Brake fluid in power Steering - TundraTalk.net - Toyota Tundra Discussion Forum
Go Back   TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Drivetrain
Old 12-23-2012, 07:00 PM   #1 (permalink)
I just topped off the power steering reservoir with brake fluid in my 08 CC.
Sucked out as much as I could before starting the truck.
Do I need to do anything else besides learning to read?
gafilda is offline   Reply With Quote
Old 12-24-2012, 01:22 PM   #2 (permalink)
TRENT310's Avatar
Probably would be a good idea to flush the entire system... so do the steering rack as well - which will involve doing lock-to-lock steering (front end lifted off the ground) quite a few times. Even though both are hydraulic fluids the additives are different and brake fluid has the potential to damage the seals on the power steering system over a long period of exposure.
2011 F-350SD SRW XLT FX4 CCLB: 6.7L PSD, 6R140, 3.55:1 EL, 11500lb GVWR
2009 Tundra SR5 4x2 RCLB¹ 5.7L 4.30:1 (Sold)
Others: 1983 F-250HD 4x2 RCLB 6.9L-IDI // 1988 F-250HD 4x4 SCLB 7.3L-IDI // 1995 F-350HD DRW 4x2 CCFB 7.3L-T444E PSD // 2004 F-350SD SRW 4x4 CCLB 6.0L-VT365 PSD.
¹VIN details are accurate for the linked truck only, YMMV.
TRENT310 is offline   Reply With Quote
Old 12-24-2012, 02:20 PM   #3 (permalink)
true....its going to eat up all ur seals in the power steering... drain it out dry and use new power steering
DIY: Power Steering Fluid Flush/Exchange - Toyota Nation Forum : Toyota Car and Truck Forums
bodio is offline   Reply With Quote
Old 12-24-2012, 06:07 PM   #4 (permalink)
Thank you...
If I empty the reservoir and refill with fresh daily for a week or so, will that do the same thing, making sure to go lock to lock when I drive it.
Old 12-24-2012, 06:58 PM   #5 (permalink)
OkSlim's Avatar
Originally Posted by gafilda View Post
Thank you...
Get the brake fluid out at the dealer or some other shop ASAP!.
Brake fluid is corrosive. I can't think of the name of the material used in brake systems but it is different than the softgoods in a power steering system.
The voices in my head don't like you.
2008 RCSB 4.7 TRD Offroad 4x4
OkSlim is offline   Reply With Quote
Old 12-26-2012, 03:20 PM   #6 (permalink)
Tech_Greek's Avatar
This
The power steering system is made to handle the detergents of transmission fluid, not brake fluid. It'll literally eat the seals away.
Tech_Greek is offline   Reply With Quote
Old 12-26-2012, 06:14 PM   #7 (permalink)
nastyn8's Avatar
Better than the other way around, at least this way you have time to get it out. If you put powersteering fluid in the brake reservoir the seals would already be bloated
Lotsa Crap Added
nastyn8 is offline   Reply With Quote
