Rust/bubbling paint in the floor of the Bed - TundraTalk.net - Toyota Tundra Discussion Forum
Old 10-17-2012, 01:20 PM   #1 (permalink)
I have 3 spots in my bed floor where its bubbling the paint and rusting out. I called the dealer and there is a TSB to replace the bed with a new one. OMG! Anybody been through this yet?
2010 White CrewMax Rock Warrior
searayrunner is offline   Reply With Quote
The Following User Says Thank You to searayrunner For This Useful Post:
dikkie (10-31-2012)
Old 10-17-2012, 02:01 PM   #2 (permalink)
tridacna's Avatar
Why not just get a liner sprayed in it?
tridacna is offline   Reply With Quote
The Following User Says Thank You to tridacna For This Useful Post:
dikkie (10-31-2012)
Old 10-17-2012, 02:03 PM   #3 (permalink)
Coachbuilder1's Avatar
A 2010 wow! What state are you in and is the rust coming from the underside of the bed or under the paint?
2007 SR5 5.7L Katzkin Leather interior, LED lighting through out, LED door handles, Color Matched handles grill surround and bushwacker pocket flares. CST 3.5" Spindles OME 614 Full Suspension Ekstrom Design & Fabrication 3" shackles, Testing a set of custom long travel air bags, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
Ekstrom Design & Fabrication LLC. 801.635.4872 "You Have To Do What Others Won't To Achieve What Others Don't!"
Coachbuilder1 is offline   Reply With Quote
The Following User Says Thank You to Coachbuilder1 For This Useful Post:
dikkie (10-31-2012)
Old 10-17-2012, 02:12 PM   #4 (permalink)
The dealer said its rusting from the inside out. They just did one a few weeks ago full bed rapacement. If you google it you will see a pic of one that was cut open, its like a cavity/space under the bed and support. My two worst spots are in front of the wheel wells and one spot behind the left wheel and all areas are on the bed floor.
There is not a single scratch in my bed or on my truck. Just these three areas where the paint is flaking and showing rust. I only have 31,000 on the truck.
I still need to take it into the dealer for photos and approval from Toyota but there is a TSB on it according to the rep and my dealer.
dikkie (10-31-2012)
Old 10-17-2012, 02:24 PM   #5 (permalink)
tridacna's Avatar
From the bottom up? Wow!
dikkie (10-31-2012)
Old 10-17-2012, 03:07 PM   #6 (permalink)
awww.. how cute.. toyota finally did something about this. My 07 was rusted all the way through and they fought it to the end. I ended up trading in the truck for $2700 more than i paid for it 2 years earlier
'12 Rock Warrior Crewmax
magnaflow / 2" leveling kit / airlift loadlifter 5k / afE pro dry s / XSP LED DRL's
j_fuggin_t is online now   Reply With Quote
The Following 2 Users Say Thank You to j_fuggin_t For This Useful Post:
dikkie (10-31-2012), searayrunner (10-18-2012)
Old 10-17-2012, 04:29 PM   #7 (permalink)
that is exactly how mine looks.
dikkie (10-31-2012)
Old 10-17-2012, 04:35 PM   #8 (permalink)
if youre under the 3yr/36 they will replace it no problem, but after that its a PITA.. you can clearly see that mine was cracked in the pictures (and even worse in person) and they fought it until i just took it in & traded it off & because my dealer wanted me to buy a new truck they handled it (which i believe resulted in a new bed for that old truck) the warranty for perforation rust through was 5yr/60k or unlimited i don't remember.. either way their customer service on that issue was horrendous, both at the dealer & at toyota corporate
The Following User Says Thank You to j_fuggin_t For This Useful Post:
dikkie (10-31-2012)
Old 10-17-2012, 04:42 PM   #9 (permalink)
Yea I am under 36,000 and 3 years. I really am dreading going through the whole process.
This truck has been great! Best truck I have ever owned and my first Toyota. But this really makes my little issues with domestics look small.
dikkie (10-31-2012)
Old 10-17-2012, 05:06 PM   #10 (permalink)
blktxtundra's Avatar
This is a quote straight from the bed rust TSB:
"APPLICABLE WARRANTY
• This repair is covered under the Toyota Corrosion Perforation. This warranty is in effect for 60
months unlimited miles, whichever occurs first, from the vehicle’s in-service date.
• Warranty application is limited to occurrence of the specified condition described in this
bulletin.
© 2012"
blktxtundra is offline   Reply With Quote
The Following 2 Users Say Thank You to blktxtundra For This Useful Post:
Old 10-18-2012, 07:22 AM   #11 (permalink)
Do you have the TSB #?
dikkie (10-31-2012)
Old 10-18-2012, 09:20 AM   #12 (permalink)
The TSB PDF wont let me save it to post here. This is the best link to it I could find.
http://www.google.com/url?q=http://w...tGkE58jPGJKNxQ
Old 10-22-2012, 03:38 PM   #13 (permalink)
thank you for posting that!
dikkie (10-31-2012)
Old 10-25-2012, 10:04 AM   #14 (permalink)
No one else has had the bed replaced yet due to this? Do they replace the plastics or reuse the old?
dikkie (10-31-2012)
Old 10-25-2012, 10:31 AM   #15 (permalink)
they tried to make me jump through flaming hoops to get it done, i gave up & traded it in, but that was prior to a TSB being out on it, had the TSB been out i would have just parked it & told them to call me when it was replaced. BUT i also put that partly on a shit dealer who wanted to do nothing for me except charge me, hence why i've switched to the other dealer & haven't looked back
dikkie (10-31-2012)
