Post your Used Oil Analysis (UOA)!!! - Page 3 - TundraTalk.net - Toyota Tundra Discussion Forum
post #31 of 375 (permalink) Old 07-13-2012, 01:07 PM
fosterelli's Avatar
Quoted: 3 Post(s)
I'd say definitely try GC...if your Amsoil is 3.0 after 5K miles, and my GC is 3.7 after 10K miles, I'd say the choice is easy now! I'm interested to see your GC results, since mine are on an old '07 100K engine that does a lot of short trips and idling...
2012 Ford F350 SRW CCLB Lariat Ultimate FX4 6.7L PSD 3.55 ELSD
2007 Range Rover Supercharged
1970 Ford Torino Cobra 429
SOLD: 2007 CrewMax Limited 5.7L 2WD
fosterelli is offline
The Following User Says Thank You to fosterelli For This Useful Post:
Bad Dad's Camrys (07-13-2012)
post #32 of 375 (permalink) Old 07-13-2012, 01:35 PM
aleaddict's Avatar
Quoted: 9 Post(s)
A couple questions for you BDT...
How did you drain your oil between changes? The reason I ask is because you might be seeing some cross-contamination from the previous oil used and the new stuff. I've read about some people hooking up a shop-vac to suction out as much used oil as possible. Have you ever tried doing this?
Second, does Toyota recommend the same weight oil (5W-20) in our engines that have a supercharger added? I'm wondering if the heavier GC (0W-30) might perform better with 500+ ponies under the hood. Not sure if there is any correlation between Hp and oil weight but it's something worth considering...
-- ale
2010 Tundra CM 5.7L Platinum 4x4/King OEM/Camburg UCA/front sway bar delete/Revtek diff drop/Air Lift bags & compressor/Daystar cradle/Corsa Sport exhaust/WKO sliders/RW wheels/StopTech cryo rotors/Hawk LTS pads/Exp1 front & rear bumpers/PIAA 525/JW Speaker 6150 fogs/RIJon rocker panel
aleaddict is offline
post #33 of 375 (permalink) Old 07-13-2012, 02:25 PM
tridacna's Avatar
Quoted: 3627 Post(s)
What oil did you use before the M1 at 34K? Was it also M1?
tridacna is offline
post #34 of 375 (permalink) Old 07-13-2012, 03:43 PM
tridacna's Avatar
I have M1 in now and I've got about 8K on this fill. I'm gonna change it out next week and send a sample in to see what the report says. I'm also changing the transmission fluid, maybe I'll send that in to.
tridacna is offline
post #35 of 375 (permalink) Old 07-13-2012, 07:04 PM
fosterelli's Avatar
Quoted: 3 Post(s)
For what it's worth...when I switched from M1 to GC I did nothing special...just drained, changed filter, and refilled with GC. The lab results I posted were from this first GC fill...the only thing I did to get my sample was take the drain plug out, let the used oil flow for a few seconds, and then put my sample bottle under the stream of oil exiting my pan.
post #36 of 375 (permalink) Old 07-14-2012, 07:42 AM
tridacna's Avatar
I think you should run it out to 8k and test it.
tridacna is offline
post #37 of 375 (permalink) Old 07-19-2012, 09:38 AM
Daveownsjoo's Avatar
Quoted: 4 Post(s)
I am running Amsoil OE and will pull it at 5k and send a sample in. Next, I am not sure what to run. Was thinking about trying either Amsoil XL, SS or maybe M1. I did not consider running GC because it is 30 grade oil. I have an unmodded motor. Please help me understand if there are any negative consequences to running the 30 grade vs the Toyota specified 20 grade oil?
'08 5.7L DC Ltd. Silver Sky Metallic
Volant CAI
Bilstein 5100 on all corners
Coachbuilder's +2 shackles
Method Fat Five 20x9
Toyo Open Country M/T 33x12.5
Daveownsjoo is offline
The Following User Says Thank You to Daveownsjoo For This Useful Post:
Mr. Creosote (07-22-2012)
post #38 of 375 (permalink) Old 07-19-2012, 12:15 PM
fosterelli's Avatar
Quoted: 3 Post(s)
The GC 0W30 is acceptable for the Tundra. The manual states "a heavier viscosity can be used in high temperatures, high speeds, towing, severe applications" or something to that effect. Toyota wants us to use 0W or 5W "winter grade" to keep the oil thin at initial start-up, but stopped at 20 on the other side to increase fuel economy to assist with CAFE. But certainly 30 is no problem for your engine or warranty, as it clearly states by Toyota that it is acceptable.
On another note, if you have engine noise (mine sounded like a diesel sometimes with M1), the 30 really made my engine less noisy. My motor is also unmodded.
The Following 2 Users Say Thank You to fosterelli For This Useful Post:
2011TundraInMe (05-26-2013), Mr. Creosote (07-22-2012)
post #39 of 375 (permalink) Old 07-19-2012, 01:26 PM
So if i live in a fairly cold climate (North Dakota) would it be wise not to run GC? or is it such a small difference that it wouldnt really matter?
Andersloot is offline
The Following User Says Thank You to Andersloot For This Useful Post:
post #40 of 375 (permalink) Old 07-19-2012, 01:38 PM
Quoted: 4 Post(s)
Starting viscosities should be the same so it wouldn't matter.
Sent from my Autoguide iPhone app
Volant CAI
The Following 2 Users Say Thank You to Daveownsjoo For This Useful Post:
Andersloot (07-19-2012), Mr. Creosote (07-22-2012)
post #41 of 375 (permalink) Old 07-19-2012, 01:52 PM
okay thats what i figured. Thanks!
post #42 of 375 (permalink) Old 07-19-2012, 04:17 PM
fosterelli's Avatar
Quoted: 3 Post(s)
Yes, no matter where you live (in the contiguous US), you should run 0W as first choice, and 20 or 30 on the flip side. Some like 5W for some reason, but thinner at start-up is better, even if it's 100 degrees outside. On the high side, that viscosity (20 or 30) is only for operating temperatures, so colder outside/ambient temperature has no effect on your oil choice.
Mr. Creosote (07-22-2012), Xchewiz (02-21-2013)
post #43 of 375 (permalink) Old 07-22-2012, 10:41 PM
Quoted: 47 Post(s)
Originally Posted by jaymz11 View Post
Since I get free oil changes from the dealer for two years how do I convince them to use German Castrol 5w-20???
fosterelli is right. the dealer won't run 0-30 for you. Castrol Syntec Edge w/ SPT (or whatever) is only made in Germany if it's 0w30. I checked all the other viscosities and they are all made in the U.S.. GC is like UFO's. We know they're out there but coming by one ain't easy. Actually, it's probably pretty easy if you use the resources on this thread.
2014 TT TRD Crewmax Magnetic Grey
TRD True Duals & TRD CAI
EXTANG solid tri-fold Tonneau
Weather Tech Digital Floor Mats
4.30, Tow & Cold Pkg Mich. AT2
Just Sold: Super White 2011 DC
5.7L 4x4 6.5' Bed
EZTundra77 is offline
The Following 2 Users Say Thank You to EZTundra77 For This Useful Post:
fosterelli (07-23-2012), Mr. Creosote (07-22-2012)
post #44 of 375 (permalink) Old 07-22-2012, 10:44 PM
Quoted: 47 Post(s)
That's probably one of the only things that allowed the 5.7 TT a ULEV. ULEV my ass. It certainly ain't Ultra Low Emissions from my wallet when it comes time to fill 'er up.
5.7L 4x4 6.5' Bed
blake711 (07-31-2012), fosterelli (07-23-2012)
post #45 of 375 (permalink) Old 07-31-2012, 10:04 AM
How long does it take to get your OA done once they receive it normally at Blackstone? I sent one in last week on wife's car. Post office said it should get there Thursday. Still haven't got an email yet.
blake711 is offline
