the dust cover. If you're out of warranty and it's the rear wheel bearing, you're in for a real treat lol.
randomwalk101 is offline   Reply With Quote
