2014 Tundra - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 108 (permalink) Old 04-21-2012, 01:25 AM Thread Starter
2014 Tundra
2014 Tundra – What To Expect
Over the next few months and years, we’ll be adding content to this page about the next major Tundra re-design to debut, projected to be a 2014 model available in 2013. What follows below is projected enhancements, categorized as definite, likely, and possible.
» NOTE: Looking for info on the 2013/2014 Tacoma? Check out this post about Direct Injection in the 2013/2014 Tacoma
Please bookmark this post as it will be updated regularly. Last updated March 25,2012.ShareThis
Definite Enhancements
1. Larger fuel tank. Based on comments from Toyota engineer Mike Sweers (the man currently in charge of designing and developing the next generation Tundra) in this Wall Street Journal article, we know that the new truck will have a larger fuel tank.
2. More traditional styling. From the same article above, we learn that the truck will have a more traditional and aggressive truck like look. Hopefully, we’ll see a glimpse of this new look in the next year or two on a Toyota concept.
3. More aerodynamics and a lower ride height. One of the easiest ways to improve truck fuel economy is to reduce the ride height a little bit as well as flatten the underside the vehicle. The trick is doing these things without impacting ground clearance.
4. New dash. This is almost a foregone conclusion. While we may still see the over-sized knobs, we’ll definitely see better quality materials, new gauges, and a modified layout.
5. Direct injection. A source has confirmed that the 2014 Tundra will be offered with at least one direct injection engine. It’s unknown as to whether this will be the same direct injection V6 that is added to the 2014 Tacoma or direct injection for the 4.6L & 5.7L. Here’s to hoping it’s all three. Direct gasoline injection is a great way to improve fuel economy – it’s estimated that it can improve gas mileage from 5-10%, depending on the engine. (NOTE: We’ve heard from less reliable sources that Toyota will replace the 4.6L V8 with a smaller turbocharged V6…but this is still very much speculation.)
Likely Enhancements
1. Variable valve lift. Variable valve timing (VVT) is commonplace, but variable valve lift is still a newer feature on most vehicles. Toyota, long a fan of VVT, currently has a couple of engines running a variable-valve lift system. This should make it’s way into all Toyota vehicles in by the middle of the decade.
2. Electric steering. Hydraulic steering pumps are less efficient than electric motors. GM and Ford both plan to move this into their full-size trucks soon, and Toyota will likely follow. In fact, this will be a common feature industry wide.
3. Weight reduction. Toyota will definitely be emphasizing a lower curb weight in the next generation Tundra. However, what they will do to reduce weight is to be determined. It could be that we’ll see a composite pickup bed (similar to the Tacoma), increased use of high-strength steel (which is lighter albeit more expensive), and more expensive sound-deadening materials that dampen road noise without adding weight.
4. New frame design. Between the Tundra frame rust fiasco and complaints about harsh ride and bed bounce, the current Tundra’s frame is a weak spot in many consumer’s eyes. While it’s true that Toyota’s frame is similar in design to heavy-duty trucks offered by GM and Ford, the fact of the matter is that the current frame doesn’t have a good reputation. Look for Toyota to come up with something new.
5. Integrated trailer brake controller. If this feature isn’t already an option, it will be by 2014. Here’s to hoping it comes along sooner.
6. Engine stop-start. This system shuts off the engine at stop lights and then quickly restarts when it’s time to go. It’s a pretty good idea, it saves fuel, and the technology has been around for years. Takeshi Uchiyamada, Toyota executive VP in charge of R&D, has been quoted as saying that stop-start will be added to select products. Considering the amount of fuel used during idle by a big V8 – and considering the special allowance for stop-start systems in the most recent set of CAFE regulations – stop-start seems like a logical addition to the Tundra.
7. A new smaller and more efficient V6. Toyota is bringing out a replacement to the 4.0L V6 in the Tundra and Tacoma – the only question is when.
Possible Enhancements
NOTE: These items are based on informed speculation…but speculation none the less.
1. A diesel version of the half-ton Tundra. Once again, rumors of a diesel half-ton Tundra are picking up steam. While we’re highly skeptical, this is added to the list of “possibles.”
2. A Turbocharged V6 to replace the 4.6L V8. Based on the success of the EcoBoost F150 and comments from a handful of Toyota execs, Toyota seems likely to add a turbo-charged engine to the Tundra line-up at some point. Our best guess is that it will be a turbo-charged version of the new direct injection V6 that debuts in the Tundra and Tacoma. But will it be ready for 2014? Probably not. 2016 seems more likely.
3. More configuration options. We’ve been told that Toyota recognizes the Tundra’s limited configurations hamper sales – especially fleet sales. If Toyota allowed customers to pick and choose options, they could probably gain some sales. Initially, this seemed likely to be addressed in the redesign. However, recent conversations indicate that the next generation Tundra will likely have the same number of limited options that the current generation has.
4. A Hybrid Tundra is guaranteed, but it’s unlikely it will debut prior to 2016.
Unlikely Enhancements
1. HD version. An HD Tundra will not debut in 2014 – the future of the HD truck is still very much unknown, in fact, and may never be built.
2. 6.5′ bed on crew cabs. This option has been desired by a few in the comments section, but our source says it’s off the table.
rinny1 is offline
The Following 15 Users Say Thank You to rinny1 For This Useful Post:
dikkie (07-04-2012), fosterelli (07-28-2012), jamant12 (05-30-2012), kstateskier (06-29-2012), Mr. Creosote (04-21-2012), O&G (05-05-2012), plainsgrown (04-21-2012), RedBullistic (05-25-2012), ronaldjay (04-21-2012), sanchez (07-28-2012), totex (11-22-2012), Trubey (09-19-2012), TundraStruk (05-04-2012), txboyalone (05-31-2012), u sh00k (04-22-2012)
post #2 of 108 (permalink) Old 04-21-2012, 07:26 AM
This looks more like complete speculation regarding the particulars and copying based on the on off engine feature and the electronic steering which is already in the new dodges for next year. There will never be a diesel tundra, and honestly if they choose to make the truck any lighter they need to get out of the full size truck market.
2010 5.7 DC 4x4 LB W/T Injen CAI, Unichip, Nfab wheel to wheel 6 step, Bilstein HD shocks, Spintech Sportsman XL muffler, Jegs H-Pipe, Amsoil Signature 0w-30, Truck Covers USA Roll Cover,4.88 Nitro gears, Auburn Pro LSD, Supersprings SSA4, TRD sway bar, 275/70/18 Toyo Open Country A/T E rated.
Bill3508 is offline
The Following 4 Users Say Thank You to Bill3508 For This Useful Post:
dikkie (07-04-2012), mendonsy (04-21-2012), Mr. Creosote (04-21-2012), SP (04-21-2012)
post #3 of 108 (permalink) Old 04-21-2012, 09:00 AM
mendonsy's Avatar
It will be interesting to re-visit this thread when the 2014's actually arrive to see how much of this speculation is actually correct.
My guess ..... less than 25%.
07' SR5 DC, 5.7, TRD
Toyota SS steps, ARE MX cap
AMP bed step, DIY underseat storage
Weathertech Floor Liners, Weathertech Vent Visors
Cooper Discoverer AT3s, Techstream
TWACC #7
mendonsy is offline
The Following 3 Users Say Thank You to mendonsy For This Useful Post:
dikkie (07-04-2012), Mr. Creosote (04-21-2012), SP (04-21-2012)
post #4 of 108 (permalink) Old 04-21-2012, 09:02 AM
SP
Moderator
SP's Avatar
Quoted: 373 Post(s)
Where is this info from rinny?
2014 CM 5.7L 1794 edition
Front tint*OEM look alike Brushed steps*GENSSI® ELITE G7 H4 Led's*morimoto LED fogs(excellent)*interior canbus LED's*Husky Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*LowPro Rollup Tonneau cover*20 inch Black Rhino black wheels*Sotck nit size terra graplers*Bully Dog tuner AWESOME*
SP is offline
The Following 2 Users Say Thank You to SP For This Useful Post:
post #5 of 108 (permalink) Old 04-21-2012, 09:10 AM
jerryvt09's Avatar
Quoted: 24 Post(s)
I read the same thing on tundra headquarters SP. That may be where this come from.
2011 crewmax 4x4
Rough Country 3/1.5
XD Hoss Machined face 18"
33" Fierce Attitude M/T
Husky Weather Beaters
Soft Tonno Cover
jerryvt09 is offline
The Following 4 Users Say Thank You to jerryvt09 For This Useful Post:
dikkie (07-04-2012), Dnairn (04-21-2012), Mr. Creosote (04-21-2012), SP (04-21-2012)
post #6 of 108 (permalink) Old 04-21-2012, 09:14 AM
SP
Moderator
SP's Avatar
Quoted: 373 Post(s)
10-4 i dont read many other sites. I need to get out more
SP is offline
post #7 of 108 (permalink) Old 04-21-2012, 09:23 AM
there are other websites?
11 CM 5.7 SR5
Jayco Octane Toy Hauler
b22mundo is offline
The Following 2 Users Say Thank You to b22mundo For This Useful Post:
post #8 of 108 (permalink) Old 04-21-2012, 09:31 AM
I would hope they make a real effort to make substantial changes and updates, otherwise the tundra may be doomed. Just not sure the money is there to put into the program the way sales are, and I consider no news as bad signs. Going to have to be a real change that they believe will bring some sales back, not from already tundra owners but from converts.
Bill3508 is offline
The Following 2 Users Say Thank You to Bill3508 For This Useful Post:
post #9 of 108 (permalink) Old 04-21-2012, 02:27 PM
This is straight from tundra headquarters.
Powerhogger is offline
The Following 2 Users Say Thank You to Powerhogger For This Useful Post:
post #10 of 108 (permalink) Old 04-21-2012, 02:45 PM
I bet it'll just be a minor face lift like they did to the Tacoma.
stangallmotor is offline
The Following 2 Users Say Thank You to stangallmotor For This Useful Post:
post #11 of 108 (permalink) Old 04-21-2012, 02:52 PM
Cereal Killer
Mr. Creosote's Avatar
Quoted: 820 Post(s)
I think they'll go a far bit further because of fuel economy regulations. They should ignore this and offer more horsepower.
Mr. Creosote is offline
The Following 3 Users Say Thank You to Mr. Creosote For This Useful Post:
$h@ki (04-22-2012), dikkie (07-04-2012), JOSH 5.7 (04-21-2012)
post #12 of 108 (permalink) Old 04-21-2012, 03:26 PM
mendonsy's Avatar
Probably correct, but it's hard to guess.
The Taco is the result of a slow evolution from the original Toyota pickup from the '80's and has been successful that way.
The Tundra has been a different path which has not been as successful even though both generations are excellent vehicles.
TWACC #7
mendonsy is offline
The Following 2 Users Say Thank You to mendonsy For This Useful Post:
post #13 of 108 (permalink) Old 04-21-2012, 06:02 PM
Quoted: 76 Post(s)
If I was betting, I would bet direct injection, redesign of interior a lot more than redesign of exterior, and slightly lighter, slightly lower to increase aerodynamics. Direct injection will improve gas mileage 1-3 mpg at best but every mpg helps since the tundra is now the worst fuel economy 1/2 ton truck on the market currently, yet the most powerful on paper except chevy's 6.2L overpriced engine.
I still want the last option though being the most useful : A CREWMAX WITH 6 1/2' BED LENGTH to compete with Ford already having what I want darn it but don't like Ford design being too boxy. Give me my dream truck please!!!!!!!!!!!!!!
cookiedough1 is offline
The Following 2 Users Say Thank You to cookiedough1 For This Useful Post:
post #14 of 108 (permalink) Old 04-21-2012, 07:36 PM
Tundergas's Avatar
Quoted: 69 Post(s)
I'm excited to see what they do. I don't think it will be as drastic as the first gen to second gen. I'm really hoping Toyota does something MPG wise. If they want converts, they are going to have to hit mid to high 20s in MPG yet retain power. The interior will resemble the 4Runner I bet. The exterior I see becoming more boxy.
Either that, or we have the last gen Tundra already.
2014 SR5 CM TRD 4x4 2.5/1 level, Fuel Maverick 18x9, 305 65R18 Falkens, TRD sway, Color matched Handles/Caps, Partial Debadge, Tinted.
Tundergas is offline
The Following 2 Users Say Thank You to Tundergas For This Useful Post:
post #15 of 108 (permalink) Old 04-21-2012, 08:15 PM
jaymz11's Avatar
Quoted: 19 Post(s)
unfortunately i dont see toyota plunging much into the tuindra. it is a soft market vehicle right now compared to the smaller car lineup.
you guys are correct in saying that IF there are any updates they will prob be subtle like the "new" tacoma.
Texas Tundra Group Member #25
2014 Platinum Crewmax 4X4
TRD
Rear Sway Bar
TRD
Rock Warrior Shift Knob
TRD
Exhaust
Fred's 1.25" Spacers
Bilstein 6112/5160/ Coachbuilder +2" Shackles
Morimoto XB Fogs
2015 Highlander XLE
1987 SR5 4RUNNER
2012 TRD 4X4 Crewmax - Ignorantly Sold
jaymz11 is offline
The Following 2 Users Say Thank You to jaymz11 For This Useful Post:
