Couldn't get the filter cannister off... - TundraTalk.net - Toyota Tundra Discussion Forum
Old 11-12-2012, 01:34 PM   #1 (permalink)
DJW
DJW's Avatar
Hi all, Did my first DIY oil change yesterday. After draining the oil, and pulling the filter canister plug, I discovered my oil filter canister wrench is worthless (slips off). Soooo, I filled the truck with new oil, but left the old filter in place.
I have a K and D filter wrench on the way.
Question is- If I drain the filter canister now (engine is full of oil), how much will come out? My plan would be to capture the oil in a clean container, replace the filter, then put the oil (which has 40 ft. of driving mileage) back in.
Anyone have ideas?
thanks,
Don
DJW is offline   Reply With Quote
Old 11-12-2012, 01:44 PM   #2 (permalink)
Art64's Avatar
Probably just a quart or not even. The oil filter location is higher than the oil pan.
Art64 is offline   Reply With Quote
The Following User Says Thank You to Art64 For This Useful Post:
DJW (11-12-2012)
Old 11-12-2012, 01:45 PM   #3 (permalink)
Lots of people used to do that, they would replace the filter leave the oil in the engine and simply add a quart of new oil. But I'm pretty sure that would void the warranties these days.
2012 Tundra Crewmax Platinum TRD 4x4
Magnetic Gray on Steel Gray
5100s on all four corners - Bakflip F1 - Bakbox - K&N Drop In - OEM Power Fold Tow Mirrors - Michelin LTX AT2's LT285/55/20
prime81 is offline   Reply With Quote
The Following User Says Thank You to prime81 For This Useful Post:
DJW (11-12-2012)
Old 11-12-2012, 01:56 PM   #4 (permalink)
DJW
DJW's Avatar
Thanks all. That's sort of what I figured. MAN o MAN- this is the worst vehicle to change oil on I've ever owned (25 previous cars/trucks).
Don
The Following 2 Users Say Thank You to DJW For This Useful Post:
kcarel (11-17-2012), SP (11-16-2012)
Old 11-12-2012, 01:57 PM   #5 (permalink)
Big Shasta's Avatar
Wait and replace it with the metal filter housing, the plastic one is junk. It's a toyota part for a venza I believe....a search on here should be easy to find it.
- I'm Ken and I approve this message -
2012 Black SR5 DC 5.7 - TRD SS Steps - 20" Ultra Mammoth Wheels - Nitto Terra Grapplers 285/55-20 - CST Spindles - +2 Shackles - Rear 5100s -
Tint - Ventvisors - Sport Shifter - Line X Premium - Access Loredo Tonneau - White Dash LEDs - BHLM - Oracle Halos - Dirty Deeds BAMuffler SS Exhaust....
Details in "My Garage"
Frequent Yamaha AR230 Jetboat Attachment!
Big Shasta is offline   Reply With Quote
The Following User Says Thank You to Big Shasta For This Useful Post:
SP (11-16-2012)
Old 11-12-2012, 02:31 PM   #6 (permalink)
here you go...I recommend it highly: the Lexus is the same as the Venza one
15620-31060 - Lexus CAP ASSY, OIL FILTER
MikeMc is offline   Reply With Quote
Old 11-12-2012, 09:57 PM   #7 (permalink)
I struggled to get my canister off during my first oil change. Then I noticed a little locking tab that kept the canister from turning. I put a small flat-tipped screwdriver on the tab as I turned the filter wrench and it came right off. Look closely. Mine is a 2012.
"If a man speaks in the woods, and a woman is not there to hear him, is he still wrong?"
2012 Tundra 5.7 Superwhite regular cab long bed 4X4, ARE V-Series cap, Wet Okole Max-4 HD seat covers with lumbar support, Husky Liners, Line-X, tow mirrors, back-up camera
TWACCM # 51
10 ga Bob is offline   Reply With Quote
Old 11-13-2012, 09:26 AM   #8 (permalink)
Don,
You can buy a custom made oil filter too and the metal housing (if you want it) from a guy over at TS.
Tundra custom made Oil Filter tool
Also, 10_ga_Bob is right, the filter housing has a locking tab that needs to be removed.
SteveAustin is offline   Reply With Quote
The Following User Says Thank You to SteveAustin For This Useful Post:
SP (11-16-2012)
Old 11-13-2012, 02:21 PM   #9 (permalink)
DJW
DJW's Avatar
Thanks all. I ordered the K and D tool on Monday, but the one shown at that TS site would have been a better choice. Oh well.
And regarding the locking tab- Where is it exactly? Weird that none of the YouTube videos on changing Tundra oil have mentioned that.
mine is an '07.
Thanks,
Don
Old 11-13-2012, 03:25 PM   #10 (permalink)
mine is an '07.
Thanks,
Don
I don't know if they had the tab on the 2007's. I had one on the 2012 and it was very visible. It pops right off with a screwdriver and I didn't bother to put it back on.
Bad Dad's Tundra (11-13-2012)
Old 11-13-2012, 09:44 PM   #11 (permalink)
DJW
DJW's Avatar
Well, it's done. What a mess, but all cleaned up. I do think there is/was a locking tab, but it looks like the dealer (last to change the oil) bent it out of the way.
The K D oil filter wrench worked great, but boy it took some torque to loosen that thing. And then about 1/3 qt. of oil ran down my arms, even after using the drain thingy.
Next time, Jiffy lube....
Thanks for the help guys!
Don
Old 11-13-2012, 09:53 PM   #12 (permalink)
Don
No don't take it there! if it was that much trouble for you, do you think they'll go the extra mile to make sure it's done right?
07 CM 4x4 / 4.5 RC lift / 20x8.5 rockstar +35mm with no center caps / power steps / paragon bed cover / line X bed / debadged / BHLM / 2010 grille conversion painted satin black / Tinted Tails / Gibson Metal Mulisha catback / fog light kit
In the garage:front camera w/overhead oem flip down monitor
Black Tundra Club Member #181
AZ Tundra Club Member#18
blakbull is offline   Reply With Quote
The Following User Says Thank You to blakbull For This Useful Post:
fosterelli (11-13-2012)
Old 11-13-2012, 10:03 PM   #13 (permalink)
about a 6" piece of hose that fits over the nipple of the drain tool makes the job MUCH easier and cleaner.
I feel spoiled, mine being 2WD, i don't have a skidplate to deal with.
05 Avalon XLS
07 Limited 5.7L 2WD DCRB - billet grille so far....
10 Forest River Salem 25S TT
Ditchhooker is online now   Reply With Quote
The Following User Says Thank You to Ditchhooker For This Useful Post:
Old 11-13-2012, 10:18 PM   #14 (permalink)
Don
If you can do it once, it gets easier. The whole ordeal is more cumbersome and tedious than it needs to be but you'll get faster and more efficient at it.
You could've used a cheater bar to break it loose. The first time I took off the filter housing I thought it was seized up from the factory. The bar and custom wrench definitely made it easier to remove.
There's a neat trick to the oil drain valve. Get a regular sized wine bottle and use the drain adapter with it. Put the drain adapter on the wine bottle and push it up into the valve. The wine bottle will give you the extra leverage to easily pop open the valve. At this point, you can let it drain into the wine bottle or let it drain into your pan. Just make sure to let it drain for a bit, so enough oil comes out of the filter housing. If you get enough of the oil out, it won't run all over your arm and make a mess.
Old 11-13-2012, 10:19 PM   #15 (permalink)
Dang, my 2WD has the skid plate. I have a 2012 though, if that makes a difference.
