Rear End Failure/Replacement Thread - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 07-13-2012, 03:59 PM Thread Starter
Quoted: 106 Post(s)
If anyone has seen my threads lately you know my rear end was making a very bad noise and I finally had to replace it.
I finally took it apart and here are my findings. similar to what everyone else with failures has found.
As you can see, the pin slid out and was bouncing around. It looks like the set screw that holds the pin in place backed out and let the pin fly free. This did not cause complete failure, and all the gears are still in good shape. I'm going to replace the housing and the pin and it will be in great working order again.
Anyone else with rear end problems please post.
Thanks!!
2007 Black TRD SR5 4x4 DC 198k Miles
37x13.5 Nitto Mud Grapplers
OME 613s w/ 4.5" Rough Country Lift
AirBags in Rear
IronCross Bumper with 12k Synthetic Winch
Hornblasters 540 Kit
dothedeww is offline
The Following 2 Users Say Thank You to dothedeww For This Useful Post:
Ogtoyfan (02-24-2013), scram84 (07-14-2012)
post #2 of 16 (permalink) Old 07-13-2012, 05:51 PM
crzy2bealive's Avatar
Quoted: 19 Post(s)
I forget wht was the reason or having the warranty claim denied
Sent from my Autoguide iPhone app
crzy2bealive is offline
The Following User Says Thank You to crzy2bealive For This Useful Post:
post #3 of 16 (permalink) Old 07-14-2012, 02:30 AM
Oct 2009 ToTM Winner
xtremelow's Avatar
Quoted: 14 Post(s)
I had my rear end replaced but was told the pinion gears were broken and lead to further damage. I was never able to physically see it or pictures as it was done under warranty.
Unguided Missile Member #1
2010 DC, King and Deaver for the speed bumps
xtremelow is offline
The Following User Says Thank You to xtremelow For This Useful Post:
post #4 of 16 (permalink) Old 07-14-2012, 05:15 PM Thread Starter
Quoted: 106 Post(s)
MAkes me very curious. Mine would be a simple fix if I had caught it early, just a new set screw and your good to go.
AirBags in Rear
The Following User Says Thank You to dothedeww For This Useful Post:
post #5 of 16 (permalink) Old 02-10-2013, 10:37 PM
Mine is exactly like your pic. The holding pin snapped allowing the main pin to slop around. Now to figure out who to have fix it.
cainon01 is offline
The Following User Says Thank You to cainon01 For This Useful Post:
post #6 of 16 (permalink) Old 02-10-2013, 10:49 PM Thread Starter
Quoted: 106 Post(s)
I got one out of a junkyard from car-part.com for $1800 and spent 8 hours putting the whole new rear assembly in. Not a hard job, just takes a while!
AirBags in Rear
cainon01 (02-15-2013), Ogtoyfan (02-24-2013)
post #7 of 16 (permalink) Old 02-10-2013, 11:36 PM
RIjon's Avatar
Quoted: 11 Post(s)
Throw that in the scrap pile and get an auburn LSD or an arb locker.
08 RCSB 2wd boosted
10 4Runner
RIjon is offline
The Following User Says Thank You to RIjon For This Useful Post:
post #8 of 16 (permalink) Old 02-13-2013, 02:04 AM
Quoted: 291 Post(s)
What am I supposed to be looking at in this pic?
Thanks!!
randomwalk101 is offline
The Following User Says Thank You to randomwalk101 For This Useful Post:
post #9 of 16 (permalink) Old 02-13-2013, 10:36 AM
RIjon's Avatar
Quoted: 11 Post(s)
That large pin in the center of the differential has slipped downward and the end has been getting destroyed from hitting things while spinning. At some point it will fall more and either lock the axles up, or (most likely) it will will grenade the center section completely.
08 RCSB 2wd boosted
10 4Runner
RIjon is offline
The Following 3 Users Say Thank You to RIjon For This Useful Post:
cainon01 (02-15-2013), dothedeww (02-13-2013), Ogtoyfan (02-24-2013)
post #10 of 16 (permalink) Old 02-13-2013, 10:51 AM
Quoted: 3 Post(s)
Does anyone have a picture of what it should look like?
MikeMc is offline
The Following User Says Thank You to MikeMc For This Useful Post:
post #11 of 16 (permalink) Old 02-13-2013, 03:28 PM
RIjon's Avatar
Quoted: 11 Post(s)
It would be where it is, just not poking out at either end.
The pin retains the spider gears and is(should be) retained with a small bolt.
Here is/was mine sitting on the bench from my LSD install
08 RCSB 2wd boosted
10 4Runner
RIjon is offline
post #12 of 16 (permalink) Old 02-13-2013, 08:33 PM Thread Starter
Quoted: 106 Post(s)
Thanks for answering the questions
AirBags in Rear
post #13 of 16 (permalink) Old 02-13-2013, 09:19 PM
Quoted: 291 Post(s)
I replaced mine with auburn LSD so it's in the box somewhere. I never even looked at it lol.
The Following 4 Users Say Thank You to randomwalk101 For This Useful Post:
cainon01 (02-15-2013), dothedeww (02-14-2013), Ogtoyfan (02-24-2013), Yuckfou (09-14-2016)
post #14 of 16 (permalink) Old 02-15-2013, 03:04 AM
Getting an auburn put in mine right now.
cainon01 is offline
post #15 of 16 (permalink) Old 02-24-2013, 12:08 AM
Did your rear end fail? is so what was the mileage at the failure? never heard of this before...
nsxman2001 is offline
The Following User Says Thank You to nsxman2001 For This Useful Post:
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Drivetrain
