So the passenger door lock actuator stopped working the other day. Checked the wiring and I have voltage at the plug for lock/unlock called the dealer and they said it wasn't under warranty. Just curious if anyone else had had this issue? It's an 08 with 57k on it. Dealer quoted $418 for a new actuator.
Did you get a part number? I found a few online.
2007 SR5 5.7L Katzkin Leather interior, LED lighting through out, LED door handles, Color Matched handles grill surround and bushwacker pocket flares. CST 3.5" Spindles OME 614 Full Suspension Ekstrom Design & Fabrication 3" shackles, Testing a set of custom long travel air bags, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset. Ekstrom Design & Fabrication LLC. 801.635.4872 "You Have To Do What Others Won't To Achieve What Others Don't!"
Funny you should mention this. This just happened to me and I checked the actuator and I have power to it. This tells me that the little motor inside has burned out. Of course Toyota wont sell just the little motor, but instead, sells the entire actuator itself. The actuators run from $160 for aftermarket or about $350 - $400 from the stealership. I found a couple of sites that will help you out, because all you need to do is replace the motor which costs...... $5. You have to remove the door panel and take the actuator apart, but its worth it in my book. I am going to be doing a write up once I get my parts in.
Past 8 months 3 doors have had to be replaced. 4th door is starting to go out
2010 tundra crew max trd package
20" BBS with toyo proxes 305/50/20
Airaid cai
Magnaflow Muffler Dual in Single out with tip
35W 6K HIDs lows and fogs
Full LED interior lights
Kinetik 2000 & 1800
Pioneer avh-4400bh
Crescendo audio bc3500 (subs)
Audioque 120.4 (mids and highs)
4 SA8v2
A big ass box
Focal 165KF(front)
DD mids with kenwood tweets (rear)
Yeah, it's a very common problem across the board for Toyotas. Mine went out last year, then all of the sudden they started working again a few months ago. Taking the door apart to get to it is easy, but I'm going the route of trying to replace just the motor
If you bought the oem actuator, replacing it is easy. Just take off the door panel, unscrew the actuator bolts and unplug the connector and manuver it out. It'll be tight but will come out without taking out the door channel. Install is reverse.
Do you have any use for the old one? If not, I'd like to have it to play around and see if I can fix it.
Are you sure that's the right motor? Is it a direct replacement? I would think that the motor in the actuator would have a gear or thread on the shaft.
I have an 08 with about 50k and my back left went out
That is just to replace the motor, not all the gears or whatever else is part of the whole lock mechanism. You can buy the entire assembly for probably a few hundred dollars from Toyota.
