How much horsepower and torque do I have? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 18 (permalink) Old 03-02-2012, 02:51 AM Thread Starter
I have a 2007 DC 5.7 with a TRD exhaust and a aFe stage 2 Si intake. Does anyone know a round about number of horsepower and torque I have?
Vanswey is offline
The Following User Says Thank You to Vanswey For This Useful Post:
Mr. Creosote (03-03-2012)
post #2 of 18 (permalink) Old 03-02-2012, 03:14 AM
F&@k Y'all, I'm from Texas
Toxarch's Avatar
Quoted: 633 Post(s)
381 hp @ 5600 rpm; 401 lb.-ft. @ 3600 rpm
Originally Posted by MORON #1
Toxarch is offline
The Following 6 Users Say Thank You to Toxarch For This Useful Post:
ampakes (03-02-2012), aprevo15 (03-02-2012), Bad Dad's Camrys (03-02-2012), dikkie (03-02-2012), Mr. Creosote (03-03-2012), SP (03-02-2012)
post #3 of 18 (permalink) Old 03-02-2012, 04:22 AM
fishinfirefighter's Avatar
LMFAO!!!
But seriously hes probably right. Only your 381hp/401lb may be achieved at a slightly different RPM after the mods. Sorry man, but toyota did a pretty good job with our intake and exhaust in stock form Ive learned from the absolutely ridiculous amount of research Ive done.
Id say at most you bolted on about 15hp best case scenario. Hey... at least it sounds badass right?
2011 DC 5.7 4x4 Tow Lexus Starfire Pearl white
Color matched handles, mirrors, bumpers and grill surround, air bags, 6" lift, 20" Rockstars w/35" Nitto Dune Grapplers, Bushwacker pockets, BHLM w/Oracle Halos, AMP power steps, Pioneer AVHP-4300DVD, 1200watt RMS brutus amp, 2 12" ib flats, Zxi 150.4 Zeus amp to focal components front and rear. FETC #15
fishinfirefighter is offline
The Following 4 Users Say Thank You to fishinfirefighter For This Useful Post:
Bad Dad's Camrys (03-02-2012), brentwood (03-02-2012), dikkie (03-02-2012), Mr. Creosote (03-03-2012)
post #4 of 18 (permalink) Old 03-02-2012, 04:46 AM Thread Starter
Thanks for the reply but aren't those stock hp and torque ratings? I'm just not sure how much the upgraded exhaust and aFe intake give me. You can defiantly feel the difference.
Vanswey is offline
The Following 2 Users Say Thank You to Vanswey For This Useful Post:
post #5 of 18 (permalink) Old 03-02-2012, 05:19 AM
Exactly Youre peak numbers are probably very close to stock however you have more torque in a lower rpm range which is why you feel it. Thats the trick aftermarket companies tend to use often. Its very difficult to improve power across the board so they rob from upper where most people wouldnt notice it and give that power to the low end so you have more useable and noticeable power. Look up some dyno graphs of aftermarket exhaust and intake on the 5.7 and you'll see what I mean.
Better yet heres TRD exhaust dyno sheet after a couple attempts so this is best case scenario.
It shows a "Slight" increase over stock and dosent rob to give but most cheap exhaust looks kinda like this (maybe not so extreme but still the same idea)
(I know this dyno sheet isnt from a tundra, Im just trying to make the point clear)
The Following 2 Users Say Thank You to fishinfirefighter For This Useful Post:
post #6 of 18 (permalink) Old 03-02-2012, 05:24 AM
Aftermarket intake will be much closer to the second dyno sheet than the trd exhaust that was properly engineered.
post #7 of 18 (permalink) Old 03-02-2012, 12:25 PM
TRDWarrior's Avatar
Quoted: 25 Post(s)
Sounds like someone needs a supercharger.
2016 TRD Pro current rig
2011 TRD Rock Warrior Totaled
TRDWarrior is offline
The Following 5 Users Say Thank You to TRDWarrior For This Useful Post:
Bad Dad's Camrys (03-02-2012), dikkie (03-02-2012), fosterelli (03-02-2012), kstateskier (03-02-2012), Mr. Creosote (03-03-2012)
post #8 of 18 (permalink) Old 03-02-2012, 01:14 PM
Quoted: 642 Post(s)
Yes, you could have as much as 10 or so extra hp and as much as 10 or so extra pounds of torque. It does not materialize out of thin air though. This is not on top of factory ratings. This is whatever extra out of that makes it to the rear wheels from the engine. But realize, when they take these measurements they are doing it in a strictly controlled environment designed to squeeze out a few extra ponies at the wheels when everything is optimized. This means on a dyno at high rpm, in the perfect gear, temperature controlled, hood up, maybe a little extra air blowing on the engine. What it usually means in my experience is that the vehicle will pull with a little more urgency if you floor it at highway speeds but that's about it. Not much use stoplight to stoplight.
And before you ask, no, the advertised rating on the box plus for the exhaust plus the advertised rating on the box for the intake won't equal the improvement you will see at the wheels. Just doesn't work that way. There are plenty of setups with both that still only have 5-10 extra hp.
The cost of fuel to operate a 6000 pound 400 horsepower half ton that does 0-60 in under 7 seconds is kind of like the price of oil changes for a Porche 911. If you have to ask you probably can't afford it.
eharri3 is offline
The Following 2 Users Say Thank You to eharri3 For This Useful Post:
post #9 of 18 (permalink) Old 03-02-2012, 01:23 PM
aprevo15's Avatar
How about MPG with the exhaust and intake?
aprevo15 is offline
The Following 2 Users Say Thank You to aprevo15 For This Useful Post:
post #10 of 18 (permalink) Old 03-02-2012, 04:15 PM
Toxarch's Avatar
Quoted: 633 Post(s)
All they will do is move the power curve a little. You lose some low end and gain a little high end.
Toxarch is offline
The Following 4 Users Say Thank You to Toxarch For This Useful Post:
dikkie (03-02-2012), Mr. Creosote (03-03-2012), SP (03-02-2012), TexasTundra4.6 (03-02-2012)
post #11 of 18 (permalink) Old 03-02-2012, 08:17 PM
Powertechn2's Avatar
Quoted: 1100 Post(s)
most will gain in the upper rpm range, but you lose low end a lil...
all it does is shift where the power is.
for these trucks most cai's are not worth the $$, you can do a drop in and get about the same result.
alot of time the feel is the fact that the curve isn't as flat and has a higher peak...
in general tho most of the gains are at higher rpm than what is used typically every day.
it just is what it is.
if you really would like to know, get it dyno'd... we will all be interested in seeing what it is, however you do not have a baseline to go off of unless you find someone with a stock tundra with same gearing/tires to dyno on the same day...
and you can call me Power.
Powertechn2 is offline
The Following 2 Users Say Thank You to Powertechn2 For This Useful Post:
post #12 of 18 (permalink) Old 03-02-2012, 08:24 PM
SP
Moderator
SP's Avatar
Quoted: 373 Post(s)
600hp!!!!
2014 CM 5.7L 1794 edition
Front tint*OEM look alike Brushed steps*GENSSI® ELITE G7 H4 Led's*morimoto LED fogs(excellent)*interior canbus LED's*Husky Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*LowPro Rollup Tonneau cover*20 inch Black Rhino black wheels*Sotck nit size terra graplers*Bully Dog tuner AWESOME*
SP is offline
The Following 2 Users Say Thank You to SP For This Useful Post:
post #13 of 18 (permalink) Old 03-02-2012, 11:05 PM
Toxarch's Avatar
Quoted: 633 Post(s)
Originally Posted by SP View Post
600hp!!!!
That kind of HP takes a lot of performance stickers on the back window and bumper.
Toxarch is offline
The Following 2 Users Say Thank You to Toxarch For This Useful Post:
Mr. Creosote (03-03-2012), SP (03-03-2012)
post #14 of 18 (permalink) Old 03-02-2012, 11:27 PM
Quoted: 161 Post(s)
What I did and a little more to stop wasting time. Want a little gain of 5-15HP, try multiple add ons that may not give cumulative gain. Work on the bigger pic, and gains to go!!!!
2000 Tundra Supercharged 4.7 Ivan Stewart in Red Pearl.
New England Tundra Club Member #3
Forced Induction Club #13
jbtoy1 is offline
The Following User Says Thank You to jbtoy1 For This Useful Post:
post #15 of 18 (permalink) Old 03-03-2012, 02:18 AM
could just give the truck a rubdown with K-Y... may not add power but will be soo slippery it will seem like a 200 shot of N2O
