Dual Battery Setup - TundraTalk.net - Toyota Tundra Discussion Forum
Old 06-15-2010, 08:59 AM   #1 (permalink)
nyrbyllek's Avatar
Dual Battery Setup
Ok, so I searched and found nothing, so i thought i would just ask. I am putting together my plans to do my new audio setup and I would like to use 2 batteries. I didn't see any posts about it, so I wanted to get some input on what some people thought about it, and to see if anybody has installed a second battery. Thank you!
2010 Black Tundra Double Cab 4x4 5.7
Daystar 3" Level kit in front
KMC Monster 18x9 35mm offset
275/70/18 BFG AT's
nyrbyllek is offline   Reply With Quote
Old 06-15-2010, 10:02 AM   #2 (permalink)
Tundra5-0's Avatar
As far as I know you would be the first. I have never done one before, good luck.
2008 Tundra Supercharged Dbl Cab: MODS-Grillcraft grille, BHLM, Corsa exhaust, Pioneer Avic-z110bt, Boss 335 22's, Kenwood amps, Memphis 12" sub, Alpine components, dynamat, custom enclosure, Extang Revolution, Katzkin Seats w/heaters, DJM drop arms, TundraRacing rear drop kit, Firestone RideRite system, Viar compressor, F/R drilled and slotted rotors.
Tundra5-0 is offline   Reply With Quote
Old 06-15-2010, 10:51 AM   #3 (permalink)
Two or more batteries is normal in a power hungry audio system. When the bass hits very hard it stabilizes the voltage.
Two batteries can be done, I believe Marky Mark has two or more batteries. The type and quality of the batteries are key though.
2010 Tundra Crewmax 5.7L Silver Sky Metallic with NFab Bars and Husky Liners
Fast Bikez International M.C.
STT http://www.sportbiketracktime.com
Jennings GP http://www.jenningsgp.com
Dexxx is offline   Reply With Quote
Old 06-15-2010, 02:30 PM   #4 (permalink)
F&@k Y'all, I'm from Texas
Toxarch's Avatar
Gameroom cash: $112093
Someone stuck a second battery near the ECU plug. I'd build a bracket and mount the second one under the truck.
All mod descriptions and pictures © 2007-2013 by Toxarch. They may be copied only for personal use and the mods may be done for non-profit only.
Originally Posted by MORON #1
Old 06-15-2010, 03:55 PM   #5 (permalink)
TRENT310's Avatar
Yeah, chassis cabs have the battery mounted on the frame under the body.
2011 F-350SD SRW XLT FX4 CCLB: 6.7L PSD, 6R140, 3.55:1 EL, 11500lb GVWR
2009 Tundra SR5 4x2 RCLB¹ 5.7L 4.30:1 (Sold)
Others: 1983 F-250HD 4x2 RCLB 6.9L-IDI // 1988 F-250HD 4x4 SCLB 7.3L-IDI // 1995 F-350HD DRW 4x2 CCFB 7.3L-T444E PSD // 2004 F-350SD SRW 4x4 CCLB 6.0L-VT365 PSD.
¹VIN details are accurate for the linked truck only, YMMV.
TRENT310 is offline   Reply With Quote
Old 06-15-2010, 04:47 PM   #6 (permalink)
I've heard that the regulator on the altenator is capped at 13.8 volts, not 14.4, so don't use a battery isolator as it will drop your voltage down to 13 to 13.1 volts. Run the batteries in parallel (connect the two positive battery posts together, and the two negative posts together, use actual wire to connect the negatives together and not the frame) and use 2/0 or even 4/0 gauge wire. 1/0 could be used, but if you are doing a high-wattage audio system, then go with the larger wire for safety. Another reason to use the larger wire is that without the battery isolator, your engine starter will pull from both batteries at the same time, so the wire will have to stand up to a high peak currents.
Nothing special. Yet...
2008 Black Double Cab, 5.7L, 4*4, SR5, bed liner and step rails
Black Tundra Club Member #19
smmiller506 is offline   Reply With Quote
Old 06-15-2010, 05:42 PM   #7 (permalink)
Well since noone mentioned it: add a high output alternator. I'm sure you already have a capacitor lined up as well. A battery tender wouldn't hurt either, C-Tek makes a few nice ones. Since you'll probably daisy chain them, one will suffice.
Telos is offline   Reply With Quote
Old 06-15-2010, 08:20 PM   #8 (permalink)
Marky Mark's Avatar
I have a second battery underneath the rear of the truck behind the rear wheel. Will be posting pics eventually of it as it will be used mainly to run my air compressors for my AirRide...Will be adding a 3rd one eventually once I get back to increasing my stereo setup later in the year. I have an isolator too so that the back battery is seperate from the front when the truck is off..That way you will not drain the front starting battery.
"They Were Just Jealous That My Tundra Pulled More Kitties Than A Bowl Of Milk"
Marky Mark is offline   Reply With Quote
Old 06-15-2010, 08:40 PM   #9 (permalink)
Brian's Avatar
Don't all the Tundras from southeastern toyota dealers already come with the cold weather package and a pretty beefy alternator ? Does it need more than it's got ?
Originally Posted by Big Tundra View Post
Nice truck Bri- looks lifted like Sams
2012 Black 5.7 CrewMax 4x4
BIG RIG CLUB MEMBER #48
Brian is offline   Reply With Quote
Old 06-15-2010, 11:09 PM   #10 (permalink)
nyrbyllek's Avatar
Thanks for the input, I think I'm going to just use one battery for now because I don't plan on running a crazy powerful system, but i know that a few friends of mine reccomended it because when their bass would hit, their headlights would dim at times and on coming traffic thought they were flicking their lights at them (I found that part pretty comical). Anyway i will keep all the advice in mind, thanks alot.
P.S. I will be running a capacitor regardless.
275/70/18 BFG AT's
Old 06-15-2010, 11:25 PM   #11 (permalink)
Bigger alternator or dual alternators (haven't seen that though) will help with that.
Old 06-16-2010, 01:11 AM   #12 (permalink)
hollatchaboy's Avatar
Please post pics of the second batt, Mark! I plan on doing 3 or 4 batteries for my setup. Should act as a nice leveling kit for me
2010 Rock Warrior
22" Matte Black Ultra Magnus Wheels on 305/45/22 General Grabbers
Hornblasters Shocker 240 Train Horns
Grillcraft Black grille
<img src=http://i32.photobucket.com/albums/d41/cheacheaboiboi/sig-1.jpg border=0 alt= />
hollatchaboy is offline   Reply With Quote
Old 06-16-2010, 02:59 AM   #13 (permalink)
Well I'm pretty sure mine didn't. But to keep 2 batteries charging properly, a high output alternator (just one) will put out twice the power as the OEM. DC alternators has one that is 3 times the output (he said that usually only the pros need that for their SPL competitions). You also have to upgrade the wiring as well and or course the belt. But I'm sure a capacitor will handle all the bass.
BTW most people don't need 2 batteries or high output alternator. But once you get one, you'll need the other. I would recommend the OP get a stronger battery. My lights (currently 6 pairs of HID, halogens are more power hungry) would kill the OEM, put in a similar size Optima. The volts raised slightly, had to move to a larger one. Now no problems, but as the setup grows will move to a dual.
Old 06-16-2010, 05:53 AM   #14 (permalink)
1SIKTUN's Avatar
My AV guy will be installing dual Kinetic batteries once I return to the U.S. Will keep ya'll posted.
Mods? None, I'm rolling stock
1SIKTUN is offline   Reply With Quote
Old 06-16-2010, 06:39 AM   #15 (permalink)
Marky Mark's Avatar
^^Kinetic are nice batteries!
